RTEMS 6.1-rc2
#define MAILBOX_ADDRESS(address)   (0xFFFC & (address))
#define CAN_CLK_FREQ_HZ   MCAN_PROG_CLK_FREQ_HZ
#define MCAN0_TSEG1   (MCAN0_PROP_SEG + MCAN0_PHASE_SEG1)
#define MCAN0_TSEG2   (MCAN0_PHASE_SEG2)
#define MCAN0_BRP
#define MCAN0_SJW   (MCAN0_SYNC_JUMP - 1)
#define MCAN0_FTSEG1   (MCAN0_FAST_PROP_SEG + MCAN0_FAST_PHASE_SEG1)
#define MCAN0_FTSEG2   (MCAN0_FAST_PHASE_SEG2)
#define MCAN0_FBRP
#define MCAN0_FSJW   (MCAN0_FAST_SYNC_JUMP - 1)
#define MCAN0_STD_FLTS_WRDS   (MCAN0_NMBR_STD_FLTS)
#define MCAN0_EXT_FLTS_WRDS   (MCAN0_NMBR_EXT_FLTS * 2)
#define MCAN0_RX_FIFO0_WRDS
#define MCAN0_RX_FIFO1_WRDS
#define MCAN0_RX_DED_BUFS_WRDS
#define MCAN0_TX_EVT_FIFO_WRDS   (MCAN0_NMBR_TX_EVT_FIFO_ELMTS * 2)
#define MCAN0_TX_DED_BUF_WRDS
#define MCAN0_TX_FIFO_Q_WRDS
#define MCAN1_TSEG1   (MCAN1_PROP_SEG + MCAN1_PHASE_SEG1)
#define MCAN1_TSEG2   (MCAN1_PHASE_SEG2)
#define MCAN1_BRP
#define MCAN1_SJW   (MCAN1_SYNC_JUMP - 1)
#define MCAN1_FTSEG1   (MCAN1_FAST_PROP_SEG + MCAN1_FAST_PHASE_SEG1)
#define MCAN1_FTSEG2   (MCAN1_FAST_PHASE_SEG2)
#define MCAN1_FBRP
#define MCAN1_FSJW   (MCAN1_FAST_SYNC_JUMP - 1)
#define MCAN1_STD_FLTS_WRDS   (MCAN1_NMBR_STD_FLTS)
#define MCAN1_EXT_FLTS_WRDS   (MCAN1_NMBR_EXT_FLTS * 2)
#define MCAN1_RX_FIFO0_WRDS
#define MCAN1_RX_FIFO1_WRDS
#define MCAN1_RX_DED_BUFS_WRDS
#define MCAN1_TX_EVT_FIFO_WRDS   (MCAN1_NMBR_TX_EVT_FIFO_ELMTS * 2)
#define MCAN1_TX_DED_BUF_WRDS
#define MCAN1_TX_FIFO_Q_WRDS
#define CAN_11_BIT_ID_MASK   (0x7FF)
#define CAN_29_BIT_ID_MASK   (0x1FFFFFFF)
#define ELMT_SIZE_MASK   (0x1F)
#define BUFFER_XTD_MASK   (0x40000000)
#define BUFFER_EXT_ID_MASK   (0x1FFFFFFF)
#define BUFFER_STD_ID_MASK   (0x1FFC0000)
#define BUFFER_DLC_MASK   (0x000F0000)
#define BUFFER_RXTS_MASK   (0x0000FFFF)
#define STD_FILT_SFT_MASK   (3U << 30)
#define STD_FILT_SFT_RANGE   (0U << 30)
#define STD_FILT_SFT_DUAL   (1U << 30)
#define STD_FILT_SFT_CLASSIC   (2U << 30)
#define STD_FILT_SFEC_MASK   (7U << 27)
#define STD_FILT_SFEC_DISABLE   (0U << 27)
#define STD_FILT_SFEC_FIFO0   (1U << 27)
#define STD_FILT_SFEC_FIFO1   (2U << 27)
#define STD_FILT_SFEC_REJECT   (3U << 27)
#define STD_FILT_SFEC_PRIORITY   (4U << 27)
#define STD_FILT_SFEC_PRIORITY_FIFO0   (5U << 27)
#define STD_FILT_SFEC_PRIORITY_FIFO1   (6U << 27)
#define STD_FILT_SFEC_BUFFER   (7U << 27)
#define STD_FILT_SFID1_MASK   (0x03FFU << 16)
#define STD_FILT_SFID2_MASK   (0x3FFU << 0)
#define STD_FILT_SFID2_RX_BUFFER   (0U << 9)
#define STD_FILT_SFID2_DEBUG_A   (1U << 9)
#define STD_FILT_SFID2_DEBUG_B   (2U << 9)
#define STD_FILT_SFID2_DEBUG_C   (3U << 9)
#define STD_FILT_SFID2_BUFFER(nmbr)   (nmbr & 0x3F)
#define EXT_FILT_EFEC_MASK   (7U << 29)
#define EXT_FILT_EFEC_DISABLE   (0U << 29)
#define EXT_FILT_EFEC_FIFO0   (1U << 29)
#define EXT_FILT_EFEC_FIFO1   (2U << 29)
#define EXT_FILT_EFEC_REJECT   (3U << 29)
#define EXT_FILT_EFEC_PRIORITY   (4U << 29)
#define EXT_FILT_EFEC_PRIORITY_FIFO0   (5U << 29)
#define EXT_FILT_EFEC_PRIORITY_FIFO1   (6U << 29)
#define EXT_FILT_EFEC_BUFFER   (7U << 29)
#define EXT_FILT_EFID1_MASK   (0x1FFFFFFF)
#define EXT_FILT_EFT_MASK   (3U << 30)
#define EXT_FILT_EFT_RANGE   (0U << 30)
#define EXT_FILT_EFT_DUAL   (1U << 30)
#define EXT_FILT_EFT_CLASSIC   (2U << 30)
#define EXT_FILT_EFT_RANGE_NO_XIDAM   (3U << 30)
#define EXT_FILT_EFID2_MASK   (0x1FFFFFFF)
#define EXT_FILT_EFID2_RX_BUFFER   (0U << 9)
#define EXT_FILT_EFID2_DEBUG_A   (1U << 9)
#define EXT_FILT_EFID2_DEBUG_B   (2U << 9)
#define EXT_FILT_EFID2_DEBUG_C   (3U << 9)
#define EXT_FILT_EFID2_BUFFER(nmbr)   (nmbr & 0x3F)
void MCAN_Init (const MCan_ConfigType *mcanConfig)
 Initializes the MCAN hardware for giving peripheral. Default: Mixed mode TX Buffer + FIFO.
void MCAN_InitFdEnable (const MCan_ConfigType *mcanConfig)
 Enables a FUTURE switch to FD mode (tx & rx payloads up to 64 bytes) but transmits WITHOUT bit rate switching INIT must be set - so this should be called between MCAN_Init() and MCAN_Enable()
void MCAN_InitFdBitRateSwitchEnable (const MCan_ConfigType *mcanConfig)
 Enables a FUTURE switch to FD mode (tx & rx payloads up to 64 bytes) and transmits WITH bit rate switching INIT must be set - so this should be called between MCAN_Init() and MCAN_Enable()
void MCAN_InitLoopback (const MCan_ConfigType *mcanConfig)
 Initializes the MCAN in loop back mode. INIT must be set - so this should be called between MCAN_Init() and MCAN_Enable()
void MCAN_InitTxQueue (const MCan_ConfigType *mcanConfig)
 Initializes MCAN queue for TX INIT must be set - so this should be called between MCAN_Init() and MCAN_Enable()
void MCAN_Enable (const MCan_ConfigType *mcanConfig)
 Enable MCAN peripheral. INIT must be set - so this should be called between MCAN_Init()
void MCAN_RequestIso11898_1 (const MCan_ConfigType *mcanConfig)
 Requests switch to Iso11898-1 (standard / classic) mode (tx & rx payloads up to 8 bytes).
void MCAN_RequestFd (const MCan_ConfigType *mcanConfig)
 Requests switch to FD mode (tx & rx payloads up to 64 bytes) but transmits WITHOUT bit rate switching. requested mode should have been enabled at initialization.
void MCAN_RequestFdBitRateSwitch (const MCan_ConfigType *mcanConfig)
 Request switch to FD mode (tx & rx payloads up to 64 bytes) and transmits WITH bit rate switching. requested mode should have been enabled at initialization.
void MCAN_LoopbackOn (const MCan_ConfigType *mcanConfig)
 Switch on loop back mode. TEST must be set in MCAN_CCCR - e.g. by a prior call to MCAN_InitLoopback()
void MCAN_LoopbackOff (const MCan_ConfigType *mcanConfig)
 Switch off loop back mode.
void MCAN_IEnableMessageStoredToRxDedBuffer (const MCan_ConfigType *mcanConfig, MCan_IntrLineType line)
 Enable message line and message stored to Dedicated Receive Buffer Interrupt Line.
uint8_t * MCAN_ConfigTxDedBuffer (const MCan_ConfigType *mcanConfig, uint8_t buffer, uint32_t id, MCan_IdType idType, MCan_DlcType dlc)
 Configures a Dedicated TX Buffer.
void MCAN_SendTxDedBuffer (const MCan_ConfigType *mcanConfig, uint8_t buffer)
 Send Tx buffer.
uint32_t MCAN_AddToTxFifoQ (const MCan_ConfigType *mcanConfig, uint32_t id, MCan_IdType idType, MCan_DlcType dlc, uint8_t *data)
 Adds Message to TX Fifo / Queue.
uint8_t MCAN_IsBufferTxd (const MCan_ConfigType *mcanConfig, uint8_t buffer)
 Check if data transmitted from buffer/fifo/queue.
void MCAN_ConfigRxBufferFilter (const MCan_ConfigType *mcanConfig, uint32_t buffer, uint32_t filter, uint32_t id, MCan_IdType idType)
 Configure RX Buffer Filter ID must match exactly for a RX Buffer Filter.
void MCAN_ConfigRxClassicFilter (const MCan_ConfigType *mcanConfig, MCan_FifoType fifo, uint8_t filter, uint32_t id, MCan_IdType idType, uint32_t mask)
 Configure Classic Filter Classic Filters direct accepted messages to a FIFO & include both a ID and a ID mask.
uint8_t MCAN_IsNewDataInRxDedBuffer (const MCan_ConfigType *mcanConfig, uint8_t buffer)
 check if data received into buffer
void MCAN_GetRxDedBuffer (const MCan_ConfigType *mcanConfig, uint8_t buffer, Mailbox64Type *pRxMailbox)
 Get Rx buffer.
uint32_t MCAN_GetRxFifoBuffer (const MCan_ConfigType *mcanConfig, MCan_FifoType fifo, Mailbox64Type *pRxMailbox)
 Get from the receive FIFO and place in a application mailbox.
const MCan_ConfigType mcan0Config
const MCan_ConfigType mcan1Config
◆ MCAN0_BRP
#define MCAN0_BRP
Value:
((uint32_t) (((float) CAN_CLK_FREQ_HZ / \
((float)(MCAN0_TSEG1 + MCAN0_TSEG2 + 3) *\
(float) MCAN0_BIT_RATE_BPS)) - 1))
◆ MCAN0_FBRP
#define MCAN0_FBRP
Value:
((float)(MCAN0_FTSEG1 + MCAN0_FTSEG2 + 3) * \
(float) MCAN0_FAST_BIT_RATE_BPS)) - 1))
◆ MCAN0_RX_DED_BUFS_WRDS
Value:
(MCAN0_NMBR_RX_DED_BUF_ELMTS * \
((MCAN0_RX_BUF_ELMT_SZ/4) + 2))
◆ MCAN0_RX_FIFO0_WRDS
Value:
(MCAN0_NMBR_RX_FIFO0_ELMTS * \
((MCAN0_RX_FIFO0_ELMT_SZ/4) + 2))
◆ MCAN0_RX_FIFO1_WRDS
Value:
(MCAN0_NMBR_RX_FIFO1_ELMTS *\
((MCAN0_RX_FIFO1_ELMT_SZ/4) + 2))
◆ MCAN0_TX_DED_BUF_WRDS
Value:
(MCAN0_NMBR_TX_DED_BUF_ELMTS * \
((MCAN0_TX_BUF_ELMT_SZ/4) + 2))
◆ MCAN0_TX_FIFO_Q_WRDS
Value:
(MCAN0_NMBR_TX_FIFO_Q_ELMTS *\
◆ MCAN1_BRP
#define MCAN1_BRP
Value:
((float)(MCAN1_TSEG1 + MCAN1_TSEG2 + 3) *\
(float) MCAN1_BIT_RATE_BPS)) - 1))
◆ MCAN1_FBRP
#define MCAN1_FBRP
Value:
((uint32_t) (((float) CAN_CLK_FREQ_HZ /\
((float)(MCAN1_FTSEG1 + MCAN1_FTSEG2 + 3) *\
(float) MCAN1_FAST_BIT_RATE_BPS)) - 1))
◆ MCAN1_RX_DED_BUFS_WRDS
Value:
(MCAN1_NMBR_RX_DED_BUF_ELMTS * \
((MCAN1_RX_BUF_ELMT_SZ/4) + 2))
◆ MCAN1_RX_FIFO0_WRDS
Value:
(MCAN1_NMBR_RX_FIFO0_ELMTS * \
((MCAN1_RX_FIFO0_ELMT_SZ/4) + 2))
◆ MCAN1_RX_FIFO1_WRDS
Value:
(MCAN1_NMBR_RX_FIFO1_ELMTS *\
((MCAN1_RX_FIFO1_ELMT_SZ/4) + 2))
◆ MCAN1_TX_DED_BUF_WRDS
Value:
(MCAN1_NMBR_TX_DED_BUF_ELMTS * \
((MCAN1_TX_BUF_ELMT_SZ/4) + 2))
◆ MCAN1_TX_FIFO_Q_WRDS
Value:
(MCAN1_NMBR_TX_FIFO_Q_ELMTS * \
◆ MCAN_AddToTxFifoQ()
uint32_t MCAN_AddToTxFifoQ ( const MCan_ConfigType mcanConfig,
uint32_t  id,
MCan_IdType  idType,
MCan_DlcType  dlc,
uint8_t *  data
Parameters
mcanConfigPointer to a MCAN instance.
idMessage ID.
idTypeType of ID
dlcType of dlc.
dataPointer to data.
◆ MCAN_ConfigRxBufferFilter()
void MCAN_ConfigRxBufferFilter ( const MCan_ConfigType mcanConfig,
uint32_t  buffer,
uint32_t  filter,
uint32_t  id,
MCan_IdType  idType
Parameters
bufferPointer to data buffer.
filterdata of filter.
idTypeType of ID
◆ MCAN_ConfigRxClassicFilter()
void MCAN_ConfigRxClassicFilter ( const MCan_ConfigType mcanConfig,
MCan_FifoType  fifo,
uint8_t  filter,
uint32_t  id,
MCan_IdType  idType,
uint32_t  mask
Parameters
fifofifo Number.
idTypeType of ID
maskMask to be match
◆ MCAN_ConfigTxDedBuffer()
uint8_t * MCAN_ConfigTxDedBuffer ( const MCan_ConfigType mcanConfig,
uint8_t  buffer,
uint32_t  id,
MCan_IdType  idType,
MCan_DlcType  dlc
Parameters
bufferPointer to buffer.
idMessage ID.
idTypeType of ID
dlcType of dlc.
◆ MCAN_Enable()
void MCAN_Enable ( const MCan_ConfigType mcanConfig)
Parameters
◆ MCAN_GetRxDedBuffer()
void MCAN_GetRxDedBuffer ( const MCan_ConfigType mcanConfig,
uint8_t  buffer,
Mailbox64Type pRxMailbox
Get Rx buffer.
Parameters
pRxMailboxPointer to rx Mailbox.
◆ MCAN_GetRxFifoBuffer()
uint32_t MCAN_GetRxFifoBuffer ( const MCan_ConfigType mcanConfig,
MCan_FifoType  fifo,
Parameters
fifoFifo Number
Returns
: # of fifo entries at the start of the function 0 -> FIFO was empty at start 1 -> FIFO had 1 entry at start, but is empty at finish 2 -> FIFO had 2 entries at start, has 1 entry at finish
◆ MCAN_IEnableMessageStoredToRxDedBuffer()
void MCAN_IEnableMessageStoredToRxDedBuffer ( const MCan_ConfigType mcanConfig,
Parameters
lineMessage line.
◆ MCAN_Init()
void MCAN_Init ( const MCan_ConfigType mcanConfig)
Parameters
◆ MCAN_InitFdBitRateSwitchEnable()
void MCAN_InitFdBitRateSwitchEnable ( const MCan_ConfigType mcanConfig)
Parameters
◆ MCAN_InitFdEnable()
void MCAN_InitFdEnable ( const MCan_ConfigType mcanConfig)
Parameters
◆ MCAN_InitLoopback()
void MCAN_InitLoopback ( const MCan_ConfigType mcanConfig)
Parameters
◆ MCAN_InitTxQueue()
void MCAN_InitTxQueue ( const MCan_ConfigType mcanConfig)
Parameters
◆ MCAN_IsBufferTxd()
uint8_t MCAN_IsBufferTxd ( const MCan_ConfigType mcanConfig,
uint8_t  buffer
Parameters
◆ MCAN_IsNewDataInRxDedBuffer()
uint8_t MCAN_IsNewDataInRxDedBuffer ( const MCan_ConfigType mcanConfig,
uint8_t  buffer
Parameters
◆ MCAN_LoopbackOff()
void MCAN_LoopbackOff ( const MCan_ConfigType mcanConfig)
Parameters
◆ MCAN_LoopbackOn()
void MCAN_LoopbackOn ( const MCan_ConfigType mcanConfig)
Parameters
◆ MCAN_RequestFd()
void MCAN_RequestFd ( const MCan_ConfigType mcanConfig)
Parameters
◆ MCAN_RequestFdBitRateSwitch()
void MCAN_RequestFdBitRateSwitch ( const MCan_ConfigType mcanConfig)
Parameters
◆ MCAN_RequestIso11898_1()
void MCAN_RequestIso11898_1 ( const MCan_ConfigType mcanConfig)
Parameters
◆ MCAN_SendTxDedBuffer()
void MCAN_SendTxDedBuffer ( const MCan_ConfigType mcanConfig,
uint8_t  buffer
Send Tx buffer.
Parameters
