RTEMS 6.1-rc2
Macros | Functions
Real-Time Clock Driver Interface
#define RTC_DEVICE_NAME   "/dev/rtc"
#define RTC_DRIVER_TABLE_ENTRY
rtems_device_driver rtc_initialize (rtems_device_major_number, rtems_device_minor_number, void *)
rtems_device_driver rtc_open (rtems_device_major_number, rtems_device_minor_number, void *)
rtems_device_driver rtc_close (rtems_device_major_number, rtems_device_minor_number, void *)
rtems_device_driver rtc_read (rtems_device_major_number, rtems_device_minor_number, void *)
rtems_device_driver rtc_write (rtems_device_major_number, rtems_device_minor_number, void *)
rtems_device_driver rtc_control (rtems_device_major_number, rtems_device_minor_number, void *)
This driver interface provides support to read and set the real-time clock and to initialize the time of day for the system.
◆ RTC_DEVICE_NAME
Device file name path.
◆ RTC_DRIVER_TABLE_ENTRY
Value:
rtems_device_driver rtc_control(rtems_device_major_number, rtems_device_minor_number, void *)
Definition: rtc.c:247
rtems_device_driver rtc_write(rtems_device_major_number, rtems_device_minor_number, void *)
Definition: rtc.c:202
rtems_device_driver rtc_initialize(rtems_device_major_number, rtems_device_minor_number, void *)
Definition: rtc.c:156
rtems_device_driver rtc_read(rtems_device_major_number, rtems_device_minor_number, void *)
Definition: rtc.c:179
rtems_device_driver rtc_close(rtems_device_major_number, rtems_device_minor_number, void *)
Definition: rtc.c:238
rtems_device_driver rtc_open(rtems_device_major_number, rtems_device_minor_number, void *)
Definition: rtc.c:229
Device driver table entry.
◆ rtc_close()
rtems_device_driver rtc_close ( rtems_device_major_number  major,
rtems_device_minor_number  minor,
void *  arg
Closes the real-time clock device.
◆ rtc_control()
rtems_device_driver rtc_control ( rtems_device_major_number  major,
void *  arg
Controls the real-time clock.
◆ rtc_initialize()
rtems_device_driver rtc_initialize ( rtems_device_major_number  major,
rtems_device_minor_number  minor_arg,
void *  arg
Initializes the real-time clock device and sets the time of day for the system.
If the real-time clock provides an invalid time of day value the system time of day must remain untouched.
◆ rtc_open()
rtems_device_driver rtc_open ( rtems_device_major_number  major,
void *  arg
Opens the real-time clock device.
◆ rtc_read()
rtems_device_driver rtc_read ( rtems_device_major_number  major,
void *  arg
Reads the real-time clock value.
The value will be returned in a rtems_time_of_day structure.
◆ rtc_write()
rtems_device_driver rtc_write ( rtems_device_major_number  major,
void *  arg
Sets the real-time clock value.
The value will be set from a rtems_time_of_day structure.
