RTEMS 6.1-rc2
Qtmr
struct  _qtmr_config
 Quad Timer config structure. More...
#define TMR_CSCTRL_OFLAG_MASK   (0x100UL)
#define TMR_CSCTRL_OFLAG_SHIFT   (8UL)
status_t QTMR_SetupPwm (TMR_Type *base, qtmr_channel_selection_t channel, uint32_t pwmFreqHz, uint8_t dutyCyclePercent, bool outputPolarity, uint32_t srcClock_Hz)
 Sets up Quad timer module for PWM signal output.
void QTMR_SetupInputCapture (TMR_Type *base, qtmr_channel_selection_t channel, qtmr_input_source_t capturePin, bool inputPolarity, bool reloadOnCapture, qtmr_input_capture_edge_t captureMode)
 Allows the user to count the source clock cycles until a capture event arrives.
Driver version
enum  _qtmr_primary_count_source {
  kQTMR_ClockCounter0InputPin = 0 , kQTMR_ClockCounter1InputPin , kQTMR_ClockCounter2InputPin , kQTMR_ClockCounter3InputPin ,
  kQTMR_ClockCounter0Output , kQTMR_ClockCounter1Output , kQTMR_ClockCounter2Output , kQTMR_ClockCounter3Output ,
  kQTMR_ClockDivide_1 , kQTMR_ClockDivide_2 , kQTMR_ClockDivide_4 , kQTMR_ClockDivide_8 ,
  kQTMR_ClockDivide_16 , kQTMR_ClockDivide_32 , kQTMR_ClockDivide_64 , kQTMR_ClockDivide_128
 Quad Timer primary clock source selection. More...
enum  _qtmr_input_source { kQTMR_Counter0InputPin = 0 , kQTMR_Counter1InputPin , kQTMR_Counter2InputPin , kQTMR_Counter3InputPin }
 Quad Timer input sources selection. More...
enum  _qtmr_counting_mode {
  kQTMR_NoOperation = 0 , kQTMR_PriSrcRiseEdge , kQTMR_PriSrcRiseAndFallEdge , kQTMR_PriSrcRiseEdgeSecInpHigh ,
  kQTMR_QuadCountMode , kQTMR_PriSrcRiseEdgeSecDir , kQTMR_SecSrcTrigPriCnt , kQTMR_CascadeCount
 Quad Timer counting mode selection. More...
enum  _qtmr_pwm_out_state { kQTMR_PwmLow = 0 , kQTMR_PwmHigh }
 Quad Timer PWM output state. More...
enum  _qtmr_output_mode {
  kQTMR_AssertWhenCountActive = 0 , kQTMR_ClearOnCompare , kQTMR_SetOnCompare , kQTMR_ToggleOnCompare ,
  kQTMR_ToggleOnAltCompareReg , kQTMR_SetOnCompareClearOnSecSrcInp , kQTMR_SetOnCompareClearOnCountRoll , kQTMR_EnableGateClock
 Quad Timer output mode selection. More...
enum  _qtmr_input_capture_edge { kQTMR_NoCapture = 0 , kQTMR_RisingEdge , kQTMR_FallingEdge , kQTMR_RisingAndFallingEdge }
 Quad Timer input capture edge mode, rising edge, or falling edge. More...
enum  _qtmr_preload_control { kQTMR_NoPreload = 0 , kQTMR_LoadOnComp1 , kQTMR_LoadOnComp2 }
enum  _qtmr_debug_action { kQTMR_RunNormalInDebug = 0U , kQTMR_HaltCounter , kQTMR_ForceOutToZero , kQTMR_HaltCountForceOutZero }
 List of Quad Timer run options when in Debug mode. More...
enum  _qtmr_interrupt_enable {
  kQTMR_CompareInterruptEnable = (1U << 0) , kQTMR_Compare1InterruptEnable = (1U << 1) , kQTMR_Compare2InterruptEnable = (1U << 2) , kQTMR_OverflowInterruptEnable = (1U << 3) ,
  kQTMR_EdgeInterruptEnable = (1U << 4)
 List of Quad Timer interrupts. More...
enum  _qtmr_status_flags {
  kQTMR_CompareFlag = (1U << 0) , kQTMR_Compare1Flag = (1U << 1) , kQTMR_Compare2Flag = (1U << 2) , kQTMR_OverflowFlag = (1U << 3) ,
  kQTMR_EdgeFlag = (1U << 4)
 List of Quad Timer flags. More...
enum  _qtmr_channel_selection { kQTMR_Channel_0 = 0U , kQTMR_Channel_1 , kQTMR_Channel_2 , kQTMR_Channel_3 }
 List of channel selection. More...
enum  _qtmr_dma_enable { kQTMR_InputEdgeFlagDmaEnable = (1U << 0) , kQTMR_ComparatorPreload1DmaEnable = (1U << 1) , kQTMR_ComparatorPreload2DmaEnable = (1U << 2) }
 List of Quad Timer DMA enable. More...
typedef enum _qtmr_primary_count_source qtmr_primary_count_source_t
typedef enum _qtmr_input_source qtmr_input_source_t
typedef enum _qtmr_counting_mode qtmr_counting_mode_t
typedef enum _qtmr_pwm_out_state qtmr_pwm_out_state_t
typedef enum _qtmr_output_mode qtmr_output_mode_t
typedef enum _qtmr_input_capture_edge qtmr_input_capture_edge_t
typedef enum _qtmr_preload_control qtmr_preload_control_t
typedef enum _qtmr_debug_action qtmr_debug_action_t
typedef enum _qtmr_interrupt_enable qtmr_interrupt_enable_t
typedef enum _qtmr_status_flags qtmr_status_flags_t
typedef enum _qtmr_channel_selection qtmr_channel_selection_t
typedef enum _qtmr_dma_enable qtmr_dma_enable_t
typedef struct _qtmr_config qtmr_config_t
#define FSL_QTMR_DRIVER_VERSION   (MAKE_VERSION(2, 2, 1))
Initialization and deinitialization
void QTMR_Init (TMR_Type *base, qtmr_channel_selection_t channel, const qtmr_config_t *config)
 Ungates the Quad Timer clock and configures the peripheral for basic operation.
void QTMR_Deinit (TMR_Type *base, qtmr_channel_selection_t channel)
 Stops the counter and gates the Quad Timer clock.
void QTMR_GetDefaultConfig (qtmr_config_t *config)
 Fill in the Quad Timer config struct with the default settings.
Interrupt Interface
void QTMR_EnableInterrupts (TMR_Type *base, qtmr_channel_selection_t channel, uint32_t mask)
 Enables the selected Quad Timer interrupts.
void QTMR_DisableInterrupts (TMR_Type *base, qtmr_channel_selection_t channel, uint32_t mask)
 Disables the selected Quad Timer interrupts.
uint32_t QTMR_GetEnabledInterrupts (TMR_Type *base, qtmr_channel_selection_t channel)
 Gets the enabled Quad Timer interrupts.
Status Interface
uint32_t QTMR_GetStatus (TMR_Type *base, qtmr_channel_selection_t channel)
 Gets the Quad Timer status flags.
void QTMR_ClearStatusFlags (TMR_Type *base, qtmr_channel_selection_t channel, uint32_t mask)
 Clears the Quad Timer status flags.
Read and Write the timer period
void QTMR_SetTimerPeriod (TMR_Type *base, qtmr_channel_selection_t channel, uint16_t ticks)
 Sets the timer period in ticks.
void QTMR_SetCompareValue (TMR_Type *base, qtmr_channel_selection_t channel, uint16_t ticks)
 Set compare value.
Enable and Disable the Quad Timer DMA
void QTMR_EnableDma (TMR_Type *base, qtmr_channel_selection_t channel, uint32_t mask)
 Enable the Quad Timer DMA.
void QTMR_DisableDma (TMR_Type *base, qtmr_channel_selection_t channel, uint32_t mask)
 Disable the Quad Timer DMA.
void QTMR_SetPwmOutputToIdle (TMR_Type *base, qtmr_channel_selection_t channel, bool idleStatus)
 Set PWM output in idle status (high or low).
uint8_t QTMR_GetPwmChannelStatus (TMR_Type *base, qtmr_channel_selection_t channel)
 Get the PWM channel dutycycle value.
void QTMR_SetPwmClockMode (TMR_Type *base, qtmr_channel_selection_t channel, qtmr_primary_count_source_t prescaler)
 This function set the value of the prescaler on QTimer channels.
◆ FSL_QTMR_DRIVER_VERSION
Version
Typedef Documentation
◆ qtmr_config_t
This structure holds the configuration settings for the Quad Timer peripheral. To initialize this structure to reasonable defaults, call the QTMR_GetDefaultConfig() function and pass a pointer to your config structure instance.
The config struct can be made const so it resides in flash
◆ _qtmr_channel_selection
kQTMR_Channel_0
TMR Channel 0
kQTMR_Channel_1
TMR Channel 1
kQTMR_Channel_2
TMR Channel 2
kQTMR_Channel_3
TMR Channel 3
◆ _qtmr_counting_mode
kQTMR_NoOperation
No operation
Count rising edges of primary source
Count rising and falling edges of primary source
Count rise edges of pri SRC while sec inp high active
kQTMR_QuadCountMode
Quadrature count mode, uses pri and sec sources
Count rising edges of pri SRC; sec SRC specifies dir
Edge of sec SRC trigger primary count until compare
kQTMR_CascadeCount
Cascaded count mode (up/down)
◆ _qtmr_debug_action
Continue with normal operation
kQTMR_HaltCounter
Halt counter
Force output to logic 0
Halt counter and force output to logic 0
◆ _qtmr_dma_enable
Input Edge Flag DMA Enable.
Comparator Preload Register 1 DMA Enable.
Comparator Preload Register 2 DMA Enable.
◆ _qtmr_input_capture_edge
kQTMR_NoCapture
Capture is disabled
kQTMR_RisingEdge
Capture on rising edge (IPS=0) or falling edge (IPS=1)
kQTMR_FallingEdge
Capture on falling edge (IPS=0) or rising edge (IPS=1)
Capture on both edges
◆ _qtmr_input_source
Use counter 0 input pin
Use counter 1 input pin
Use counter 2 input pin
Use counter 3 input pin
◆ _qtmr_interrupt_enable
Compare interrupt.
Compare 1 interrupt.
Compare 2 interrupt.
Timer overflow interrupt.
Input edge interrupt.
◆ _qtmr_output_mode
Assert OFLAG while counter is active
Clear OFLAG on successful compare
kQTMR_SetOnCompare
Set OFLAG on successful compare
Toggle OFLAG on successful compare
Toggle OFLAG using alternating compare registers
Set OFLAG on compare, clear on sec SRC input edge
Set OFLAG on compare, clear on counter rollover
Enable gated clock output while count is active
◆ _qtmr_preload_control
kQTMR_NoPreload
Never preload
kQTMR_LoadOnComp1
Load upon successful compare with value in COMP1
kQTMR_LoadOnComp2
Load upon successful compare with value in COMP2
◆ _qtmr_primary_count_source
Use counter 0 output
Use counter 1 output
Use counter 2 output
Use counter 3 output
kQTMR_ClockDivide_1
IP bus clock divide by 1 prescaler
kQTMR_ClockDivide_2
IP bus clock divide by 2 prescaler
kQTMR_ClockDivide_4
IP bus clock divide by 4 prescaler
kQTMR_ClockDivide_8
IP bus clock divide by 8 prescaler
IP bus clock divide by 16 prescaler
IP bus clock divide by 32 prescaler
IP bus clock divide by 64 prescaler
IP bus clock divide by 128 prescaler
◆ _qtmr_pwm_out_state
kQTMR_PwmLow
The output state of PWM channel is low
kQTMR_PwmHigh
◆ _qtmr_status_flags
kQTMR_CompareFlag
Compare flag
kQTMR_Compare1Flag
Compare 1 flag
kQTMR_Compare2Flag
Compare 2 flag
kQTMR_OverflowFlag
Timer overflow flag
kQTMR_EdgeFlag
Input edge flag
◆ QTMR_ClearStatusFlags()
void QTMR_ClearStatusFlags ( TMR_Type base,
uint32_t  mask
Parameters
baseQuad Timer peripheral base address
channelQuad Timer channel number
maskThe status flags to clear. This is a logical OR of members of the enumeration qtmr_status_flags_t
brief Clears the Quad Timer status flags.
param base Quad Timer peripheral base address param channel Quad Timer channel number param mask The status flags to clear. This is a logical OR of members of the enumeration qtmr_status_flags_t
◆ QTMR_Deinit()
void QTMR_Deinit ( TMR_Type base,
Parameters
brief Stops the counter and gates the Quad Timer clock
◆ QTMR_DisableDma()
void QTMR_DisableDma ( TMR_Type base,
uint32_t  mask
Parameters
maskThe DMA to enable. This is a logical OR of members of the enumeration qtmr_dma_enable_t
brief Disable the Quad Timer DMA.
param base Quad Timer peripheral base address param channel Quad Timer channel number param mask The DMA to enable. This is a logical OR of members of the enumeration qtmr_dma_enable_t
◆ QTMR_DisableInterrupts()
void QTMR_DisableInterrupts ( TMR_Type base,
uint32_t  mask
Parameters
maskThe interrupts to enable. This is a logical OR of members of the enumeration qtmr_interrupt_enable_t
brief Disables the selected Quad Timer interrupts
param base Quad Timer peripheral base addres param channel Quad Timer channel number param mask The interrupts to enable. This is a logical OR of members of the enumeration qtmr_interrupt_enable_t
◆ QTMR_EnableDma()
void QTMR_EnableDma ( TMR_Type base,
uint32_t  mask
Parameters
brief Enable the Quad Timer DMA.
◆ QTMR_EnableInterrupts()
void QTMR_EnableInterrupts ( TMR_Type base,
uint32_t  mask
Parameters
brief Enables the selected Quad Timer interrupts
param base Quad Timer peripheral base address param channel Quad Timer channel number param mask The interrupts to enable. This is a logical OR of members of the enumeration qtmr_interrupt_enable_t
◆ QTMR_GetDefaultConfig()
void QTMR_GetDefaultConfig ( qtmr_config_t config)
The default values are:
config->enableExternalForce = false;
config->enableMasterMode = false;
config->faultFilterCount = 0;
config->faultFilterPeriod = 0;
config->primarySource = kQTMR_ClockDivide_2;
config->secondarySource = kQTMR_Counter0InputPin;
@ kQTMR_RunNormalInDebug
Definition: fsl_qtmr.h:119
@ kQTMR_Counter0InputPin
Definition: fsl_qtmr.h:60
@ kQTMR_ClockDivide_2
Definition: fsl_qtmr.h:48
Definition: deflate.c:114
Parameters
configPointer to user's Quad Timer config structure.
brief Fill in the Quad Timer config struct with the default settings
The default values are: code config->debugMode = kQTMR_RunNormalInDebug; config->enableExternalForce = false; config->enableMasterMode = false; config->faultFilterCount = 0; config->faultFilterPeriod = 0; config->primarySource = kQTMR_ClockDivide_2; config->secondarySource = kQTMR_Counter0InputPin; endcode param config Pointer to user's Quad Timer config structure.
◆ QTMR_GetEnabledInterrupts()
uint32_t QTMR_GetEnabledInterrupts ( TMR_Type base,
Parameters
Returns
The enabled interrupts. This is the logical OR of members of the enumeration qtmr_interrupt_enable_t
brief Gets the enabled Quad Timer interrupts
return The enabled interrupts. This is the logical OR of members of the enumeration qtmr_interrupt_enable_t
◆ QTMR_GetPwmChannelStatus()
uint8_t QTMR_GetPwmChannelStatus ( TMR_Type base,
Parameters
Returns
Current channel dutycycle value.
brief Get the PWM channel dutycycle value.
return Current channel dutycycle value.
◆ QTMR_GetStatus()
uint32_t QTMR_GetStatus ( TMR_Type base,
Parameters
Returns
The status flags. This is the logical OR of members of the enumeration qtmr_status_flags_t
brief Gets the Quad Timer status flags
return The status flags. This is the logical OR of members of the enumeration qtmr_status_flags_t
◆ QTMR_Init()
void QTMR_Init ( TMR_Type base,
const qtmr_config_t config
Note
This API should be called at the beginning of the application using the Quad Timer driver.
Parameters
brief Ungates the Quad Timer clock and configures the peripheral for basic operation.
note This API should be called at the beginning of the application using the Quad Timer driver.
param base Quad Timer peripheral base address param channel Quad Timer channel number param config Pointer to user's Quad Timer config structure
◆ QTMR_SetCompareValue()
void QTMR_SetCompareValue ( TMR_Type base,
uint16_t  ticks
Set compare value.
This function sets the value used for comparison with the counter value.
Parameters
ticksTimer period in units of ticks.
brief Set compare value.
param base Quad Timer peripheral base address param channel Quad Timer channel number param ticks Timer period in units of ticks.
◆ QTMR_SetPwmClockMode()
void QTMR_SetPwmClockMode ( TMR_Type base,
Parameters
prescalerSet prescaler value
brief This function set the value of the prescaler on QTimer channels.
param base Quad Timer peripheral base address param channel Quad Timer channel number param prescaler Set prescaler value
◆ QTMR_SetPwmOutputToIdle()
void QTMR_SetPwmOutputToIdle ( TMR_Type base,
bool  idleStatus
Note
When the PWM is set again, the counting needs to be restarted.
Parameters
idleStatusTrue: PWM output is high in idle status; false: PWM output is low in idle status.
brief Set PWM output in idle status (high or low).
Note: When the PWM is set again, the counting needs to be restarted.
param base Quad Timer peripheral base address param channel Quad Timer channel number param idleStatus True: PWM output is high in idle status; false: PWM output is low in idle status.
◆ QTMR_SetTimerPeriod()
void QTMR_SetTimerPeriod ( TMR_Type base,
uint16_t  ticks
Timers counts from initial value till it equals the count value set here. The counter will then reinitialize to the value specified in the Load register.
Note
  1. This function will write the time period in ticks to COMP1 or COMP2 register depending on the count direction
  2. User can call the utility macros provided in fsl_common.h to convert to ticks
  3. This function supports cases, providing only primary source clock without secondary source clock.
Parameters
brief Sets the timer period in ticks.
note
  4. The load register is reset before the counter is reinitialized to the value specified in the load register.
◆ QTMR_SetupInputCapture()
void QTMR_SetupInputCapture ( TMR_Type base,
bool  inputPolarity,
The count is stored in the capture register.
Parameters
capturePinPin through which we receive the input signal to trigger the capture
inputPolaritytrue: invert polarity of the input signal, false: no inversion
reloadOnCapturetrue: reload the counter when an input capture occurs, false: no reload
captureModeSpecifies which edge of the input signal triggers a capture
brief Allows the user to count the source clock cycles until a capture event arrives.
param base Quad Timer peripheral base address param channel Quad Timer channel number param capturePin Pin through which we receive the input signal to trigger the capture param inputPolarity true: invert polarity of the input signal, false: no inversion param reloadOnCapture true: reload the counter when an input capture occurs, false: no reload param captureMode Specifies which edge of the input signal triggers a capture
◆ QTMR_SetupPwm()
status_t QTMR_SetupPwm ( TMR_Type base,
uint32_t  pwmFreqHz,
The function initializes the timer module according to the parameters passed in by the user. The function also sets up the value compare registers to match the PWM signal requirements.
Parameters
pwmFreqHzPWM signal frequency in Hz
dutyCyclePercentPWM pulse width, value should be between 0 to 100 0=inactive signal(0% duty cycle)... 100=active signal (100% duty cycle)
outputPolaritytrue: invert polarity of the output signal, false: no inversion
srcClock_HzMain counter clock in Hz.
Returns
Returns an error if there was error setting up the signal.
brief Sets up Quad timer module for PWM signal output.
param base Quad Timer peripheral base address param channel Quad Timer channel number param pwmFreqHz PWM signal frequency in Hz param dutyCyclePercent PWM pulse width, value should be between 0 to 100 0=inactive signal(0% duty cycle)... 100=active signal (100% duty cycle) param outputPolarity true: invert polarity of the output signal, false: no inversion param srcClock_Hz Main counter clock in Hz.
return Returns an error if there was error setting up the signal.
