RTEMS 6.1-rc2
mips.h File Reference
Information to build RTEMS for a "no cpu" while in protected mode. More...
#include <rtems/mips/idtcpu.h>
#define MIPS_HAS_FPU   1
#define CPU_NAME   "MIPS"
#define MIPS_EXCEPTION_BASE   0
#define MIPS_EXCEPTION_INT   MIPS_EXCEPTION_BASE+0
#define MIPS_EXCEPTION_MOD   MIPS_EXCEPTION_BASE+1
#define MIPS_EXCEPTION_TLBL   MIPS_EXCEPTION_BASE+2
#define MIPS_EXCEPTION_TLBS   MIPS_EXCEPTION_BASE+3
#define MIPS_EXCEPTION_ADEL   MIPS_EXCEPTION_BASE+4
#define MIPS_EXCEPTION_ADES   MIPS_EXCEPTION_BASE+5
#define MIPS_EXCEPTION_IBE   MIPS_EXCEPTION_BASE+6
#define MIPS_EXCEPTION_DBE   MIPS_EXCEPTION_BASE+7
#define MIPS_EXCEPTION_SYSCALL   MIPS_EXCEPTION_BASE+8
#define MIPS_EXCEPTION_BREAK   MIPS_EXCEPTION_BASE+9
#define MIPS_EXCEPTION_RI   MIPS_EXCEPTION_BASE+10
#define MIPS_EXCEPTION_CPU   MIPS_EXCEPTION_BASE+11
#define MIPS_EXCEPTION_OVERFLOW   MIPS_EXCEPTION_BASE+12
#define MIPS_EXCEPTION_TRAP   MIPS_EXCEPTION_BASE+13
#define MIPS_EXCEPTION_VCEI   MIPS_EXCEPTION_BASE+14
#define MIPS_EXCEPTION_FPE   MIPS_EXCEPTION_BASE+15
#define MIPS_EXCEPTION_C2E   MIPS_EXCEPTION_BASE+16
#define MIPS_EXCEPTION_WATCH   MIPS_EXCEPTION_BASE+23
#define MIPS_EXCEPTION_VCED   MIPS_EXCEPTION_BASE+31
#define MIPS_INTERRUPT_BASE   MIPS_EXCEPTION_BASE+32
#define mips_get_sr(_x)
#define mips_set_sr(_x)
#define mips_get_cause(_x)
#define mips_set_cause(_x)
#define mips_get_dcic(_x)
#define mips_set_dcic(_x)
#define mips_get_bpcrm(_x, _y)
#define mips_set_bpcrm(_x, _y)
#define mips_get_bdarm(_x, _y)
#define mips_set_bdarm(_x, _y)
#define mips_get_fcr31(_x)
#define mips_set_fcr31(_x)
#define mips_enable_in_interrupt_mask(_mask)
#define mips_disable_in_interrupt_mask(_mask)
This file contains the information required to build RTEMS for a particular member of the "no cpu" family when executing in protected mode. It does this by setting variables to indicate which implementation dependent features are present in a particular member of the family.
