RTEMS 6.1-rc2
Spdif
struct  _spdif_config
 SPDIF user configuration structure. More...
struct  _spdif_transfer
 SPDIF transfer structure. More...
struct  _spdif_handle
 SPDIF handle structure. More...
Driver version
enum  {
  kStatus_SPDIF_RxDPLLLocked = MAKE_STATUS(kStatusGroup_SPDIF, 0) , kStatus_SPDIF_TxFIFOError = MAKE_STATUS(kStatusGroup_SPDIF, 1) , kStatus_SPDIF_TxFIFOResync = MAKE_STATUS(kStatusGroup_SPDIF, 2) , kStatus_SPDIF_RxCnew = MAKE_STATUS(kStatusGroup_SPDIF, 3) ,
  kStatus_SPDIF_ValidatyNoGood = MAKE_STATUS(kStatusGroup_SPDIF, 4) , kStatus_SPDIF_RxIllegalSymbol = MAKE_STATUS(kStatusGroup_SPDIF, 5) , kStatus_SPDIF_RxParityBitError = MAKE_STATUS(kStatusGroup_SPDIF, 6) , kStatus_SPDIF_UChannelOverrun = MAKE_STATUS(kStatusGroup_SPDIF, 7) ,
  kStatus_SPDIF_QChannelOverrun = MAKE_STATUS(kStatusGroup_SPDIF, 8) , kStatus_SPDIF_UQChannelSync = MAKE_STATUS(kStatusGroup_SPDIF, 9) , kStatus_SPDIF_UQChannelFrameError = MAKE_STATUS(kStatusGroup_SPDIF, 10) , kStatus_SPDIF_RxFIFOError = MAKE_STATUS(kStatusGroup_SPDIF, 11) ,
  kStatus_SPDIF_RxFIFOResync = MAKE_STATUS(kStatusGroup_SPDIF, 12) , kStatus_SPDIF_LockLoss = MAKE_STATUS(kStatusGroup_SPDIF, 13) , kStatus_SPDIF_TxIdle = MAKE_STATUS(kStatusGroup_SPDIF, 14) , kStatus_SPDIF_RxIdle = MAKE_STATUS(kStatusGroup_SPDIF, 15) ,
  kStatus_SPDIF_QueueFull = MAKE_STATUS(kStatusGroup_SPDIF, 16)
 SPDIF return status. More...
enum  _spdif_rxfull_select { kSPDIF_RxFull1Sample = 0x0u , kSPDIF_RxFull4Samples , kSPDIF_RxFull8Samples , kSPDIF_RxFull16Samples }
 SPDIF Rx FIFO full falg select, it decides when assert the rx full flag. More...
enum  _spdif_txempty_select { kSPDIF_TxEmpty0Sample = 0x0u , kSPDIF_TxEmpty4Samples , kSPDIF_TxEmpty8Samples , kSPDIF_TxEmpty12Samples }
 SPDIF tx FIFO EMPTY falg select, it decides when assert the tx empty flag. More...
enum  _spdif_uchannel_source { kSPDIF_NoUChannel = 0x0U , kSPDIF_UChannelFromRx = 0x1U , kSPDIF_UChannelFromTx = 0x3U }
 SPDIF U channel source. More...
enum  _spdif_gain_select {
  kSPDIF_GAIN_24 = 0x0U , kSPDIF_GAIN_16 , kSPDIF_GAIN_12 , kSPDIF_GAIN_8 ,
  kSPDIF_GAIN_6 , kSPDIF_GAIN_4 , kSPDIF_GAIN_3
 SPDIF clock gain. More...
enum  _spdif_tx_source { kSPDIF_txFromReceiver = 0x1U , kSPDIF_txNormal = 0x5U }
 SPDIF tx data source. More...
enum  _spdif_validity_config { kSPDIF_validityFlagAlwaysSet = 0x0U , kSPDIF_validityFlagAlwaysClear }
enum  {
  kSPDIF_RxDPLLLocked = SPDIF_SIE_LOCK_MASK , kSPDIF_TxFIFOError = SPDIF_SIE_TXUNOV_MASK , kSPDIF_TxFIFOResync = SPDIF_SIE_TXRESYN_MASK , kSPDIF_RxControlChannelChange = SPDIF_SIE_CNEW_MASK ,
  kSPDIF_ValidityFlagNoGood = SPDIF_SIE_VALNOGOOD_MASK , kSPDIF_RxIllegalSymbol = SPDIF_SIE_SYMERR_MASK , kSPDIF_RxParityBitError = SPDIF_SIE_BITERR_MASK , kSPDIF_UChannelReceiveRegisterFull = SPDIF_SIE_URXFUL_MASK ,
  kSPDIF_UChannelReceiveRegisterOverrun = SPDIF_SIE_URXOV_MASK , kSPDIF_QChannelReceiveRegisterFull = SPDIF_SIE_QRXFUL_MASK , kSPDIF_QChannelReceiveRegisterOverrun = SPDIF_SIE_QRXOV_MASK , kSPDIF_UQChannelSync = SPDIF_SIE_UQSYNC_MASK ,
  kSPDIF_UQChannelFrameError = SPDIF_SIE_UQERR_MASK , kSPDIF_RxFIFOError = SPDIF_SIE_RXFIFOUNOV_MASK , kSPDIF_RxFIFOResync = SPDIF_SIE_RXFIFORESYN_MASK , kSPDIF_LockLoss = SPDIF_SIE_LOCKLOSS_MASK ,
  kSPDIF_TxFIFOEmpty = SPDIF_SIE_TXEM_MASK , kSPDIF_RxFIFOFull = SPDIF_SIE_RXFIFOFUL_MASK , kSPDIF_AllInterrupt
 The SPDIF interrupt enable flag. More...
enum  { kSPDIF_RxDMAEnable = SPDIF_SCR_DMA_RX_EN_MASK , kSPDIF_TxDMAEnable = SPDIF_SCR_DMA_TX_EN_MASK }
 The DMA request sources. More...
typedef enum _spdif_rxfull_select spdif_rxfull_select_t
typedef enum _spdif_txempty_select spdif_txempty_select_t
typedef enum _spdif_uchannel_source spdif_uchannel_source_t
typedef enum _spdif_gain_select spdif_gain_select_t
 SPDIF clock gain.
typedef enum _spdif_tx_source spdif_tx_source_t
typedef enum _spdif_validity_config spdif_validity_config_t
typedef struct _spdif_config spdif_config_t
typedef struct _spdif_transfer spdif_transfer_t
typedef struct _spdif_handle spdif_handle_t
typedef void(* spdif_transfer_callback_t) (SPDIF_Type *base, spdif_handle_t *handle, status_t status, void *userData)
 SPDIF transfer callback prototype.
#define FSL_SPDIF_DRIVER_VERSION   (MAKE_VERSION(2, 0, 6))
#define SPDIF_XFER_QUEUE_SIZE   (4U)
 SPDIF transfer queue size, user can refine it according to use case.
Initialization and deinitialization
void SPDIF_Init (SPDIF_Type *base, const spdif_config_t *config)
 Initializes the SPDIF peripheral.
void SPDIF_GetDefaultConfig (spdif_config_t *config)
 Sets the SPDIF configuration structure to default values.
void SPDIF_Deinit (SPDIF_Type *base)
 De-initializes the SPDIF peripheral.
uint32_t SPDIF_GetInstance (SPDIF_Type *base)
 Get the instance number for SPDIF.
void SPDIF_TxEnable (SPDIF_Type *base, bool enable)
 Enables/disables the SPDIF Tx.
Bus Operations
void SPDIF_TxSetSampleRate (SPDIF_Type *base, uint32_t sampleRate_Hz, uint32_t sourceClockFreq_Hz)
 Configures the SPDIF Tx sample rate.
uint32_t SPDIF_GetRxSampleRate (SPDIF_Type *base, uint32_t clockSourceFreq_Hz)
 Configures the SPDIF Rx audio format.
void SPDIF_WriteBlocking (SPDIF_Type *base, uint8_t *buffer, uint32_t size)
 Sends data using a blocking method.
void SPDIF_ReadBlocking (SPDIF_Type *base, uint8_t *buffer, uint32_t size)
 Receives data using a blocking method.
Transactional
void SPDIF_TransferTxCreateHandle (SPDIF_Type *base, spdif_handle_t *handle, spdif_transfer_callback_t callback, void *userData)
 Initializes the SPDIF Tx handle.
void SPDIF_TransferRxCreateHandle (SPDIF_Type *base, spdif_handle_t *handle, spdif_transfer_callback_t callback, void *userData)
 Initializes the SPDIF Rx handle.
status_t SPDIF_TransferSendNonBlocking (SPDIF_Type *base, spdif_handle_t *handle, spdif_transfer_t *xfer)
 Performs an interrupt non-blocking send transfer on SPDIF.
status_t SPDIF_TransferReceiveNonBlocking (SPDIF_Type *base, spdif_handle_t *handle, spdif_transfer_t *xfer)
 Performs an interrupt non-blocking receive transfer on SPDIF.
status_t SPDIF_TransferGetSendCount (SPDIF_Type *base, spdif_handle_t *handle, size_t *count)
 Gets a set byte count.
status_t SPDIF_TransferGetReceiveCount (SPDIF_Type *base, spdif_handle_t *handle, size_t *count)
 Gets a received byte count.
void SPDIF_TransferAbortSend (SPDIF_Type *base, spdif_handle_t *handle)
 Aborts the current send.
void SPDIF_TransferAbortReceive (SPDIF_Type *base, spdif_handle_t *handle)
 Aborts the current IRQ receive.
void SPDIF_TransferTxHandleIRQ (SPDIF_Type *base, spdif_handle_t *handle)
 Tx interrupt handler.
void SPDIF_TransferRxHandleIRQ (SPDIF_Type *base, spdif_handle_t *handle)
◆ FSL_SPDIF_DRIVER_VERSION
Version 2.0.6
◆ anonymous enum
anonymous enum
SPDIF Rx PLL locked.
SPDIF Tx FIFO error.
SPDIF Tx left and right FIFO resync.
SPDIF Rx status channel value updated.
SPDIF validaty flag not good.
SPDIF Rx receive illegal symbol.
SPDIF Rx parity bit error.
SPDIF receive U channel overrun.
SPDIF receive Q channel overrun.
SPDIF U/Q channel sync found.
SPDIF U/Q channel frame error.
SPDIF Rx FIFO error.
SPDIF Rx left and right FIFO resync.
SPDIF Rx PLL clock lock loss.
SPDIF Tx is idle
SPDIF Rx is idle
SPDIF queue full
◆ anonymous enum
anonymous enum
kSPDIF_RxDPLLLocked
SPDIF DPLL locked
kSPDIF_TxFIFOError
Tx FIFO underrun or overrun
kSPDIF_TxFIFOResync
Tx FIFO left and right channel resync
SPDIF Rx control channel value changed
SPDIF validity flag no good
SPDIF receiver found illegal symbol
SPDIF receiver found parity bit error
SPDIF U channel revceive register full
SPDIF U channel receive register overrun
SPDIF Q channel receive reigster full
SPDIF Q channel receive register overrun
kSPDIF_RxFIFOError
SPDIF Rx FIFO underrun/overrun
kSPDIF_RxFIFOResync
kSPDIF_LockLoss
SPDIF receiver loss of lock
kSPDIF_TxFIFOEmpty
SPDIF Tx FIFO empty
kSPDIF_RxFIFOFull
SPDIF Rx FIFO full
kSPDIF_AllInterrupt
all interrupt
◆ anonymous enum
anonymous enum
kSPDIF_RxDMAEnable
Rx FIFO full
kSPDIF_TxDMAEnable
Tx FIFO empty
◆ _spdif_gain_select
SPDIF clock gain.
kSPDIF_GAIN_24
Gain select is 24
kSPDIF_GAIN_16
Gain select is 16
kSPDIF_GAIN_12
Gain select is 12
kSPDIF_GAIN_8
Gain select is 8
kSPDIF_GAIN_6
Gain select is 6
kSPDIF_GAIN_4
Gain select is 4
kSPDIF_GAIN_3
Gain select is 3
◆ _spdif_rxfull_select
Rx full at least 1 sample in left and right FIFO
Rx full at least 4 sample in left and right FIFO
Rx full at least 8 sample in left and right FIFO
Rx full at least 16 sample in left and right FIFO
◆ _spdif_tx_source
Tx data directly through SPDIF receiver
kSPDIF_txNormal
Normal operation, data from processor
◆ _spdif_txempty_select
Tx empty at most 0 sample in left and right FIFO
Tx empty at most 4 sample in left and right FIFO
Tx empty at most 8 sample in left and right FIFO
Tx empty at most 12 sample in left and right FIFO
◆ _spdif_uchannel_source
kSPDIF_NoUChannel
No embedded U channel
U channel from receiver, it is CD mode
U channel from on chip tx
◆ _spdif_validity_config
Outgoing validity flags always set
Outgoing validity flags always clear
◆ SPDIF_Deinit()
void SPDIF_Deinit ( SPDIF_Type base)
This API gates the SPDIF clock. The SPDIF module can't operate unless SPDIF_Init is called to enable the clock.
Parameters
baseSPDIF base pointer
brief De-initializes the SPDIF peripheral.
param base SPDIF base pointer
◆ SPDIF_GetDefaultConfig()
void SPDIF_GetDefaultConfig ( spdif_config_t config)
This API initializes the configuration structure for use in SPDIF_Init. The initialized structure can remain unchanged in SPDIF_Init, or it can be modified before calling SPDIF_Init. This is an example.
void SPDIF_GetDefaultConfig(spdif_config_t *config)
Definition: fsl_spdif.c:156
Definition: fsl_spdif.h:142
Definition: deflate.c:114
Parameters
configpointer to master configuration structure
brief Sets the SPDIF configuration structure to default values.
This API initializes the configuration structure for use in SPDIF_Init. The initialized structure can remain unchanged in SPDIF_Init, or it can be modified before calling SPDIF_Init. This is an example. code spdif_config_t config; SPDIF_GetDefaultConfig(&config); endcode
param config pointer to master configuration structure
◆ SPDIF_GetInstance()
uint32_t SPDIF_GetInstance ( SPDIF_Type base)
Parameters
baseSPDIF base pointer.
◆ SPDIF_GetRxSampleRate()
uint32_t SPDIF_GetRxSampleRate ( SPDIF_Type base,
The audio format can be changed at run-time. This function configures the sample rate and audio data format to be transferred.
Parameters
clockSourceFreq_HzSPDIF system clock frequency in hz.
brief Configures the SPDIF Rx audio format.
param base SPDIF base pointer. param clockSourceFreq_Hz SPDIF system clock frequency in hz.
◆ SPDIF_Init()
void SPDIF_Init ( SPDIF_Type base,
const spdif_config_t config
Ungates the SPDIF clock, resets the module, and configures SPDIF with a configuration structure. The configuration structure can be custom filled or set with default values by SPDIF_GetDefaultConfig().
Note
This API should be called at the beginning of the application to use the SPDIF driver. Otherwise, accessing the SPDIF module can cause a hard fault because the clock is not enabled.
Parameters
configSPDIF configuration structure.
brief Initializes the SPDIF peripheral.
note This API should be called at the beginning of the application to use the SPDIF driver. Otherwise, accessing the SPDIF module can cause a hard fault because the clock is not enabled.
param base SPDIF base pointer param config SPDIF configuration structure.
◆ SPDIF_ReadBlocking()
void SPDIF_ReadBlocking ( SPDIF_Type base,
uint8_t *  buffer,
uint32_t  size
Note
This function blocks by polling until data is ready to be sent.
Parameters
bufferPointer to the data to be read.
sizeBytes to be read.
brief Receives data using a blocking method.
note This function blocks by polling until data is ready to be sent.
param base SPDIF base pointer. param buffer Pointer to the data to be read. param size Bytes to be read.
◆ SPDIF_TransferAbortReceive()
void SPDIF_TransferAbortReceive ( SPDIF_Type base,
spdif_handle_t handle
Note
This API can be called when an interrupt non-blocking transfer initiates to abort the transfer early.
Parameters
handlePointer to the spdif_handle_t structure which stores the transfer state.
brief Aborts the current IRQ receive.
note This API can be called when an interrupt non-blocking transfer initiates to abort the transfer early.
param base SPDIF base pointer param handle Pointer to the spdif_handle_t structure which stores the transfer state.
◆ SPDIF_TransferAbortSend()
void SPDIF_TransferAbortSend ( SPDIF_Type base,
Note
This API can be called any time when an interrupt non-blocking transfer initiates to abort the transfer early.
Parameters
brief Aborts the current send.
note This API can be called any time when an interrupt non-blocking transfer initiates to abort the transfer early.
param base SPDIF base pointer. param handle Pointer to the spdif_handle_t structure which stores the transfer state.
◆ SPDIF_TransferGetReceiveCount()
status_t SPDIF_TransferGetReceiveCount ( SPDIF_Type base,
spdif_handle_t handle,
size_t *  count
Parameters
countBytes count received.
Return values
kStatus_SuccessSucceed get the transfer count.
kStatus_NoTransferInProgressThere is not a non-blocking transaction currently in progress.
brief Gets a received byte count.
param base SPDIF base pointer. param handle Pointer to the spdif_handle_t structure which stores the transfer state. param count Bytes count received. retval kStatus_Success Succeed get the transfer count. retval kStatus_NoTransferInProgress There is not a non-blocking transaction currently in progress.
◆ SPDIF_TransferGetSendCount()
status_t SPDIF_TransferGetSendCount ( SPDIF_Type base,
size_t *  count
Parameters
countBytes count sent.
Return values
brief Gets a set byte count.
param base SPDIF base pointer. param handle Pointer to the spdif_handle_t structure which stores the transfer state. param count Bytes count sent. retval kStatus_Success Succeed get the transfer count. retval kStatus_NoTransferInProgress There is not a non-blocking transaction currently in progress.
◆ SPDIF_TransferReceiveNonBlocking()
status_t SPDIF_TransferReceiveNonBlocking ( SPDIF_Type base,
spdif_transfer_t xfer
Note
This API returns immediately after the transfer initiates. Call the SPDIF_RxGetTransferStatusIRQ to poll the transfer status and check whether the transfer is finished. If the return status is not kStatus_SPDIF_Busy, the transfer is finished.
Parameters
xferPointer to the spdif_transfer_t structure.
Return values
kStatus_SuccessSuccessfully started the data receive.
kStatus_SPDIF_RxBusyPrevious receive still not finished.
kStatus_InvalidArgumentThe input parameter is invalid.
brief Performs an interrupt non-blocking receive transfer on SPDIF.
note This API returns immediately after the transfer initiates. Call the SPDIF_RxGetTransferStatusIRQ to poll the transfer status and check whether the transfer is finished. If the return status is not kStatus_SPDIF_Busy, the transfer is finished.
param base SPDIF base pointer param handle Pointer to the spdif_handle_t structure which stores the transfer state. param xfer Pointer to the spdif_transfer_t structure. retval kStatus_Success Successfully started the data receive. retval kStatus_SPDIF_RxBusy Previous receive still not finished. retval kStatus_InvalidArgument The input parameter is invalid.
◆ SPDIF_TransferRxCreateHandle()
void SPDIF_TransferRxCreateHandle ( SPDIF_Type base,
void *  userData
This function initializes the Rx handle for the SPDIF Rx transactional APIs. Call this function once to get the handle initialized.
Parameters
handleSPDIF handle pointer.
callbackPointer to the user callback function.
userDataUser parameter passed to the callback function.
brief Initializes the SPDIF Rx handle.
param base SPDIF base pointer. param handle SPDIF handle pointer. param callback Pointer to the user callback function. param userData User parameter passed to the callback function.
◆ SPDIF_TransferRxHandleIRQ()
void SPDIF_TransferRxHandleIRQ ( SPDIF_Type base,
Parameters
handlePointer to the spdif_handle_t structure.
brief Tx interrupt handler.
param base SPDIF base pointer. param handle Pointer to the spdif_handle_t structure.
◆ SPDIF_TransferSendNonBlocking()
status_t SPDIF_TransferSendNonBlocking ( SPDIF_Type base,
Note
This API returns immediately after the transfer initiates. Call the SPDIF_TxGetTransferStatusIRQ to poll the transfer status and check whether the transfer is finished. If the return status is not kStatus_SPDIF_Busy, the transfer is finished.
Parameters
Return values
kStatus_SPDIF_TxBusyPrevious receive still not finished.
brief Performs an interrupt non-blocking send transfer on SPDIF.
note This API returns immediately after the transfer initiates. Call the SPDIF_TxGetTransferStatusIRQ to poll the transfer status and check whether the transfer is finished. If the return status is not kStatus_SPDIF_Busy, the transfer is finished.
param base SPDIF base pointer. param handle Pointer to the spdif_handle_t structure which stores the transfer state. param xfer Pointer to the spdif_transfer_t structure. retval kStatus_Success Successfully started the data receive. retval kStatus_SPDIF_TxBusy Previous receive still not finished. retval kStatus_InvalidArgument The input parameter is invalid.
◆ SPDIF_TransferTxCreateHandle()
void SPDIF_TransferTxCreateHandle ( SPDIF_Type base,
void *  userData
This function initializes the Tx handle for the SPDIF Tx transactional APIs. Call this function once to get the handle initialized.
Parameters
brief Initializes the SPDIF Tx handle.
param base SPDIF base pointer param handle SPDIF handle pointer. param callback Pointer to the user callback function. param userData User parameter passed to the callback function
◆ SPDIF_TransferTxHandleIRQ()
void SPDIF_TransferTxHandleIRQ ( SPDIF_Type base,
Parameters
◆ SPDIF_TxEnable()
void SPDIF_TxEnable ( SPDIF_Type base,
bool  enable
Parameters
enableTrue means enable SPDIF Tx, false means disable.
brief Enables/disables the SPDIF Tx.
param base SPDIF base pointer param enable True means enable SPDIF Tx, false means disable.
◆ SPDIF_TxSetSampleRate()
void SPDIF_TxSetSampleRate ( SPDIF_Type base,
The audio format can be changed at run-time. This function configures the sample rate.
Parameters
sampleRate_HzSPDIF sample rate frequency in Hz.
sourceClockFreq_HzSPDIF tx clock source frequency in Hz.
brief Configures the SPDIF Tx sample rate.
param base SPDIF base pointer. param sampleRate_Hz SPDIF sample rate frequency in Hz. param sourceClockFreq_Hz SPDIF tx clock source frequency in Hz.
◆ SPDIF_WriteBlocking()
void SPDIF_WriteBlocking ( SPDIF_Type base,
uint8_t *  buffer,
uint32_t  size
Note
Parameters
bufferPointer to the data to be written.
sizeBytes to be written.
brief Sends data using a blocking method.
param base SPDIF base pointer. param buffer Pointer to the data to be written. param size Bytes to be written.
