Real mode interrupt call implementation.
More...
#include <bsp/realmode_int.h>
#include <rtems/score/cpu.h>
struct | RTEMS_PACKED |
| Used for passing and retrieving registers content to/from real mode interrupt call. More...
#define | IR_EAX_OFF "0x00" |
#define | IR_EBX_OFF "0x04" |
#define | IR_ECX_OFF "0x08" |
#define | IR_EDX_OFF "0x0C" |
#define | IR_ESI_OFF "0x10" |
#define | IR_EDI_OFF "0x14" |
#define | IR_DS_OFF "0x18" |
#define | IR_ES_OFF "0x1A" |
#define | IR_FS_OFF "0x1C" |
#define | IR_GS_OFF "0x1E" |
#define | BKP_ESP_OFF "0x20" |
#define | BKP_SS_OFF "0x24" |
#define | BKP_DS_OFF "0x26" |
#define | RM_ENTRY "0x28" |
#define | PM_ENTRY "0x2C" |
#define | BKP_IDTR_LIM "0x00" |
#define | BKP_IDTR_BASE "0x02" |
#define | BKP_ES_OFF "0x06" |
#define | BKP_FS_OFF "0x08" |
#define | BKP_GS_OFF "0x0A" |
#define | RML_ENTRY "0x0C" |
#define | RML_D_SEL "0x12" |
#define | RM_SS "0x14" |
#define | RM_SP "0x16" |
#define | RM_DS "0x18" |
#define | REAL_MODE_SPOT 0x12000 |
#define | DEFAULT_BUFFER_SIZE 512 |
#define | STACK_SIZE 8192 |
#define | INT_STACK_TOP REAL_MODE_SPOT |
#define | __DP_TYPE uint8_t |
#define | __DP_YES ((__DP_TYPE)1) |
#define | __DP_NO ((__DP_TYPE)-1) |
#define | __DP_FAIL ((__DP_TYPE)0) |
#define | rml_limit 0xFFFF |
void * | i386_get_default_rm_buffer (uint16_t *size) |
| Returns buffer and its size usable with real mode interrupt call.
int | i386_real_interrupt_call (uint8_t interrupt_number, i386_realmode_interrupt_registers *ir) |
| Call to real mode interrupt with specified int NO and processor registers.
◆ i386_get_default_rm_buffer()
void * i386_get_default_rm_buffer |
uint16_t * |
size | ) |
Provides position to real mode buffer. It is buffer accessible from real mode context - it is located below address ~0x100000 in order for it to be accessible This buffer is meant to be pointed to by segReg:GenPurpReg and through this get bigger portion of an information to/from interrupt service routine than just by using register.
- Parameters
[out] | size | pointer to variable, where the size of buffer will be filled |
- Return values
◆ i386_real_interrupt_call()
int i386_real_interrupt_call |
uint8_t |
interrupt_number, |
i386_realmode_interrupt_registers * |
ir |
This function allows calling interrupts in real mode and to set processor registers as desired before interrupt call is made and to retrieve the registers content after call was made.
- Parameters
[in] | interrupt_number | interrupt number to be called |
[in] | ir | pointer to structure containing registers to be passed to interrupt and to retrieve register content after call was made. |
- Return values
0 | call failed (GDT too small or pagin is on) |
1 | call successful |
