RTEMS 6.1-rc2
Data Structures | Typedefs | Enumerations | Functions | Variables
mcan.h File Reference
#include "chip.h"
#include <stdint.h>
struct  MailboxInfoTag
struct  MailBox8Tag
struct  MailBox12Tag
struct  MailBox16Tag
struct  MailBox20Tag
struct  MailBox24Tag
struct  MailBox32Tag
struct  MailBox48Tag
struct  MailBox64Tag
struct  MCan_MsgRamPntrsTag
struct  MCan_ConfigTag
typedef struct MailboxInfoTag MailboxInfoType
typedef struct MailBox8Tag Mailbox8Type
typedef struct MailBox12Tag Mailbox12Type
typedef struct MailBox16Tag Mailbox16Type
typedef struct MailBox20Tag Mailbox20Type
typedef struct MailBox24Tag Mailbox24Type
typedef struct MailBox32Tag Mailbox32ype
typedef struct MailBox48Tag Mailbox48Type
typedef struct MailBox64Tag Mailbox64Type
typedef struct MCan_MsgRamPntrsTag MCan_MsgRamPntrs
typedef struct MCan_ConfigTag MCan_ConfigType
enum  MCan_IdType { CAN_STD_ID = 0 , CAN_EXT_ID = 1 }
enum  MCan_DlcType {
  CAN_DLC_0 = 0 , CAN_DLC_1 = 1 , CAN_DLC_2 = 2 , CAN_DLC_3 = 3 ,
  CAN_DLC_4 = 4 , CAN_DLC_5 = 5 , CAN_DLC_6 = 6 , CAN_DLC_7 = 7 ,
  CAN_DLC_8 = 8 , CAN_DLC_12 = 9 , CAN_DLC_16 = 10 , CAN_DLC_20 = 11 ,
  CAN_DLC_24 = 12 , CAN_DLC_32 = 13 , CAN_DLC_48 = 14 , CAN_DLC_64 = 15
enum  MCan_FifoType { CAN_FIFO_0 = 0 , CAN_FIFO_1 = 1 }
enum  MCan_IntrLineType { CAN_INTR_LINE_0 = 0 , CAN_INTR_LINE_1 = 1 }
__STATIC_INLINE uint32_t MCAN_IsTxComplete (const MCan_ConfigType *mcanConfig)
__STATIC_INLINE void MCAN_ClearTxComplete (const MCan_ConfigType *mcanConfig)
__STATIC_INLINE uint32_t MCAN_IsMessageStoredToRxDedBuffer (const MCan_ConfigType *mcanConfig)
__STATIC_INLINE void MCAN_ClearMessageStoredToRxBuffer (const MCan_ConfigType *mcanConfig)
__STATIC_INLINE uint32_t MCAN_IsMessageStoredToRxFifo0 (const MCan_ConfigType *mcanConfig)
__STATIC_INLINE void MCAN_ClearMessageStoredToRxFifo0 (const MCan_ConfigType *mcanConfig)
__STATIC_INLINE uint32_t MCAN_IsMessageStoredToRxFifo1 (const MCan_ConfigType *mcanConfig)
__STATIC_INLINE void MCAN_ClearMessageStoredToRxFifo1 (const MCan_ConfigType *mcanConfig)
void MCAN_Init (const MCan_ConfigType *mcanConfig)
 Initializes the MCAN hardware for giving peripheral. Default: Mixed mode TX Buffer + FIFO.
void MCAN_InitFdEnable (const MCan_ConfigType *mcanConfig)
 Enables a FUTURE switch to FD mode (tx & rx payloads up to 64 bytes) but transmits WITHOUT bit rate switching INIT must be set - so this should be called between MCAN_Init() and MCAN_Enable()
void MCAN_InitFdBitRateSwitchEnable (const MCan_ConfigType *mcanConfig)
 Enables a FUTURE switch to FD mode (tx & rx payloads up to 64 bytes) and transmits WITH bit rate switching INIT must be set - so this should be called between MCAN_Init() and MCAN_Enable()
void MCAN_InitTxQueue (const MCan_ConfigType *mcanConfig)
 Initializes MCAN queue for TX INIT must be set - so this should be called between MCAN_Init() and MCAN_Enable()
void MCAN_InitLoopback (const MCan_ConfigType *mcanConfig)
 Initializes the MCAN in loop back mode. INIT must be set - so this should be called between MCAN_Init() and MCAN_Enable()
void MCAN_Enable (const MCan_ConfigType *mcanConfig)
 Enable MCAN peripheral. INIT must be set - so this should be called between MCAN_Init()
void MCAN_RequestIso11898_1 (const MCan_ConfigType *mcanConfig)
 Requests switch to Iso11898-1 (standard / classic) mode (tx & rx payloads up to 8 bytes).
void MCAN_RequestFd (const MCan_ConfigType *mcanConfig)
 Requests switch to FD mode (tx & rx payloads up to 64 bytes) but transmits WITHOUT bit rate switching. requested mode should have been enabled at initialization.
void MCAN_RequestFdBitRateSwitch (const MCan_ConfigType *mcanConfig)
 Request switch to FD mode (tx & rx payloads up to 64 bytes) and transmits WITH bit rate switching. requested mode should have been enabled at initialization.
void MCAN_LoopbackOn (const MCan_ConfigType *mcanConfig)
 Switch on loop back mode. TEST must be set in MCAN_CCCR - e.g. by a prior call to MCAN_InitLoopback()
void MCAN_LoopbackOff (const MCan_ConfigType *mcanConfig)
 Switch off loop back mode.
void MCAN_IEnableMessageStoredToRxDedBuffer (const MCan_ConfigType *mcanConfig, MCan_IntrLineType line)
 Enable message line and message stored to Dedicated Receive Buffer Interrupt Line.
uint8_t * MCAN_ConfigTxDedBuffer (const MCan_ConfigType *mcanConfig, uint8_t buffer, uint32_t id, MCan_IdType idType, MCan_DlcType dlc)
 Configures a Dedicated TX Buffer.
void MCAN_SendTxDedBuffer (const MCan_ConfigType *mcanConfig, uint8_t buffer)
 Send Tx buffer.
uint32_t MCAN_AddToTxFifoQ (const MCan_ConfigType *mcanConfig, uint32_t id, MCan_IdType idType, MCan_DlcType dlc, uint8_t *data)
 Adds Message to TX Fifo / Queue.
uint8_t MCAN_IsBufferTxd (const MCan_ConfigType *mcanConfig, uint8_t buffer)
 Check if data transmitted from buffer/fifo/queue.
void MCAN_ConfigRxBufferFilter (const MCan_ConfigType *mcanConfig, uint32_t buffer, uint32_t filter, uint32_t id, MCan_IdType idType)
 Configure RX Buffer Filter ID must match exactly for a RX Buffer Filter.
void MCAN_ConfigRxClassicFilter (const MCan_ConfigType *mcanConfig, MCan_FifoType fifo, uint8_t filter, uint32_t id, MCan_IdType idType, uint32_t mask)
 Configure Classic Filter Classic Filters direct accepted messages to a FIFO & include both a ID and a ID mask.
uint8_t MCAN_IsNewDataInRxDedBuffer (const MCan_ConfigType *mcanConfig, uint8_t buffer)
 check if data received into buffer
void MCAN_GetRxDedBuffer (const MCan_ConfigType *mcanConfig, uint8_t buffer, Mailbox64Type *pRxMailbox)
 Get Rx buffer.
uint32_t MCAN_GetRxFifoBuffer (const MCan_ConfigType *mcanConfig, MCan_FifoType fifo, Mailbox64Type *pRxMailbox)
 Get from the receive FIFO and place in a application mailbox.
const MCan_ConfigType mcan0Config
const MCan_ConfigType mcan1Config
Purpose
Interface for configuring and using Timer Counter (TC) peripherals.
Usage
  1. Optionally, use TC_FindMckDivisor() to let the program find the best TCCLKS field value automatically.
  2. Configure a Timer Counter in the desired mode using TC_Configure().
  3. Start or stop the timer clock using TC_Start() and TC_Stop().
