RTEMS 6.1-rc2
Enumerations | Functions
init_system.c File Reference
This source file contains parts of the system initialization. More...
#include <stdint.h>
#include <stdbool.h>
#include <bsp/tms570.h>
#include <bsp/tms570-pinmux.h>
#include <bsp/tms570_selftest.h>
#include <bsp/tms570_hwinit.h>
enum  tms570_flash_power_modes { TMS570_FLASH_SYS_SLEEP = 0U , TMS570_FLASH_SYS_STANDBY = 1U , TMS570_FLASH_SYS_ACTIVE = 3U }
void tms570_trim_lpo_init (void)
 Adjust Low-Frequency (LPO) oscilator (HCG:trimLPO)
void tms570_flash_init (void)
 Setup Flash memory parameters and timing (HCG:setupFlash)
void tms570_periph_init (void)
 Power-up all peripherals and enable their clocks (HCG:periphInit)
void tms570_system_hw_init (void)
 TMS570 system hardware initialization (HCG:systemInit)
◆ tms570_flash_power_modes
Alias for flash bank power mode sleep
Alias for flash bank power mode standby
Alias for flash bank power mode active
◆ tms570_flash_init()
void tms570_flash_init ( void  )
  • Setup flash read mode, address wait states and data wait states
  • Setup flash access wait states for bank 7
  • Disable write access to flash state machine registers
  • Setup flash bank power modes
◆ tms570_periph_init()
void tms570_periph_init ( void  )
  • Disable Peripherals before peripheral powerup
  • Release peripherals from reset and enable clocks to all peripherals
  • Power-up all peripherals
  • Enable Peripherals
◆ tms570_system_hw_init()
void tms570_system_hw_init ( void  )
  • Set up flash address and data wait states based on the target CPU clock frequency The number of address and data wait states for the target CPU clock frequency are specified in the specific part's datasheet.
  • Configure the LPO such that HF LPO is as close to 10MHz as possible
  • Wait for PLLs to start up and map clock domains to desired clock sources
  • set ECLK pins functional mode
  • set ECLK pins default output value
  • set ECLK pins output direction
  • set ECLK pins open drain enable
  • set ECLK pins pullup/pulldown enable
  • set ECLK pins pullup/pulldown select
  • Setup ECLK
◆ tms570_trim_lpo_init()
void tms570_trim_lpo_init ( void  )
Initialize Lpo:
Load TRIM values from OTP if present else load user defined values
