RTEMS 6.1-rc2
Data Structures | Enumerator | Variables
Rtwdog
struct  _rtwdog_work_mode
 Defines RTWDOG work mode. More...
struct  _rtwdog_config
 Describes RTWDOG configuration structure. More...
bool _rtwdog_work_mode::enableWait
bool _rtwdog_work_mode::enableStop
bool _rtwdog_work_mode::enableDebug
bool _rtwdog_config::enableRtwdog
rtwdog_clock_source_t _rtwdog_config::clockSource
rtwdog_clock_prescaler_t _rtwdog_config::prescaler
rtwdog_work_mode_t _rtwdog_config::workMode
rtwdog_test_mode_t _rtwdog_config::testMode
bool _rtwdog_config::enableUpdate
bool _rtwdog_config::enableInterrupt
bool _rtwdog_config::enableWindowMode
uint16_t _rtwdog_config::windowValue
uint16_t _rtwdog_config::timeoutValue
Driver version
enum  _rtwdog_clock_source { kRTWDOG_ClockSource0 = 0U , kRTWDOG_ClockSource1 = 1U , kRTWDOG_ClockSource2 = 2U , kRTWDOG_ClockSource3 = 3U }
 Describes RTWDOG clock source. More...
enum  _rtwdog_clock_prescaler { kRTWDOG_ClockPrescalerDivide1 = 0x0U , kRTWDOG_ClockPrescalerDivide256 = 0x1U }
 Describes the selection of the clock prescaler. More...
enum  _rtwdog_test_mode { kRTWDOG_TestModeDisabled = 0U , kRTWDOG_UserModeEnabled = 1U , kRTWDOG_LowByteTest = 2U , kRTWDOG_HighByteTest = 3U }
 Describes RTWDOG test mode. More...
enum  _rtwdog_interrupt_enable_t { kRTWDOG_InterruptEnable = RTWDOG_CS_INT_MASK }
 RTWDOG interrupt configuration structure. More...
enum  _rtwdog_status_flags_t { kRTWDOG_RunningFlag = RTWDOG_CS_EN_MASK , kRTWDOG_InterruptFlag = RTWDOG_CS_FLG_MASK }
 RTWDOG status flags. More...
typedef enum _rtwdog_clock_source rtwdog_clock_source_t
typedef enum _rtwdog_clock_prescaler rtwdog_clock_prescaler_t
typedef struct _rtwdog_work_mode rtwdog_work_mode_t
typedef enum _rtwdog_test_mode rtwdog_test_mode_t
typedef struct _rtwdog_config rtwdog_config_t
#define FSL_RTWDOG_DRIVER_VERSION   (MAKE_VERSION(2, 1, 2))
 RTWDOG driver version 2.1.2.
RTWDOG Initialization and De-initialization
void RTWDOG_GetDefaultConfig (rtwdog_config_t *config)
 Initializes the RTWDOG configuration structure.
 AT_QUICKACCESS_SECTION_CODE (void RTWDOG_Init(RTWDOG_Type *base, const rtwdog_config_t *config))
 Initializes the RTWDOG module.
void RTWDOG_Deinit (RTWDOG_Type *base)
 De-initializes the RTWDOG module.
RTWDOG functional Operation
void RTWDOG_ClearStatusFlags (RTWDOG_Type *base, uint32_t mask)
 Clears the RTWDOG flag.
__STATIC_FORCEINLINE void RTWDOG_Unlock (RTWDOG_Type *base)
 Unlocks the RTWDOG register written.
Unlock sequence
#define WDOG_FIRST_WORD_OF_UNLOCK   (RTWDOG_UPDATE_KEY & 0xFFFFU)
#define WDOG_SECOND_WORD_OF_UNLOCK   ((RTWDOG_UPDATE_KEY >> 16U) & 0xFFFFU)
Refresh sequence
#define WDOG_FIRST_WORD_OF_REFRESH   (RTWDOG_REFRESH_KEY & 0xFFFFU)
#define WDOG_SECOND_WORD_OF_REFRESH   ((RTWDOG_REFRESH_KEY >> 16U) & 0xFFFFU)
◆ WDOG_FIRST_WORD_OF_REFRESH
First word of refresh sequence
◆ WDOG_FIRST_WORD_OF_UNLOCK
First word of unlock sequence
◆ WDOG_SECOND_WORD_OF_REFRESH
Second word of refresh sequence
◆ WDOG_SECOND_WORD_OF_UNLOCK
Second word of unlock sequence
◆ _rtwdog_clock_prescaler
Divided by 1
Divided by 256
◆ _rtwdog_clock_source
Clock source 0
Clock source 1
Clock source 2
Clock source 3
◆ _rtwdog_interrupt_enable_t
This structure contains the settings for all of the RTWDOG interrupt configurations.
Interrupt is generated before forcing a reset
◆ _rtwdog_status_flags_t
This structure contains the RTWDOG status flags for use in the RTWDOG functions.
kRTWDOG_RunningFlag
Running flag, set when RTWDOG is enabled
Interrupt flag, set when interrupt occurs
◆ _rtwdog_test_mode
Test Mode disabled
User Mode enabled
kRTWDOG_LowByteTest
Test Mode enabled, only low byte is used
Test Mode enabled, only high byte is used
◆ AT_QUICKACCESS_SECTION_CODE()
AT_QUICKACCESS_SECTION_CODE ( void   RTWDOG_InitRTWDOG_Type *base, const rtwdog_config_t *config)
This function initializes the RTWDOG. To reconfigure the RTWDOG without forcing a reset first, enableUpdate must be set to true in the configuration.
Example:
config.timeoutValue = 0x7ffU;
config.enableUpdate = true;
RTWDOG_Init(wdog_base,&config);
void RTWDOG_GetDefaultConfig(rtwdog_config_t *config)
Definition: fsl_rtwdog.c:65
Definition: fsl_rtwdog.h:73
Definition: deflate.c:114
Parameters
baseRTWDOG peripheral base address.
configThe configuration of the RTWDOG.
◆ RTWDOG_ClearStatusFlags()
void RTWDOG_ClearStatusFlags ( RTWDOG_Type base,
uint32_t  mask
This function clears the RTWDOG status flag.
Example to clear an interrupt flag:
void RTWDOG_ClearStatusFlags(RTWDOG_Type *base, uint32_t mask)
Definition: fsl_rtwdog.c:34
@ kRTWDOG_InterruptFlag
Definition: fsl_rtwdog.h:104
Parameters
maskThe status flags to clear. The parameter can be any combination of the following values:
  • kRTWDOG_InterruptFlag
brief Clears the RTWDOG flag.
Example to clear an interrupt flag: code RTWDOG_ClearStatusFlags(wdog_base,kRTWDOG_InterruptFlag); endcode param base RTWDOG peripheral base address. param mask The status flags to clear. The parameter can be any combination of the following values: arg kRTWDOG_InterruptFlag
◆ RTWDOG_Deinit()
void RTWDOG_Deinit ( RTWDOG_Type base)
This function shuts down the RTWDOG. Ensure that the WDOG_CS.UPDATE is 1, which means that the register update is enabled.
Parameters
brief De-initializes the RTWDOG module.
◆ RTWDOG_GetDefaultConfig()
void RTWDOG_GetDefaultConfig ( rtwdog_config_t config)
This function initializes the RTWDOG configuration structure to default values. The default values are:
rtwdogConfig->enableRtwdog = true;
rtwdogConfig->clockSource = kRTWDOG_ClockSource1;
rtwdogConfig->prescaler = kRTWDOG_ClockPrescalerDivide1;
rtwdogConfig->workMode.enableWait = true;
rtwdogConfig->workMode.enableStop = false;
rtwdogConfig->workMode.enableDebug = false;
rtwdogConfig->testMode = kRTWDOG_TestModeDisabled;
rtwdogConfig->enableUpdate = true;
rtwdogConfig->enableInterrupt = false;
rtwdogConfig->enableWindowMode = false;
rtwdogConfig->windowValue = 0U;
rtwdogConfig->timeoutValue = 0xFFFFU;
@ kRTWDOG_TestModeDisabled
Definition: fsl_rtwdog.h:65
@ kRTWDOG_ClockPrescalerDivide1
Definition: fsl_rtwdog.h:50
@ kRTWDOG_ClockSource1
Definition: fsl_rtwdog.h:42
Parameters
configPointer to the RTWDOG configuration structure.
See also
rtwdog_config_t
brief Initializes the RTWDOG configuration structure.
This function initializes the RTWDOG configuration structure to default values. The default values are: code rtwdogConfig->enableRtwdog = true; rtwdogConfig->clockSource = kRTWDOG_ClockSource1; rtwdogConfig->prescaler = kRTWDOG_ClockPrescalerDivide1; rtwdogConfig->workMode.enableWait = true; rtwdogConfig->workMode.enableStop = false; rtwdogConfig->workMode.enableDebug = false; rtwdogConfig->testMode = kRTWDOG_TestModeDisabled; rtwdogConfig->enableUpdate = true; rtwdogConfig->enableInterrupt = false; rtwdogConfig->enableWindowMode = false; rtwdogConfig->windowValue = 0U; rtwdogConfig->timeoutValue = 0xFFFFU; endcode
param config Pointer to the RTWDOG configuration structure. see rtwdog_config_t
◆ RTWDOG_Unlock()
__STATIC_FORCEINLINE void RTWDOG_Unlock ( RTWDOG_Type base)
This function unlocks the RTWDOG register written.
Before starting the unlock sequence and following the configuration, disable the global interrupts. Otherwise, an interrupt could effectively invalidate the unlock sequence and the WCT may expire. After the configuration finishes, re-enable the global interrupts.
Parameters
Variable Documentation
◆ clockSource
Clock source select
◆ enableDebug
Enables or disables RTWDOG in debug mode
◆ enableInterrupt
Enables or disables RTWDOG interrupt
◆ enableRtwdog
◆ enableStop
Enables or disables RTWDOG in stop mode
◆ enableUpdate
Update write-once register enable
◆ enableWait
Enables or disables RTWDOG in wait mode
◆ enableWindowMode
Enables or disables RTWDOG window mode
◆ prescaler
Clock prescaler value
◆ testMode
Configures RTWDOG test mode
◆ timeoutValue
Timeout value
◆ windowValue
Window value
◆ workMode
Configures RTWDOG work mode in debug stop and wait mode
