RTEMS
6.1-rc2
libdl
rtl-trampoline.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
52
53
* COPYRIGHT (c) 2019 Chris Johns <chrisj@rtems.org>
54
55
56
* modification, are permitted provided that the following conditions
57
* are met:
58
* 1. Redistributions of source code must retain the above copyright
59
* notice, this list of conditions and the following disclaimer.
60
* 2. Redistributions in binary form must reproduce the above copyright
61
* notice, this list of conditions and the following disclaimer in the
62
* documentation and/or other materials provided with the distribution.
63
64
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
65
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
66
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
67
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
68
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
69
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
70
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
71
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
72
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
73
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
74
* POSSIBILITY OF SUCH DAMAGE.
75
76
77
#if !defined (_RTEMS_RTL_TRAMPOLINE_H_)
78
#define _RTEMS_RTL_TRAMPOLINE_H_
79
80
rtems/rtl/rtl-unresolved.h
81
82
#ifdef __cplusplus
83
extern
"C"
84
#endif
/* __cplusplus */
85
97
bool
rtems_rtl_trampoline_add
rtems_rtl_obj
* obj,
98
const
uint16_t flags,
99
const
uint16_t sect,
100
const
rtems_rtl_word
symvalue,
101
const
rtems_rtl_word
* rel);
102
108
void
rtems_rtl_trampoline_remove
rtems_rtl_obj
* obj);
109
110
#ifdef __cplusplus
111
112
#endif
/* __cplusplus */
113
114
#endif
void rtems_rtl_trampoline_remove(rtems_rtl_obj *obj)
Definition:
rtl-unresolved.c:740
bool rtems_rtl_trampoline_add(rtems_rtl_obj *obj, const uint16_t flags, const uint16_t sect, const rtems_rtl_word symvalue, const rtems_rtl_word *rel)
Definition:
rtl-unresolved.c:698
rtl-unresolved.h
RTEMS Run-Time Linker Object File Unresolved Relocations Table.
rtems_rtl_word
uint32_t rtems_rtl_word
Definition:
rtl-unresolved.h:86
rtems_rtl_obj
Definition:
rtl-obj.h:200
