RTEMS 6.1-rc2
POSIX FIFO/pipe File System Support. More...
struct | pipe_control |
Typedefs | |
typedef struct pipe_control | pipe_control_t |
void | pipe_release (pipe_control_t **pipep, rtems_libio_t *iop) |
Release a pipe. | |
int | fifo_open (pipe_control_t **pipep, rtems_libio_t *iop) |
File system open. Interface to file system open. | |
ssize_t | pipe_read (pipe_control_t *pipe, void *buffer, size_t count, rtems_libio_t *iop) |
File system read. | |
ssize_t | pipe_write (pipe_control_t *pipe, const void *buffer, size_t count, rtems_libio_t *iop) |
File system write. | |
int | pipe_ioctl (pipe_control_t *pipe, ioctl_command_t cmd, void *buffer, rtems_libio_t *iop) |
File system Input/Output control. | |
This include file defines the interface to the POSIX FIFO/pipe file system support.
