RTEMS 6.1-rc2
Macros | Typedefs | Functions | Variables
modes.h File Reference
This header file provides the task modes API of the Task Manager. More...
#include <stdint.h>
#include <rtems/score/cpu.h>
#define RTEMS_ALL_MODE_MASKS   0x0000ffff
 This task mode constant is a bit mask with all mode bits set.
#define RTEMS_ASR   0x00000000
 This task mode constant indicates that signal processing is disabled.
#define RTEMS_ASR_MASK   0x00000400
 This mode constant corresponds to the signal enable/disable bit.
#define RTEMS_CURRENT_MODE   0
 This task mode constant indicates that the current task mode of the executing task shall be returned by rtems_task_mode().
#define RTEMS_DEFAULT_MODES   0x00000000
 This task mode constant represents the default mode set.
#define RTEMS_INTERRUPT_MASK   CPU_MODES_INTERRUPT_MASK
 This task mode constant corresponds to the interrupt enable/disable bits.
#define RTEMS_INTERRUPT_LEVEL(_interrupt_level)    ( ( _interrupt_level ) & RTEMS_INTERRUPT_MASK )
 Maps the interrupt level to the associated processor-dependent task mode interrupt level.
#define RTEMS_NO_ASR   0x00000400
#define RTEMS_NO_PREEMPT   0x00000100
 This task mode constant indicates that preemption is disabled.
#define RTEMS_NO_TIMESLICE   0x00000000
 This task mode constant indicates that timeslicing is disabled.
#define RTEMS_PREEMPT   0x00000000
 This task mode constant indicates that preemption is enabled.
#define RTEMS_PREEMPT_MASK   0x00000100
 This task mode constant corresponds to the preemption enable/disable bit.
#define RTEMS_TIMESLICE   0x00000200
 This task mode constant indicates that timeslicing is enabled.
#define RTEMS_TIMESLICE_MASK   0x00000200
 This task mode constant corresponds to the timeslice enable/disable bit.
typedef uint32_t rtems_mode
 This type represents a Classic API task mode set.
rtems_mode rtems_interrupt_level_body (uint32_t level)
const uint32_t rtems_interrupt_mask
 This task mode constant has the same value as RTEMS_INTERRUPT_MASK.
