RTEMS 6.1-rc2
Files | Data Structures | Enumerator | Variables
Tempsensor
file  fsl_tempsensor.h
struct  _tmpsns_config
 TMPSNS temperature structure. More...
tmpsns_measure_mode_t _tmpsns_config::measureMode
uint16_t _tmpsns_config::frequency
int32_t _tmpsns_config::highAlarmTemp
int32_t _tmpsns_config::panicAlarmTemp
int32_t _tmpsns_config::lowAlarmTemp
Driver version
enum  { kTEMPSENSOR_HighTempInterruptStatusEnable , kTEMPSENSOR_LowTempInterruptStatusEnable , kTEMPSENSOR_PanicTempInterruptStatusEnable , kTEMPSENSOR_FinishInterruptStatusEnable = TMPSNS_CTRL1_FINISH_IE_MASK }
 TMPSNS interrupt status enable type, tmpsns_interrupt_status_enable_t. More...
enum  { kTEMPSENSOR_HighTempInterruptStatus = TMPSNS_STATUS0_HIGH_TEMP_MASK , kTEMPSENSOR_LowTempInterruptStatus = TMPSNS_STATUS0_LOW_TEMP_MASK , kTEMPSENSOR_PanicTempInterruptStatus = TMPSNS_STATUS0_PANIC_TEMP_MASK }
 TMPSNS interrupt status type, tmpsns_interrupt_status_t. More...
enum  tmpsns_measure_mode_t { kTEMPSENSOR_SingleMode = 0U , kTEMPSENSOR_ContinuousMode = 1U }
 TMPSNS measure mode, tempsensor_measure_mode. More...
enum  _tmpsns_alarm_mode { kTEMPMON_HighAlarmMode = 0U , kTEMPMON_PanicAlarmMode = 1U , kTEMPMON_LowAlarmMode = 2U }
 TMPSNS alarm mode. More...
typedef struct _tmpsns_config tmpsns_config_t
typedef enum _tmpsns_alarm_mode tmpsns_alarm_mode_t
 TMPSNS alarm mode.
void TMPSNS_Init (TMPSNS_Type *base, const tmpsns_config_t *config)
 Initializes the TMPSNS module.
void TMPSNS_Deinit (TMPSNS_Type *base)
 Deinitializes the TMPSNS module.
void TMPSNS_GetDefaultConfig (tmpsns_config_t *config)
 Gets the default configuration structure.
void TMPSNS_StartMeasure (TMPSNS_Type *base)
 start the temperature measurement process.
void TMPSNS_StopMeasure (TMPSNS_Type *base)
 stop the measurement process.
float TMPSNS_GetCurrentTemperature (TMPSNS_Type *base)
 Get current temperature with the fused temperature calibration data.
void TMPSNS_SetTempAlarm (TMPSNS_Type *base, int32_t tempVal, tmpsns_alarm_mode_t alarmMode)
 Set the temperature count (raw sensor output) that will generate an alarm interrupt.
void TMPSNS_EnableInterrupt (TMPSNS_Type *base, uint32_t mask)
 Enable interrupt status.
void TMPSNS_DisableInterrupt (TMPSNS_Type *base, uint32_t mask)
 Disable interrupt status.
#define FSL_TMPSNS_DRIVER_VERSION   (MAKE_VERSION(2, 1, 0))
◆ anonymous enum
anonymous enum
High temperature interrupt status enable.
Low temperature interrupt status enable.
Panic temperature interrupt status enable.
Finish interrupt enable.
◆ anonymous enum
anonymous enum
High temperature interrupt status.
Low temperature interrupt status.
Panic temperature interrupt status.
◆ _tmpsns_alarm_mode
TMPSNS alarm mode.
The high alarm temperature interrupt mode.
The panic alarm temperature interrupt mode.
The low alarm temperature interrupt mode.
◆ tmpsns_measure_mode_t
Single measurement mode.
Continuous measurement mode.
◆ TMPSNS_Deinit()
void TMPSNS_Deinit ( TMPSNS_Type base)
Parameters
baseTMPSNS base pointer
brief Deinitializes the TMPSNS module.
param base TMPSNS base pointer
◆ TMPSNS_DisableInterrupt()
void TMPSNS_DisableInterrupt ( TMPSNS_Type base,
uint32_t  mask
Parameters
maskThe interrupts to disable from tmpsns_interrupt_status_enable_t.
brief Disable interrupt status.
param base TMPSNS base pointer param mask The interrupts to disable from tmpsns_interrupt_status_enable_t.
◆ TMPSNS_EnableInterrupt()
void TMPSNS_EnableInterrupt ( TMPSNS_Type base,
uint32_t  mask
Parameters
maskThe interrupts to enable from tmpsns_interrupt_status_enable_t.
brief Enable interrupt status.
param base TMPSNS base pointer param mask The interrupts to enable from tmpsns_interrupt_status_enable_t.
◆ TMPSNS_GetCurrentTemperature()
float TMPSNS_GetCurrentTemperature ( TMPSNS_Type base)
Parameters
Returns
current temperature with degrees Celsius.
brief Get current temperature with the fused temperature calibration data.
param base TMPSNS base pointer return current temperature with degrees Celsius.
◆ TMPSNS_GetDefaultConfig()
void TMPSNS_GetDefaultConfig ( tmpsns_config_t config)
This function initializes the TMPSNS configuration structure to a default value. The default values are: tempmonConfig->frequency = 0x02U; tempmonConfig->highAlarmTemp = 44U; tempmonConfig->panicAlarmTemp = 90U; tempmonConfig->lowAlarmTemp = 39U;
Parameters
configPointer to a configuration structure.
brief Gets the default configuration structure.
This function initializes the TMPSNS configuration structure to a default value. The default values are: tempmonConfig->frequency = 0x00U; tempmonConfig->highAlarmTemp = 25U; tempmonConfig->panicAlarmTemp = 80U; tempmonConfig->lowAlarmTemp = 20U;
param config Pointer to a configuration structure.
◆ TMPSNS_Init()
void TMPSNS_Init ( TMPSNS_Type base,
const tmpsns_config_t config
Parameters
configPointer to configuration structure.
brief Initializes the TMPSNS module.
param base TMPSNS base pointer param config Pointer to configuration structure.
◆ TMPSNS_SetTempAlarm()
void TMPSNS_SetTempAlarm ( TMPSNS_Type base,
int32_t  tempVal,
Parameters
tempValThe alarm temperature with degrees Celsius
alarmModeThe alarm mode.
brief Set the temperature count (raw sensor output) that will generate an alarm interrupt.
param base TMPSNS base pointer param tempVal The alarm temperature with degrees Celsius param alarmMode The alarm mode.
◆ TMPSNS_StartMeasure()
void TMPSNS_StartMeasure ( TMPSNS_Type base)
Parameters
baseTMPSNS base pointer.
Parameters
◆ TMPSNS_StopMeasure()
void TMPSNS_StopMeasure ( TMPSNS_Type base)
Parameters
Parameters
Variable Documentation
◆ frequency
The temperature measure frequency.
◆ highAlarmTemp
The high alarm temperature.
◆ lowAlarmTemp
The low alarm temperature.
◆ measureMode
The temperature measure mode.
◆ panicAlarmTemp
The panic alarm temperature.
