#define | XUARTLITE_L_H /* by using protection macros */ |
#define | XPAR_XUARTLITE_USE_DCR_BRIDGE 0 |
#define | XUL_RX_FIFO_OFFSET 0 /* receive FIFO, read only */ |
#define | XUL_TX_FIFO_OFFSET 4 /* transmit FIFO, write only */ |
#define | XUL_STATUS_REG_OFFSET 8 /* status register, read only */ |
#define | XUL_CONTROL_REG_OFFSET 12 /* control reg, write only */ |
#define | XUL_CR_ENABLE_INTR 0x10 /* enable interrupt */ |
#define | XUL_CR_FIFO_RX_RESET 0x02 /* reset receive FIFO */ |
#define | XUL_CR_FIFO_TX_RESET 0x01 /* reset transmit FIFO */ |
#define | XUL_SR_PARITY_ERROR 0x80 |
#define | XUL_SR_FRAMING_ERROR 0x40 |
#define | XUL_SR_OVERRUN_ERROR 0x20 |
#define | XUL_SR_INTR_ENABLED 0x10 /* interrupt enabled */ |
#define | XUL_SR_TX_FIFO_FULL 0x08 /* transmit FIFO full */ |
#define | XUL_SR_TX_FIFO_EMPTY 0x04 /* transmit FIFO empty */ |
#define | XUL_SR_RX_FIFO_FULL 0x02 /* receive FIFO full */ |
#define | XUL_SR_RX_FIFO_VALID_DATA 0x01 /* data in receive FIFO */ |
#define | XUL_FIFO_SIZE 16 |
#define | XUL_STOP_BITS 1 |
#define | XUL_PARITY_NONE 0 |
#define | XUL_PARITY_ODD 1 |
#define | XUL_PARITY_EVEN 2 |
#define | XUartLite_In32 Xil_In32 |
#define | XUartLite_Out32 Xil_Out32 |
#define | XUartLite_WriteReg(BaseAddress, RegOffset, Data) XUartLite_Out32((BaseAddress) + (RegOffset), (u32)(Data)) |
#define | XUartLite_ReadReg(BaseAddress, RegOffset) XUartLite_In32((BaseAddress) + (RegOffset)) |
#define | XUartLite_SetControlReg(BaseAddress, Mask) XUartLite_WriteReg((BaseAddress), XUL_CONTROL_REG_OFFSET, (Mask)) |
#define | XUartLite_GetStatusReg(BaseAddress) XUartLite_ReadReg((BaseAddress), XUL_STATUS_REG_OFFSET) |
#define | XUartLite_IsReceiveEmpty(BaseAddress) |
#define | XUartLite_IsTransmitFull(BaseAddress) |
#define | XUartLite_IsIntrEnabled(BaseAddress) |
#define | XUartLite_EnableIntr(BaseAddress) XUartLite_SetControlReg((BaseAddress), XUL_CR_ENABLE_INTR) |
#define | XUartLite_DisableIntr(BaseAddress) XUartLite_SetControlReg((BaseAddress), 0) |
This header file contains identifiers and low-level driver functions (or macros) that can be used to access the device. High-level driver functions are defined in xuartlite.h.
MODIFICATION HISTORY:
Ver Who Date Changes
1.00b rpm 04/25/02 First release
1.00b rpm 07/07/03 Removed references to XUartLite_GetControlReg macro
since the control register is write-only
1.12a mta 03/21/07 Updated to new coding style
1.13a sv 01/21/08 Updated driver to support access through DCR bus
2.00a ktn 10/20/09 Updated to use HAL Processor APIs. The macros have been
renamed to remove _m from the name.
3.2 sk 11/10/15 Used UINTPTR instead of u32 for Baseaddress CR# 867425.
Changed the prototypes of XUartLite_SendByte,
XUartLite_RecvByte APIs.
This file contains low-level driver functions that can be used to access the device. The user should refer to the hardware device specification for more details of the device operation.
1.12a rpm 07/16/07 Fixed arg type for RecvByte
2.00a ktn 10/20/09 The macros have been renamed to remove _m from the name.
◆ XUartLite_DisableIntr
Disable the device interrupt. We cannot read the control register, so we just clear all bits. Since the only other ones are the FIFO reset bits, this works without side effects.
- Parameters
BaseAddress | is the base address of the device |
- Returns
- None.
- Note
- C-style Signature: void XUartLite_DisableIntr(u32 BaseAddress);
◆ XUartLite_EnableIntr
Enable the device interrupt. We cannot read the control register, so we just write the enable interrupt bit and clear all others. Since the only other ones are the FIFO reset bits, this works without side effects.
- Parameters
- Returns
- None.
- Note
- C-style Signature: void XUartLite_EnableIntr(u32 BaseAddress);
◆ XUartLite_GetStatusReg
#define XUartLite_GetStatusReg |
BaseAddress | ) |
Get the contents of the status register. Use the XUL_SR_* constants defined above to interpret the bit-mask returned.
- Parameters
- Returns
- A 32-bit value representing the contents of the status register.
- Note
- C-style Signature: u32 XUartLite_GetStatusReg(u32 BaseAddress);
◆ XUartLite_IsIntrEnabled
#define XUartLite_IsIntrEnabled |
BaseAddress | ) |
Value:
XUL_SR_INTR_ENABLED)
#define XUartLite_GetStatusReg(BaseAddress)
Definition: uartlite_l.h:216
Check to see if the interrupt is enabled.
- Parameters
- Returns
- TRUE if the interrupt is enabled, FALSE otherwise.
- Note
- C-style Signature: int XUartLite_IsIntrEnabled(u32 BaseAddress);
◆ XUartLite_IsReceiveEmpty
#define XUartLite_IsReceiveEmpty |
BaseAddress | ) |
Value:
XUL_SR_RX_FIFO_VALID_DATA)
Check to see if the receiver has data.
- Parameters
- Returns
- TRUE if the receiver is empty, FALSE if there is data present.
- Note
- C-style Signature: int XUartLite_IsReceiveEmpty(u32 BaseAddress);
◆ XUartLite_IsTransmitFull
#define XUartLite_IsTransmitFull |
BaseAddress | ) |
Value:Check to see if the transmitter is full.
- Parameters
- Returns
- TRUE if the transmitter is full, FALSE otherwise.
- Note
- C-style Signature: int XUartLite_IsTransmitFull(u32 BaseAddress);
◆ XUartLite_ReadReg
#define XUartLite_ReadReg |
BaseAddress, |
RegOffset |
Read a value from a UartLite register. A 32 bit read is performed.
- Parameters
BaseAddress | is the base address of the UartLite device. |
RegOffset | is the register offset from the base to read from. |
- Returns
- Data read from the register.
- Note
- C-style signature: u32 XUartLite_ReadReg(u32 BaseAddress, u32 RegOffset)
◆ XUartLite_SetControlReg
#define XUartLite_SetControlReg |
BaseAddress, |
Mask |
Set the contents of the control register. Use the XUL_CR_* constants defined above to create the bit-mask to be written to the register.
- Parameters
Mask | is the 32-bit value to write to the control register |
- Returns
- None.
- Note
- C-style Signature: void XUartLite_SetControlReg(u32 BaseAddress, u32 Mask);
◆ XUartLite_WriteReg
#define XUartLite_WriteReg |
BaseAddress, |
RegOffset, |
Data |
Write a value to a UartLite register. A 32 bit write is performed.
- Parameters
RegOffset | is the register offset from the base to write to. |
Data | is the data written to the register. |
- Returns
- None.
- Note
- C-style signature: void XUartLite_WriteReg(u32 BaseAddress, u32 RegOffset,
u32 Data)
◆ XUartLite_RecvByte()
u8 XUartLite_RecvByte |
UINTPTR |
BaseAddress | ) |
This functions receives a single byte using the UART. It is blocking in that it waits for the receiver to become non-empty before it reads from the receive register.
- Parameters
- Returns
- The byte of data received.
- Note
- None.
◆ XUartLite_SendByte()
void XUartLite_SendByte |
UINTPTR |
BaseAddress, |
u8 |
Data |
This functions sends a single byte using the UART. It is blocking in that it waits for the transmitter to become non-full before it writes the byte to the transmit register.
- Parameters
Data | is the byte of data to send |
- Returns
- None.
- Note
- None.
