RTEMS 6.1-rc2
Data Structures | Enumerator | Variables
Wdog
struct  _wdog_work_mode
 Defines WDOG work mode. More...
struct  _wdog_config
 Describes WDOG configuration structure. More...
bool _wdog_work_mode::enableWait
bool _wdog_work_mode::enableStop
bool _wdog_work_mode::enableDebug
bool _wdog_config::enableWdog
wdog_work_mode_t _wdog_config::workMode
bool _wdog_config::enableInterrupt
uint16_t _wdog_config::timeoutValue
uint16_t _wdog_config::interruptTimeValue
bool _wdog_config::softwareResetExtension
bool _wdog_config::enablePowerDown
bool _wdog_config::enableTimeOutAssert
Refresh sequence
enum  _wdog_interrupt_enable { kWDOG_InterruptEnable = WDOG_WICR_WIE_MASK }
 WDOG interrupt configuration structure, default settings all disabled. More...
enum  _wdog_status_flags {
  kWDOG_RunningFlag = WDOG_WCR_WDE_MASK , kWDOG_PowerOnResetFlag = WDOG_WRSR_POR_MASK , kWDOG_TimeoutResetFlag = WDOG_WRSR_TOUT_MASK , kWDOG_SoftwareResetFlag = WDOG_WRSR_SFTW_MASK ,
  kWDOG_InterruptFlag = WDOG_WICR_WTIS_MASK
 WDOG status flags. More...
typedef struct _wdog_work_mode wdog_work_mode_t
typedef struct _wdog_config wdog_config_t
#define WDOG_REFRESH_KEY   (0xAAAA5555U)
WDOG Initialization and De-initialization.
void WDOG_GetDefaultConfig (wdog_config_t *config)
 Initializes the WDOG configuration structure.
void WDOG_Init (WDOG_Type *base, const wdog_config_t *config)
 Initializes the WDOG.
void WDOG_Deinit (WDOG_Type *base)
 Shuts down the WDOG.
uint16_t WDOG_GetStatusFlags (WDOG_Type *base)
 Gets the WDOG all reset status flags.
void WDOG_ClearInterruptStatus (WDOG_Type *base, uint16_t mask)
 Clears the WDOG flag.
void WDOG_Refresh (WDOG_Type *base)
 Refreshes the WDOG timer.
Driver version
#define FSL_WDOG_DRIVER_VERSION   (MAKE_VERSION(2, 1, 1))
 Defines WDOG driver version.
◆ _wdog_interrupt_enable
This structure contains the settings for all of the WDOG interrupt configurations.
WDOG timeout generates an interrupt before reset
◆ _wdog_status_flags
WDOG status flags.
This structure contains the WDOG status flags for use in the WDOG functions.
kWDOG_RunningFlag
Running flag, set when WDOG is enabled
Power On flag, set when reset is the result of a powerOnReset
Timeout flag, set when reset is the result of a timeout
Software flag, set when reset is the result of a software
kWDOG_InterruptFlag
interrupt flag,whether interrupt has occurred or not
◆ WDOG_ClearInterruptStatus()
void WDOG_ClearInterruptStatus ( WDOG_Type base,
uint16_t  mask
This function clears the WDOG status flag.
This is an example for clearing the interrupt flag.
WDOG_ClearStatusFlags(wdog_base,KWDOG_InterruptFlag);
Parameters
baseWDOG peripheral base address
maskThe status flags to clear. The parameter could be any combination of the following values. kWDOG_TimeoutFlag
brief Clears the WDOG flag.
This is an example for clearing the interrupt flag. code WDOG_ClearStatusFlags(wdog_base,KWDOG_InterruptFlag); endcode param base WDOG peripheral base address param mask The status flags to clear. The parameter could be any combination of the following values. kWDOG_TimeoutFlag
◆ WDOG_Deinit()
void WDOG_Deinit ( WDOG_Type base)
This function shuts down the WDOG. Watchdog Enable bit is a write one once only bit. It is not possible to clear this bit by a software write, once the bit is set. This bit(WDE) can be set/reset only in debug mode(exception).
brief Shuts down the WDOG.
◆ WDOG_GetDefaultConfig()
void WDOG_GetDefaultConfig ( wdog_config_t config)
This function initializes the WDOG configuration structure to default values. The default values are as follows.
wdogConfig->enableWdog = true;
wdogConfig->workMode.enableWait = true;
wdogConfig->workMode.enableStop = false;
wdogConfig->workMode.enableDebug = false;
wdogConfig->enableInterrupt = false;
wdogConfig->enablePowerdown = false;
wdogConfig->resetExtension = flase;
wdogConfig->timeoutValue = 0xFFU;
wdogConfig->interruptTimeValue = 0x04u;
Parameters
configPointer to the WDOG configuration structure.
See also
wdog_config_t
brief Initializes the WDOG configuration structure.
This function initializes the WDOG configuration structure to default values. The default values are as follows. code wdogConfig->enableWdog = true; wdogConfig->workMode.enableWait = true; wdogConfig->workMode.enableStop = false; wdogConfig->workMode.enableDebug = false; wdogConfig->enableInterrupt = false; wdogConfig->enablePowerdown = false; wdogConfig->resetExtension = flase; wdogConfig->timeoutValue = 0xFFU; wdogConfig->interruptTimeValue = 0x04u; endcode
param config Pointer to the WDOG configuration structure. see wdog_config_t
◆ WDOG_GetStatusFlags()
uint16_t WDOG_GetStatusFlags ( WDOG_Type base)
This function gets all reset status flags.
uint16_t status;
status = WDOG_GetStatusFlags (wdog_base);
uint16_t WDOG_GetStatusFlags(WDOG_Type *base)
Definition: fsl_wdog.c:162
Parameters
Returns
State of the status flag: asserted (true) or not-asserted (false).
See also
_wdog_status_flags
  • true: a related status flag has been set.
  • false: a related status flag is not set.
brief Gets the WDOG all reset status flags.
code uint16_t status; status = WDOG_GetStatusFlags (wdog_base); endcode param base WDOG peripheral base address return State of the status flag: asserted (true) or not-asserted (false).see _wdog_status_flags
◆ WDOG_Init()
void WDOG_Init ( WDOG_Type base,
const wdog_config_t config
This function initializes the WDOG. When called, the WDOG runs according to the configuration.
This is an example.
config.timeoutValue = 0xffU;
config->interruptTimeValue = 0x04u;
WDOG_Init(wdog_base,&config);
void WDOG_Init(WDOG_Type *base, const wdog_config_t *config)
Definition: fsl_wdog.c:104
void WDOG_GetDefaultConfig(wdog_config_t *config)
Definition: fsl_wdog.c:68
Definition: fsl_wdog.h:41
Definition: deflate.c:114
Parameters
configThe configuration of WDOG
brief Initializes the WDOG.
This is an example. code wdog_config_t config; WDOG_GetDefaultConfig(&config); config.timeoutValue = 0xffU; config->interruptTimeValue = 0x04u; WDOG_Init(wdog_base,&config); endcode
param base WDOG peripheral base address param config The configuration of WDOG
◆ WDOG_Refresh()
void WDOG_Refresh ( WDOG_Type base)
This function feeds the WDOG. This function should be called before the WDOG timer is in timeout. Otherwise, a reset is asserted.
Parameters
brief Refreshes the WDOG timer.
Variable Documentation
◆ enableDebug
continue or suspend WDOG in debug mode
◆ enableInterrupt
Enables or disables WDOG interrupt
◆ enablePowerDown
power down enable bit
◆ enableStop
continue or suspend WDOG in stop mode
◆ enableTimeOutAssert
Enable WDOG_B timeout assertion.
◆ enableWait
continue or suspend WDOG in wait mode
◆ enableWdog
◆ interruptTimeValue
Interrupt count timeout value
◆ softwareResetExtension
software reset extension
◆ timeoutValue
Timeout value
◆ workMode
Configures WDOG work mode in debug stop and wait mode
