RTEMS 6.1-rc2
Data Structures | Macros | Enumerator | Variables
Romapi
struct  _flexspi_lut_seq
 FLEXSPI LUT Sequence structure. More...
struct  flexspi_dll_time_t
 FLEXSPI DLL time. More...
struct  _flexspi_mem_config
 FLEXSPI Memory Configuration Block. More...
struct  _flexspi_nor_config
 Serial NOR configuration block. More...
struct  _flexspi_xfer
 FLEXSPI Transfer Context. More...
struct  _serial_nor_config_option
 Serial NOR Configuration Option. More...
#define FSL_ROM_ROMAPI_VERSION   (MAKE_VERSION(1U, 1U, 1U))
 ROMAPI version 1.1.1.
#define FSL_ROM_FLEXSPINOR_DRIVER_VERSION   (MAKE_VERSION(1U, 4U, 0U))
 ROM FLEXSPI NOR driver version 1.4.0.
 ROM API version 1.1.1.
#define FSL_ROM_FLEXSPINOR_DRIVER_VERSION   (MAKE_VERSION(1U, 7U, 0U))
 ROM FLEXSPI NOR driver version 1.7.0.
uint8_t _flexspi_lut_seq::seqNum
uint8_t _flexspi_lut_seq::seqId
uint16_t _flexspi_lut_seq::reserved
uint8_t flexspi_dll_time_t::time_100ps
uint8_t flexspi_dll_time_t::delay_cells
uint32_t _flexspi_mem_config::tag
uint32_t _flexspi_mem_config::version
uint32_t _flexspi_mem_config::reserved0
uint8_t _flexspi_mem_config::readSampleClkSrc
uint8_t _flexspi_mem_config::csHoldTime
uint8_t _flexspi_mem_config::csSetupTime
uint8_t _flexspi_mem_config::columnAddressWidth
uint8_t _flexspi_mem_config::deviceModeCfgEnable
uint8_t _flexspi_mem_config::deviceModeType
uint16_t _flexspi_mem_config::waitTimeCfgCommands
flexspi_lut_seq_t _flexspi_mem_config::deviceModeSeq
uint32_t _flexspi_mem_config::deviceModeArg
uint8_t _flexspi_mem_config::configCmdEnable
uint8_t _flexspi_mem_config::configModeType [3]
flexspi_lut_seq_t _flexspi_mem_config::configCmdSeqs [3]
uint32_t _flexspi_mem_config::reserved1
uint32_t _flexspi_mem_config::configCmdArgs [3]
uint32_t _flexspi_mem_config::reserved2
uint32_t _flexspi_mem_config::controllerMiscOption
uint8_t _flexspi_mem_config::deviceType
uint8_t _flexspi_mem_config::sflashPadType
uint8_t _flexspi_mem_config::serialClkFreq
uint8_t _flexspi_mem_config::lutCustomSeqEnable
uint32_t _flexspi_mem_config::reserved3 [2]
uint32_t _flexspi_mem_config::sflashA1Size
uint32_t _flexspi_mem_config::sflashA2Size
uint32_t _flexspi_mem_config::sflashB1Size
uint32_t _flexspi_mem_config::sflashB2Size
uint32_t _flexspi_mem_config::csPadSettingOverride
uint32_t _flexspi_mem_config::sclkPadSettingOverride
uint32_t _flexspi_mem_config::dataPadSettingOverride
uint32_t _flexspi_mem_config::dqsPadSettingOverride
uint32_t _flexspi_mem_config::timeoutInMs
uint32_t _flexspi_mem_config::commandInterval
flexspi_dll_time_t _flexspi_mem_config::dataValidTime [2]
uint16_t _flexspi_mem_config::busyOffset
uint16_t _flexspi_mem_config::busyBitPolarity
uint32_t _flexspi_mem_config::lookupTable [64]
flexspi_lut_seq_t _flexspi_mem_config::lutCustomSeq [12]
uint32_t _flexspi_mem_config::reserved4 [4]
flexspi_mem_config_t _flexspi_nor_config::memConfig
 Common memory configuration info via FlexSPI.
uint32_t _flexspi_nor_config::pageSize
 Page size of Serial NOR.
uint32_t _flexspi_nor_config::sectorSize
 Sector size of Serial NOR.
uint8_t _flexspi_nor_config::ipcmdSerialClkFreq
 Clock frequency for IP command.
uint8_t _flexspi_nor_config::isUniformBlockSize
 Sector/Block size is the same.
uint8_t _flexspi_nor_config::isDataOrderSwapped
 The data order is swapped in OPI DDR mode (only i.MXRT11*)
uint8_t _flexspi_nor_config::reserved0
 Reserved for future use.
uint8_t _flexspi_nor_config::serialNorType
 Serial NOR Flash type: 0/1/2/3.
uint8_t _flexspi_nor_config::needExitNoCmdMode
 Need to exit NoCmd mode before other IP command.
uint8_t _flexspi_nor_config::halfClkForNonReadCmd
 Half the Serial Clock for non-read command: true/false.
uint8_t _flexspi_nor_config::needRestoreNoCmdMode
 Need to Restore NoCmd mode after IP commmand execution.
uint32_t _flexspi_nor_config::blockSize
 Block size.
uint32_t _flexspi_nor_config::reserve2 [10]
flexspi_operation_t _flexspi_xfer::operation
uint32_t _flexspi_xfer::baseAddress
uint32_t _flexspi_xfer::seqId
uint32_t _flexspi_xfer::seqNum
bool _flexspi_xfer::isParallelModeEnable
uint32_t * _flexspi_xfer::txBuffer
uint32_t _flexspi_xfer::txSize
uint32_t * _flexspi_xfer::rxBuffer
uint32_t _flexspi_xfer::rxSize
uint32_t   _serial_nor_config_option::max_freq: 4
uint32_t   _serial_nor_config_option::misc_mode: 4
uint32_t   _serial_nor_config_option::quad_mode_setting: 4
uint32_t   _serial_nor_config_option::cmd_pads: 4
uint32_t   _serial_nor_config_option::query_pads: 4
uint32_t   _serial_nor_config_option::device_type: 4
uint32_t   _serial_nor_config_option::option_size: 4
uint32_t   _serial_nor_config_option::tag: 4
struct {
}   _serial_nor_config_option::B
uint32_t   _serial_nor_config_option::U
union {
   struct {
   }   B
   uint32_t   U
_serial_nor_config_option::option0
uint32_t   _serial_nor_config_option::dummy_cycles: 8
uint32_t   _serial_nor_config_option::status_override: 8
uint32_t   _serial_nor_config_option::pinmux_group: 4
uint32_t   _serial_nor_config_option::dqs_pinmux_group: 4
uint32_t   _serial_nor_config_option::drive_strength: 4
uint32_t   _serial_nor_config_option::flash_connection: 4
struct {
union {
   struct {
   }   B
   uint32_t   U
_serial_nor_config_option::option1
Support for init FLEXSPI NOR configuration
enum  { kSerialFlash_1Pad = 1U , kSerialFlash_2Pads = 2U , kSerialFlash_4Pads = 4U , kSerialFlash_8Pads = 8U }
 Flash Pad Definitions.
enum  { kFLEXSPIClk_SDR , kFLEXSPIClk_DDR }
 FLEXSPI clock configuration type. More...
enum  _flexspi_read_sample_clk {
  kFLEXSPIReadSampleClk_LoopbackInternally = 0U , kFLEXSPIReadSampleClk_LoopbackFromDqsPad = 1U , kFLEXSPIReadSampleClk_LoopbackFromSckPad = 2U , kFLEXSPIReadSampleClk_ExternalInputFromDqsPad = 3U ,
 FLEXSPI Read Sample Clock Source definition. More...
enum  { kFLEXSPIDeviceType_SerialNOR = 1U }
 Flash Type Definition. More...
enum  {
  kDeviceConfigCmdType_Generic , kDeviceConfigCmdType_QuadEnable , kDeviceConfigCmdType_Spi2Xpi , kDeviceConfigCmdType_Xpi2Spi ,
  kDeviceConfigCmdType_Spi2NoCmd , kDeviceConfigCmdType_Reset
 Flash Configuration Command Type. More...
enum  _flexspi_serial_clk_freq {
  kFLEXSPISerialClk_NoChange = 0U , kFLEXSPISerialClk_30MHz = 1U , kFLEXSPISerialClk_50MHz = 2U , kFLEXSPISerialClk_60MHz = 3U ,
  kFLEXSPISerialClk_75MHz = 4U , kFLEXSPISerialClk_80MHz = 5U , kFLEXSPISerialClk_100MHz = 6U , kFLEXSPISerialClk_133MHz = 7U ,
  kFLEXSPISerialClk_166MHz = 8U , kFLEXSPISerialClk_200MHz = 9U , kFLEXSPISerialClk_NoChange = 0U , kFLEXSPISerialClk_30MHz = 1U ,
  kFLEXSPISerialClk_50MHz = 2U , kFLEXSPISerialClk_60MHz = 3U , kFLEXSPISerialClk_75MHz = 4U , kFLEXSPISerialClk_80MHz = 5U ,
  kFLEXSPISerialClk_100MHz = 6U , kFLEXSPISerialClk_133MHz = 7U , kFLEXSPISerialClk_166MHz = 8U
 Defintions for FLEXSPI Serial Clock Frequency. More...
enum  {
  kFLEXSPIMiscOffset_DiffClkEnable = 0U , kFLEXSPIMiscOffset_Ck2Enable = 1U , kFLEXSPIMiscOffset_ParallelEnable = 2U , kFLEXSPIMiscOffset_WordAddressableEnable = 3U ,
  kFLEXSPIMiscOffset_SafeConfigFreqEnable = 4U , kFLEXSPIMiscOffset_PadSettingOverrideEnable = 5U , kFLEXSPIMiscOffset_DdrModeEnable = 6U , kFLEXSPIMiscOffset_UseValidTimeForAllFreq = 7U
 Misc feature bit definitions. More...
enum  { kSerialNorType_StandardSPI , kSerialNorType_HyperBus , kSerialNorType_XPI , kSerialNorType_NoCmd }
FLEXSPI NOR Configuration
enum  { kSerialFlash_ISSI_ManufacturerID = 0x9DU , kSerialFlash_Adesto_ManufacturerID = 0x1F , kSerialFlash_Winbond_ManufacturerID = 0xEFU , kSerialFlash_Cypress_ManufacturerID = 0x01U }
 Manufacturer ID. More...
enum  _flexspi_nor_status {
  kStatus_ROM_FLEXSPI_SequenceExecutionTimeout , kStatus_ROM_FLEXSPI_InvalidSequence = MAKE_STATUS(kROM_StatusGroup_FLEXSPI, 1) , kStatus_ROM_FLEXSPI_DeviceTimeout = MAKE_STATUS(kROM_StatusGroup_FLEXSPI, 2) , kStatus_FLEXSPINOR_DTRRead_DummyProbeFailed ,
  kStatus_ROM_FLEXSPINOR_SFDP_NotFound , kStatus_ROM_FLEXSPINOR_Flash_NotFound , kStatus_ROM_FLEXSPI_SequenceExecutionTimeout , kStatus_ROM_FLEXSPI_InvalidSequence = MAKE_STATUS(kStatusGroup_FLEXSPI, 1) ,
  kStatus_ROM_FLEXSPI_DeviceTimeout = MAKE_STATUS(kStatusGroup_FLEXSPI, 2) , kStatus_ROM_FLEXSPINOR_SFDP_NotFound , kStatus_ROM_FLEXSPINOR_Flash_NotFound , kStatus_FLEXSPINOR_DTRRead_DummyProbeFailed
 ROM FLEXSPI NOR flash status. More...
enum  _flexspi_operation {
  kFLEXSPIOperation_Command , kFLEXSPIOperation_Config , kFLEXSPIOperation_Write , kFLEXSPIOperation_Read ,
  kFLEXSPIOperation_End = kFLEXSPIOperation_Read , kFLEXSPIOperation_Command , kFLEXSPIOperation_Config , kFLEXSPIOperation_Write ,
typedef struct _flexspi_lut_seq flexspi_lut_seq_t
typedef struct _flexspi_mem_config flexspi_mem_config_t
typedef struct _flexspi_nor_config flexspi_nor_config_t
typedef enum _flexspi_operation flexspi_operation_t
typedef struct _flexspi_xfer flexspi_xfer_t
 Flash Pad Definitions. More...
enum  {
 Definitions for FLEXSPI Serial Clock Frequency. More...
enum  {
 FLEXSPI Operation Context. More...
#define kFLEXSPIOperation_End   kFLEXSPIOperation_Read
#define MISRA_CAST(to_type, to_var, from_type, from_var)
 convert the type for MISRA
typedef struct _serial_nor_config_option serial_nor_config_option_t
Common ROMAPI fearures info defines
#define FSL_ROM_HAS_FLEXSPINOR_API   (1)
#define FSL_ROM_HAS_RUNBOOTLOADER_API   (0)
#define FSL_ROM_FLEXSPINOR_API_HAS_FEATURE_GET_CONFIG   (0)
#define FSL_ROM_FLEXSPINOR_API_HAS_FEATURE_FLASH_INIT   (1)
#define FSL_ROM_FLEXSPINOR_API_HAS_FEATURE_ERASE   (1)
#define FSL_ROM_FLEXSPINOR_API_HAS_FEATURE_ERASE_SECTOR   (1)
#define FSL_ROM_FLEXSPINOR_API_HAS_FEATURE_ERASE_BLOCK   (0)
#define FSL_ROM_FLEXSPINOR_API_HAS_FEATURE_ERASE_ALL   (1)
#define FSL_ROM_FLEXSPINOR_API_HAS_FEATURE_PAGE_PROGRAM   (1)
#define FSL_ROM_FLEXSPINOR_API_HAS_FEATURE_UPDATE_LUT   (1)
#define FSL_ROM_FLEXSPINOR_API_HAS_FEATURE_CMD_XFER   (1)
#define kROM_StatusGroup_FLEXSPI   60U
#define kROM_StatusGroup_FLEXSPINOR   200U
#define FSL_ROM_FLEXSPI_LUT_SEQ(cmd0, pad0, op0, cmd1, pad1, op1)
#define FSL_ROM_FLEXSPI_BITMASK(bit_offset)   (1U << (bit_offset))
 Generate bit mask.
#define FLEXSPI_CFG_BLK_TAG   (0x42464346UL)
 FLEXSPI memory config block related defintions.
#define FLEXSPI_CFG_BLK_VERSION   (0x56010400UL)
#define CMD_SDR   0x01U
#define CMD_DDR   0x21U
#define RADDR_SDR   0x02U
#define RADDR_DDR   0x22U
#define CADDR_SDR   0x03U
#define CADDR_DDR   0x23U
#define MODE1_SDR   0x04U
#define MODE1_DDR   0x24U
#define MODE2_SDR   0x05U
#define MODE2_DDR   0x25U
#define MODE4_SDR   0x06U
#define MODE4_DDR   0x26U
#define MODE8_SDR   0x07U
#define MODE8_DDR   0x27U
#define WRITE_SDR   0x08U
#define WRITE_DDR   0x28U
#define READ_SDR   0x09U
#define READ_DDR   0x29U
#define LEARN_SDR   0x0AU
#define LEARN_DDR   0x2AU
#define DATSZ_SDR   0x0BU
#define DATSZ_DDR   0x2BU
#define DUMMY_SDR   0x0CU
#define DUMMY_DDR   0x2CU
#define DUMMY_RWDS_SDR   0x0DU
#define DUMMY_RWDS_DDR   0x2DU
#define JMP_ON_CS   0x1FU
#define STOP   0U
#define FLEXSPI_1PAD   0U
#define FLEXSPI_2PAD   1U
#define FLEXSPI_4PAD   2U
#define FLEXSPI_8PAD   3U
#define NOR_CMD_INDEX_READ   0U
#define NOR_CMD_INDEX_READSTATUS   1U
#define NOR_CMD_INDEX_WRITEENABLE   2U
#define NOR_CMD_INDEX_ERASESECTOR   3U
#define NOR_CMD_INDEX_PAGEPROGRAM   4U
#define NOR_CMD_INDEX_CHIPERASE   5U
#define NOR_CMD_INDEX_DUMMY   6U
#define NOR_CMD_INDEX_ERASEBLOCK   7U
#define NOR_CMD_LUT_SEQ_IDX_READ   0U
#define NOR_CMD_LUT_SEQ_IDX_READSTATUS   1U
#define NOR_CMD_LUT_SEQ_IDX_READSTATUS_XPI    2U
#define NOR_CMD_LUT_SEQ_IDX_WRITEENABLE   3U
#define NOR_CMD_LUT_SEQ_IDX_WRITEENABLE_XPI    4U
#define NOR_CMD_LUT_SEQ_IDX_ERASESECTOR   5U
#define NOR_CMD_LUT_SEQ_IDX_ERASEBLOCK   8U
#define NOR_CMD_LUT_SEQ_IDX_PAGEPROGRAM   9U
#define NOR_CMD_LUT_SEQ_IDX_CHIPERASE   11U
#define NOR_CMD_LUT_SEQ_IDX_READ_SFDP   13U
#define NOR_CMD_LUT_SEQ_IDX_RESTORE_NOCMD    14U
#define NOR_CMD_LUT_SEQ_IDX_EXIT_NOCMD    15U
Common ROMAPI features info defines
 ROM has FLEXSPI NOR API.
#define FSL_ROM_HAS_RUNBOOTLOADER_API   (1)
 ROM has run bootloader API.
#define FSL_ROM_FLEXSPINOR_API_HAS_FEATURE_GET_CONFIG   (1)
 ROM has FLEXSPI NOR get config API.
 ROM has flash init API.
 ROM has erase API.
 ROM has erase sector API.
#define FSL_ROM_FLEXSPINOR_API_HAS_FEATURE_ERASE_BLOCK   (1)
 ROM has erase block API.
 ROM has erase all API.
#define FSL_ROM_FLEXSPINOR_API_HAS_FEATURE_READ   (1)
 ROM has read API.
 ROM has update lut API.
 ROM has FLEXSPI command API.
#define kROM_StatusGroup_FLEXSPINOR   201U
 Generate bit mask.
 FLEXSPI memory config block related definitions.
#define STOP   0U
#define NOR_CMD_LUT_SEQ_IDX_READID   7U
◆ FLEXSPI_CFG_BLK_TAG [1/2]
ascii "FCFB" Big Endian
◆ FLEXSPI_CFG_BLK_TAG [2/2]
◆ FLEXSPI_CFG_BLK_VERSION [1/2]
V1.4.0
◆ FLEXSPI_CFG_BLK_VERSION [2/2]
V1.4.0
◆ FSL_ROM_FLEXSPI_LUT_SEQ [1/2]
#define FSL_ROM_FLEXSPI_LUT_SEQ (   cmd0,
  pad0,
  op0,
  cmd1,
  pad1,
  op1
Value:
FLEXSPI_LUT_NUM_PADS1(pad1) | FLEXSPI_LUT_OPCODE1(cmd1))
#define FLEXSPI_LUT_NUM_PADS0(x)
Definition: MIMXRT1052.h:22264
#define FLEXSPI_LUT_OPERAND1(x)
Definition: MIMXRT1052.h:22276
#define FLEXSPI_LUT_OPCODE1(x)
Definition: MIMXRT1052.h:22288
#define FLEXSPI_LUT_OPERAND0(x)
Definition: MIMXRT1052.h:22258
#define FLEXSPI_LUT_OPCODE0(x)
Definition: MIMXRT1052.h:22270
◆ FSL_ROM_FLEXSPI_LUT_SEQ [2/2]
  pad0,
  op0,
  cmd1,
  pad1,
  op1
Value:
◆ kROM_StatusGroup_FLEXSPI
ROM FLEXSPI status group number.
◆ kROM_StatusGroup_FLEXSPINOR [1/2]
ROM FLEXSPI NOR status group number.
◆ kROM_StatusGroup_FLEXSPINOR [2/2]
◆ MISRA_CAST
#define MISRA_CAST (   to_type,
  to_var,
  from_type,
  from_var
Value:
do \
union \
to_type to_var_tmp; \
from_type from_var_tmp; \
} type_converter_var = {.from_var_tmp = (from_var)}; \
(to_var) = type_converter_var.to_var_tmp; \
} while (false)
◆ NOR_CMD_LUT_SEQ_IDX_CHIPERASE [1/2]
Chip Erase sequence in lookupTable id stored in config block
◆ NOR_CMD_LUT_SEQ_IDX_CHIPERASE [2/2]
◆ NOR_CMD_LUT_SEQ_IDX_ERASEBLOCK [1/2]
Erase Block sequence id in lookupTable stored in config block
◆ NOR_CMD_LUT_SEQ_IDX_ERASEBLOCK [2/2]
◆ NOR_CMD_LUT_SEQ_IDX_ERASESECTOR [1/2]
Erase Sector sequence id in lookupTable stored in config block
◆ NOR_CMD_LUT_SEQ_IDX_ERASESECTOR [2/2]
◆ NOR_CMD_LUT_SEQ_IDX_EXIT_NOCMD [1/2]
Exit 0-4-4/0-8-8 mode sequence id in lookupTable stored in config blobk
◆ NOR_CMD_LUT_SEQ_IDX_EXIT_NOCMD [2/2]
Exit 0-4-4/0-8-8 mode sequence id in lookupTable stored in config block
◆ NOR_CMD_LUT_SEQ_IDX_PAGEPROGRAM [1/2]
Program sequence id in lookupTable stored in config block
◆ NOR_CMD_LUT_SEQ_IDX_PAGEPROGRAM [2/2]
◆ NOR_CMD_LUT_SEQ_IDX_READ [1/2]
NOR LUT sequence index used for default LUT assignment NOTE: The will take effect if the lut sequences are not customized. READ LUT sequence id in lookupTable stored in config block
◆ NOR_CMD_LUT_SEQ_IDX_READ [2/2]
NOR LUT sequence index used for default LUT assignment.
Note
It will take effect if the lut sequences are not customized. READ LUT sequence id in lookupTable stored in config block
◆ NOR_CMD_LUT_SEQ_IDX_READ_SFDP [1/2]
Read SFDP sequence in lookupTable id stored in config block
◆ NOR_CMD_LUT_SEQ_IDX_READ_SFDP [2/2]
◆ NOR_CMD_LUT_SEQ_IDX_READSTATUS [1/2]
Read Status LUT sequence id in lookupTable stored in config block
◆ NOR_CMD_LUT_SEQ_IDX_READSTATUS [2/2]
◆ NOR_CMD_LUT_SEQ_IDX_READSTATUS_XPI [1/2]
Read status DPI/QPI/OPI sequence id in lookupTable stored in config block
◆ NOR_CMD_LUT_SEQ_IDX_READSTATUS_XPI [2/2]
◆ NOR_CMD_LUT_SEQ_IDX_RESTORE_NOCMD [1/2]
Restore 0-4-4/0-8-8 mode sequence id in lookupTable stored in config block
◆ NOR_CMD_LUT_SEQ_IDX_RESTORE_NOCMD [2/2]
◆ NOR_CMD_LUT_SEQ_IDX_WRITEENABLE [1/2]
Write Enable sequence id in lookupTable stored in config block
◆ NOR_CMD_LUT_SEQ_IDX_WRITEENABLE [2/2]
◆ NOR_CMD_LUT_SEQ_IDX_WRITEENABLE_XPI [1/2]
Write Enable DPI/QPI/OPI sequence id in lookupTable stored in config block
◆ NOR_CMD_LUT_SEQ_IDX_WRITEENABLE_XPI [2/2]
◆ anonymous enum
anonymous enum
kFLEXSPIClk_SDR
Clock configure for SDR mode
kFLEXSPIClk_DDR
Clock configurat for DDR mode
◆ anonymous enum
anonymous enum
Flash device is Serial NOR
◆ anonymous enum
anonymous enum
Generic command, for example: configure dummy cycles, drive strength, etc
Quad Enable command
Switch from SPI to DPI/QPI/OPI mode
Switch from DPI/QPI/OPI to SPI mode
Switch to 0-4-4/0-8-8 mode
Reset device command
◆ anonymous enum
anonymous enum
Bit for Differential clock enable
Bit for CK2 enable
Bit for Parallel mode enable
Bit for Word Addressable enable
Bit for Safe Configuration Frequency enable
Bit for Pad setting override enable
Bit for DDR clock confiuration indication.
Bit for DLLCR settings under all modes
◆ anonymous enum
anonymous enum
Device that support Standard SPI and Extended SPI mode
Device that supports HyperBus only
kSerialNorType_XPI
Device that works under DPI, QPI or OPI mode
Device that works under No command mode (XIP mode/Performance Enhance mode/continous read mode)
◆ anonymous enum
anonymous enum
Manufacturer ID.
Manufacturer ID of the ISSI serial flash
Manufacturer ID of the Adesto Technologies serial flash
Manufacturer ID of the Winbond serial flash
Manufacturer ID for Cypress
◆ anonymous enum
anonymous enum
kSerialFlash_1Pad
1-wire communication
kSerialFlash_2Pads
2-wire communication
kSerialFlash_4Pads
4-wire communication
kSerialFlash_8Pads
8-wire communication
◆ anonymous enum
anonymous enum
kFLEXSPIClk_SDR
kFLEXSPIClk_DDR
Clock configure for DDR mode
◆ anonymous enum
anonymous enum
◆ anonymous enum
anonymous enum
Generic command, for example: configure dummy cycles, drive strength, etc.
Quad Enable command
◆ anonymous enum
anonymous enum
Bit for CK2 enable
Bit for DDR clock configuration indication.
◆ anonymous enum
anonymous enum
Manufacturer ID.
◆ _flexspi_nor_status [1/2]
Status for Sequence Execution timeout
Status for Invalid Sequence
Status for Device timeout
Status for DDR Read dummy probe failure
Status for SFDP read failure
Status for Flash detection failure
◆ _flexspi_nor_status [2/2]
◆ _flexspi_operation [1/2]
FLEXSPI operation: Only command, both TX and RX buffer are ignored.
FLEXSPI operation: Configure device mode, the TX FIFO size is fixed in LUT.
FLEXSPI operation: Write, only TX buffer is effective
FLEXSPI operation: Read, only Rx Buffer is effective.
◆ _flexspi_operation [2/2]
◆ _flexspi_read_sample_clk [1/2]
FLEXSPI Read Sample Clock Source from the Internal loopback
FLEXSPI Read Sample Clock Source from the Dqs Pad loopback
FLEXSPI Read Sample Clock Source from the Sck Pad loopback
FLEXSPI Read Sample Clock Source from the External Input by the Dqs Pad
◆ _flexspi_read_sample_clk [2/2]
◆ _flexspi_serial_clk_freq [1/2]
FlexSPI serial clock no changed
FlexSPI serial clock 30MHz
FlexSPI serial clock 50MHz
FlexSPI serial clock 60MHz
FlexSPI serial clock 75MHz
FlexSPI serial clock 80MHz
FlexSPI serial clock 100MHz
FlexSPI serial clock 133MHz
FlexSPI serial clock 166MHz
◆ _flexspi_serial_clk_freq [2/2]
Variable Documentation
◆ baseAddress
FLEXSPI operation base address
◆ blockSize
Block size.
Block size
◆ busyBitPolarity
[0x07e-0x07f] Busy flag polarity, 0 - busy flag is 1 when flash device is busy, 1 - busy flag is 0 when flash device is busy
◆ busyOffset
[0x07c-0x07d] Busy offset, valid value: 0-31
◆ cmd_pads [1/2]
Command pads
◆  [2/2]
uint32_t { ... } ::cmd_pads
Command pads
◆ columnAddressWidth
[0x00f-0x00f] Column Address with, for HyperBus protocol, it is fixed to 3, For Serial NAND, need to refer to datasheet
◆ commandInterval
[0x074-0x077] CS deselect interval between two commands
◆ configCmdArgs
[0x030-0x03b] Arguments/Parameters for device Configuration commands
◆ configCmdEnable
[0x01c-0x01c] Configure command Enable Flag, 1 - Enable, 0 - Disable
◆ configCmdSeqs
[0x020-0x02b] Sequence info for Device Configuration command, similar as deviceModeSeq
◆ configModeType
[0x01d-0x01f] Configure Mode Type, similar as deviceModeTpe
◆ controllerMiscOption
[0x040-0x043] Controller Misc Options, see Misc feature bit definitions for more details
◆ csHoldTime
[0x00d-0x00d] Data hold time, default value: 3
◆ csPadSettingOverride
[0x060-0x063] CS pad setting override value
◆ csSetupTime
[0x00e-0x00e] Date setup time, default value: 3
◆ dataPadSettingOverride
[0x068-0x06b] data pad setting override value
◆ dataValidTime
[0x078-0x07b] CLK edge to data valid time for PORT A and PORT B
◆ delay_cells
Data valid time, in terms of delay cells
◆ device_type [1/2]
Device type
◆  [2/2]
uint32_t { ... } ::device_type
Device type
◆ deviceModeArg
[0x018-0x01b] Argument/Parameter for device configuration
◆ deviceModeCfgEnable
[0x010-0x010] Device Mode Configure enable flag, 1 - Enable, 0 - Disable
◆ deviceModeSeq
[0x014-0x017] Device mode sequence info, [7:0] - LUT sequence id, [15:8] - LUt sequence number, [31:16] Reserved
◆ deviceModeType
[0x011-0x011] Specify the configuration command type:Quad Enable, DPI/QPI/OPI switch, Generic configuration, etc.
◆ deviceType
[0x044-0x044] Device Type: See Flash Type Definition for more details
◆  [1/2]
uint32_t { ... } ::dqs_pinmux_group
The DQS Pinmux Group Selection
◆ dqs_pinmux_group [2/2]
◆ dqsPadSettingOverride
[0x06c-0x06f] DQS pad setting override value
◆  [1/2]
uint32_t { ... } ::drive_strength
The Drive Strength of FlexSPI Pads
◆ drive_strength [2/2]
◆ dummy_cycles [1/2]
Dummy cycles before read
◆  [2/2]
uint32_t { ... } ::dummy_cycles
◆ flash_connection [1/2]
Flash connection option: 0 - Single Flash connected to port A, 1 - Parallel mode, 2 - Single Flash connected to Port B
◆  [2/2]
uint32_t { ... } ::flash_connection
◆ halfClkForNonReadCmd
◆ ipcmdSerialClkFreq
◆ isDataOrderSwapped
Data order (D0, D1, D2, D3) is swapped (D1,D0, D3, D2)
◆ isParallelModeEnable
Is a parallel transfer
◆ isUniformBlockSize
◆ lookupTable
[0x080-0x17f] Lookup table holds Flash command sequences
◆ lutCustomSeq
[0x180-0x1af] Customizable LUT Sequences
◆ lutCustomSeqEnable
[0x047-0x047] LUT customization Enable, it is required if the program/erase cannot be done using 1 LUT sequence, currently, only applicable to HyperFLASH
◆  [1/2]
uint32_t { ... } ::max_freq
Maximum supported Frequency
◆ max_freq [2/2]
◆ memConfig
Common memory configuration info via FLEXSPI
◆ misc_mode [1/2]
miscellaneous mode
◆  [2/2]
uint32_t { ... } ::misc_mode
miscellaneous mode
◆ needExitNoCmdMode
◆ needRestoreNoCmdMode
Need to Restore NoCmd mode after IP command execution
◆ operation
FLEXSPI operation
◆ option_size [1/2]
Option size, in terms of uint32_t, size = (option_size + 1) * 4
◆  [2/2]
uint32_t { ... } ::option_size
◆ pageSize
◆ pinmux_group [1/2]
The pinmux group selection
◆  [2/2]
uint32_t { ... } ::pinmux_group
◆ quad_mode_setting [1/2]
Quad mode setting
◆  [2/2]
uint32_t { ... } ::quad_mode_setting
Quad mode setting
◆ query_pads [1/2]
SFDP read pads
◆  [2/2]
uint32_t { ... } ::query_pads
SFDP read pads
◆ readSampleClkSrc
[0x00c-0x00c] Read Sample Clock Source, valid value: 0/1/3
◆ reserve2
◆ reserved0 [1/2]
◆ reserved0 [2/2]
[0x008-0x00b] Reserved for future use
◆ reserved1
[0x02c-0x02f] Reserved for future use
◆ reserved2
[0x03c-0x03f] Reserved for future use
◆ reserved3
[0x048-0x04f] Reserved for future use
◆ reserved4
[0x1b0-0x1bf] Reserved for future use
◆ rxBuffer
Rx buffer
◆ rxSize
Rx size in bytes
◆ sclkPadSettingOverride
[0x064-0x067] SCK pad setting override value
◆ sectorSize
◆ seqId [1/2]
Sequence Index, valid number: 0-15
◆ seqId [2/2]
Sequence Id
◆ seqNum [1/2]
Sequence Number, valid number: 1-16
◆ seqNum [2/2]
Sequence Number
◆ serialClkFreq
[0x046-0x046] Serial Flash Frequencey, device specific definitions, See System Boot Chapter for more details
[0x046-0x046] Serial Flash Frequency, device specific definitions. See System Boot Chapter for more details
◆ serialNorType
◆ sflashA1Size
[0x050-0x053] Size of Flash connected to A1
◆ sflashA2Size
[0x054-0x057] Size of Flash connected to A2
◆ sflashB1Size
[0x058-0x05b] Size of Flash connected to B1
◆ sflashB2Size
[0x05c-0x05f] Size of Flash connected to B2
◆ sflashPadType
[0x045-0x045] Serial Flash Pad Type: 1 - Single, 2 - Dual, 4 - Quad, 8 - Octal
◆ status_override [1/2]
Override status register value during device mode configuration
◆  [2/2]
uint32_t { ... } ::status_override
◆ tag [1/3]
[0x000-0x003] Tag, fixed value 0x42464346UL
◆  [2/3]
uint32_t { ... } ::tag
Tag, must be 0x0E
◆ tag [3/3]
Tag, must be 0x0E
◆ time_100ps
Data valid time, in terms of 100ps
◆ timeoutInMs
[0x070-0x073] Timeout threshold for read status command
◆ txBuffer
Tx buffer
◆ txSize
Tx size in bytes
◆ version
[0x004-0x007] Version,[31:24] -'V', [23:16] - Major, [15:8] - Minor, [7:0] - bugfix
◆ waitTimeCfgCommands
[0x012-0x013] Wait time for all configuration commands, unit: 100us, Used for DPI/QPI/OPI switch or reset command
