RTEMS 6.1-rc2
This header file defines the Regulator API. More...
struct | rtems_regulator_attributes |
Attributes for Regulator Instance. More... | |
struct | rtems_regulator_statistics |
Statistics for Regulator Instance. More... | |
Typedefs | |
typedef bool(* | rtems_regulator_deliverer) (void *context, void *message, size_t length) |
Regulator Delivery Function Type. | |
typedef struct _Regulator_Control * | rtems_regulator_instance |
Regulator Instance. | |
rtems_status_code | rtems_regulator_create (rtems_regulator_attributes *attributes, rtems_regulator_instance **regulator) |
Create a regulator. | |
rtems_status_code | rtems_regulator_delete (rtems_regulator_instance *regulator, rtems_interval ticks) |
Delete a regulator. | |
rtems_status_code | rtems_regulator_obtain_buffer (rtems_regulator_instance *regulator, void **buffer) |
Obtain Buffer from Regulator. | |
rtems_status_code | rtems_regulator_release_buffer (rtems_regulator_instance *regulator, void *buffer) |
Release Previously Obtained Regulator Buffer. | |
rtems_status_code | rtems_regulator_send (rtems_regulator_instance *regulator, void *message, size_t length) |
Send to regulator instance. | |
rtems_status_code | rtems_regulator_get_statistics (rtems_regulator_instance *regulator, rtems_regulator_statistics *statistics) |
Obtain statistics for regulator instance. | |
