RTEMS 6.1-rc2
The RTEMS Monitor Task. More...
struct | rtems_monitor_symbol_t |
struct | rtems_monitor_generic_t |
struct | rtems_monitor_task_t |
struct | rtems_monitor_init_task_t |
struct | rtems_monitor_queue_t |
struct | rtems_monitor_sema_t |
struct | rtems_monitor_extension_t |
struct | rtems_monitor_region_t |
struct | rtems_monitor_part_t |
struct | rtems_monitor_driver_t |
struct | rtems_monitor_config_t |
union | rtems_monitor_union_t |
struct | rtems_monitor_server_request_t |
struct | rtems_monitor_server_response_t |
union | _rtems_monitor_command_arg_t |
struct | rtems_monitor_command_entry_s |
struct | rtems_monitor_object_info_t |
#define | RTEMS_MONITOR_SUSPEND 0x0001 /* suspend monitor on startup */ |
#define | RTEMS_MONITOR_GLOBAL 0x0002 /* monitor should be global */ |
#define | RTEMS_MONITOR_NOTASK 0x0004 /* do not start monitor task */ |
#define | RTEMS_MONITOR_NOSYMLOAD 0x0008 /* do not load symbols */ |
#define | RTEMS_MONITOR_WAITQUIT 0x0010 /* wait for monitor task to terminate */ |
#define | MONITOR_SYMBOL_LEN 20 |
#define | RTEMS_MONITOR_NAME (rtems_build_name('R', 'M', 'O', 'N')) |
#define | RTEMS_MONITOR_SERVER_NAME (rtems_build_name('R', 'M', 'S', 'V')) |
#define | RTEMS_MONITOR_QUEUE_NAME (rtems_build_name('R', 'M', 'S', 'Q')) |
#define | RTEMS_MONITOR_RESPONSE_QUEUE_NAME (rtems_build_name('R', 'M', 'R', 'Q')) |
#define | RTEMS_MONITOR_SERVER_RESPONSE 0x0001 |
#define | RTEMS_MONITOR_SERVER_CANONICAL 0x0002 |
#define | MONITOR_WAKEUP_EVENT RTEMS_EVENT_0 |
Typedefs | |
typedef struct _rtems_symbol_t | rtems_symbol_t |
typedef struct _rtems_symbol_table_t | rtems_symbol_table_t |
typedef struct rtems_monitor_command_entry_s | rtems_monitor_command_entry_t |
typedef union _rtems_monitor_command_arg_t | rtems_monitor_command_arg_t |
typedef void(* | rtems_monitor_command_function_t) (int argc, char **argv, const rtems_monitor_command_arg_t *command_arg, bool verbose) |
typedef const void *(* | rtems_monitor_object_next_fn) (void *, void *, rtems_id *) |
typedef void(* | rtems_monitor_object_canonical_fn) (void *, const void *) |
typedef void(* | rtems_monitor_object_dump_header_fn) (bool) |
typedef void(* | rtems_monitor_object_dump_fn) (void *, bool) |
typedef bool(* | rtems_monitor_per_command_routine) (const rtems_monitor_command_entry_t *, void *) |
void | rtems_monitor_pause_cmd (int, char **, const rtems_monitor_command_arg_t *, bool) |
void | rtems_monitor_fatal_cmd (int, char **, const rtems_monitor_command_arg_t *, bool) |
void | rtems_monitor_continue_cmd (int, char **, const rtems_monitor_command_arg_t *, bool) |
void | rtems_monitor_debugger_cmd (int, char **, const rtems_monitor_command_arg_t *, bool) |
void | rtems_monitor_reset_cmd (int, char **, const rtems_monitor_command_arg_t *, bool) |
void | rtems_monitor_node_cmd (int, char **, const rtems_monitor_command_arg_t *, bool) |
void | rtems_monitor_symbols_loadup (void) |
int | rtems_monitor_insert_cmd (rtems_monitor_command_entry_t *) |
void | rtems_monitor_wakeup (void) |
void | rtems_monitor_command_iterate (rtems_monitor_per_command_routine routine, void *arg) |
Iterates through all registerd commands. | |
rtems_status_code | rtems_monitor_suspend (rtems_interval timeout) |
void | rtems_monitor_kill (void) |
void | rtems_monitor_init (uint32_t) |
void | rtems_monitor_task (rtems_task_argument) |
void | rtems_monitor_server_kill (void) |
rtems_status_code | rtems_monitor_server_request (uint32_t, rtems_monitor_server_request_t *, rtems_monitor_server_response_t *) |
void | rtems_monitor_server_task (rtems_task_argument) |
void | rtems_monitor_server_init (uint32_t) |
int | rtems_monitor_make_argv (char *, int *, char **) |
int | rtems_monitor_command_read (char *, int *, char **) |
void | rtems_monitor_command_usage (const rtems_monitor_command_entry_t *, const char *) |
void | rtems_monitor_help_cmd (int, char **, const rtems_monitor_command_arg_t *, bool) |
const rtems_monitor_command_entry_t * | rtems_monitor_command_lookup (const char *name) |
Looks for a command with the name name in the list of registered commands. | |
void | rtems_monitor_separator (void) |
uint32_t | rtems_monitor_pad (uint32_t dest_col, uint32_t curr_col) |
int | rtems_monitor_dump_decimal (uint32_t num) |
int | rtems_monitor_dump_hex (uint32_t num) |
int | rtems_monitor_dump_addr (const void *addr) |
int | rtems_monitor_dump_id (rtems_id id) |
int | rtems_monitor_dump_name (rtems_id id) |
int | rtems_monitor_dump_priority (rtems_task_priority priority) |
int | rtems_monitor_dump_state (States_Control state) |
int | rtems_monitor_dump_modes (rtems_mode modes) |
int | rtems_monitor_dump_attributes (rtems_attribute attributes) |
int | rtems_monitor_dump_events (rtems_event_set events) |
rtems_id | rtems_monitor_id_fixup (rtems_id, uint32_t, rtems_monitor_object_type_t) |
const rtems_monitor_object_info_t * | rtems_monitor_object_lookup (rtems_monitor_object_type_t type) |
rtems_id | rtems_monitor_object_canonical_get (rtems_monitor_object_type_t, rtems_id, void *, size_t *size_p) |
rtems_id | rtems_monitor_object_canonical_next (const rtems_monitor_object_info_t *, rtems_id, void *) |
const void * | rtems_monitor_object_next (void *, void *, rtems_id, rtems_id *) |
rtems_id | rtems_monitor_object_canonical (rtems_id, const void *) |
void | rtems_monitor_object_cmd (int, char **, const rtems_monitor_command_arg_t *, bool) |
const void * | rtems_monitor_manager_next (void *, void *, rtems_id *) |
void | rtems_monitor_config_canonical (rtems_monitor_config_t *, const void *) |
const void * | rtems_monitor_config_next (void *, rtems_monitor_config_t *, rtems_id *) |
void | rtems_monitor_config_dump_header (bool) |
int | rtems_monitor_config_dump (rtems_monitor_config_t *, bool verbose) |
void | rtems_monitor_init_task_canonical (rtems_monitor_init_task_t *, const void *) |
const void * | rtems_monitor_init_task_next (void *, rtems_monitor_init_task_t *, rtems_id *) |
void | rtems_monitor_init_task_dump_header (bool) |
void | rtems_monitor_init_task_dump (rtems_monitor_init_task_t *, bool verbose) |
void | rtems_monitor_extension_canonical (rtems_monitor_extension_t *, const void *) |
void | rtems_monitor_extension_dump_header (bool verbose) |
void | rtems_monitor_extension_dump (rtems_monitor_extension_t *, bool) |
void | rtems_monitor_task_canonical (rtems_monitor_task_t *, const void *) |
void | rtems_monitor_task_dump_header (bool verbose) |
void | rtems_monitor_task_dump (rtems_monitor_task_t *, bool) |
void | rtems_monitor_sema_canonical (rtems_monitor_sema_t *, const void *) |
void | rtems_monitor_sema_dump_header (bool verbose) |
void | rtems_monitor_sema_dump (rtems_monitor_sema_t *, bool) |
void | rtems_monitor_queue_canonical (rtems_monitor_queue_t *, const void *) |
void | rtems_monitor_queue_dump_header (bool verbose) |
void | rtems_monitor_queue_dump (rtems_monitor_queue_t *, bool) |
void | rtems_monitor_region_canonical (rtems_monitor_region_t *, const void *) |
void | rtems_monitor_region_dump_header (bool verbose) |
void | rtems_monitor_region_dump (rtems_monitor_region_t *, bool) |
void | rtems_monitor_part_canonical (rtems_monitor_part_t *, const void *) |
void | rtems_monitor_part_dump_header (bool verbose) |
void | rtems_monitor_part_dump (rtems_monitor_part_t *, bool) |
const void * | rtems_monitor_driver_next (void *, rtems_monitor_driver_t *, rtems_id *) |
void | rtems_monitor_driver_canonical (rtems_monitor_driver_t *, const void *) |
void | rtems_monitor_driver_dump_header (bool) |
void | rtems_monitor_driver_dump (rtems_monitor_driver_t *, bool) |
rtems_symbol_table_t * | rtems_symbol_table_create (void) |
void | rtems_symbol_table_destroy (rtems_symbol_table_t *table) |
rtems_symbol_t * | rtems_symbol_create (rtems_symbol_table_t *, const char *, uint32_t) |
rtems_symbol_t * | rtems_symbol_value_lookup (rtems_symbol_table_t *, uint32_t) |
const rtems_symbol_t * | rtems_symbol_value_lookup_exact (rtems_symbol_table_t *, uint32_t) |
rtems_symbol_t * | rtems_symbol_name_lookup (rtems_symbol_table_t *, const char *) |
const void * | rtems_monitor_symbol_next (void *object_info, rtems_monitor_symbol_t *, rtems_id *) |
void | rtems_monitor_symbol_canonical (rtems_monitor_symbol_t *, rtems_symbol_t *) |
void | rtems_monitor_symbol_canonical_by_name (rtems_monitor_symbol_t *, const char *) |
void | rtems_monitor_symbol_canonical_by_value (rtems_monitor_symbol_t *, void *) |
uint32_t | rtems_monitor_symbol_dump (rtems_monitor_symbol_t *, bool) |
void | rtems_monitor_symbol_cmd (int, char **, const rtems_monitor_command_arg_t *, bool) |
rtems_id | rtems_monitor_task_id |
uint32_t | rtems_monitor_node |
uint32_t | rtems_monitor_default_node |
rtems_symbol_table_t * | rtems_monitor_symbols |
void rtems_monitor_command_iterate | ( | rtems_monitor_per_command_routine | routine, |
void * | arg | ||
For each command the interation routine routine is called with the command entry and the user provided argument arg. It is guaranteed that the command name and function are not NULL.
const rtems_monitor_command_entry_t * rtems_monitor_command_lookup | ( | const char * | name | ) |
The parameter name must not be NULL.
Returns the corresponding command entry or NULL if no command is found.
