RTEMS 6.1-rc2
Data Structures | Macros | Enumerator | Variables
Pxp_driver
struct  _pxp_output_buffer_config
 PXP output buffer configuration. More...
struct  _pxp_ps_buffer_config
 PXP process surface buffer configuration. More...
struct  _pxp_as_buffer_config
 PXP alphs surface buffer configuration. More...
struct  _pxp_as_blend_config
 PXP alpha surface blending configuration. More...
struct  _pxp_csc2_config
 PXP CSC2 configuration. More...
struct  _pxp_lut_config
 PXP LUT configuration. More...
struct  _pxp_dither_final_lut_data
 PXP dither final LUT data. More...
struct  _pxp_dither_config
 PXP dither configuration. More...
struct  pxp_porter_duff_config_t
 PXP Porter Duff configuration. More...
struct  _pxp_pic_copy_config
 PXP Porter Duff blend mode. Note: don't change the enum item value. More...
#define PXP_LUT_TABLE_BYTE   (16UL * 1024UL)
#define PXP_INTERNAL_RAM_LUT_BYTE   (256)
pxp_output_pixel_format_t _pxp_output_buffer_config::pixelFormat
pxp_interlaced_output_mode_t _pxp_output_buffer_config::interlacedMode
uint32_t _pxp_output_buffer_config::buffer0Addr
uint32_t _pxp_output_buffer_config::buffer1Addr
uint16_t _pxp_output_buffer_config::pitchBytes
uint16_t _pxp_output_buffer_config::width
uint16_t _pxp_output_buffer_config::height
pxp_ps_pixel_format_t _pxp_ps_buffer_config::pixelFormat
bool _pxp_ps_buffer_config::swapByte
uint32_t _pxp_ps_buffer_config::bufferAddr
uint32_t _pxp_ps_buffer_config::bufferAddrU
uint32_t _pxp_ps_buffer_config::bufferAddrV
uint16_t _pxp_ps_buffer_config::pitchBytes
pxp_as_pixel_format_t _pxp_as_buffer_config::pixelFormat
uint32_t _pxp_as_buffer_config::bufferAddr
uint16_t _pxp_as_buffer_config::pitchBytes
uint8_t _pxp_as_blend_config::alpha
bool _pxp_as_blend_config::invertAlpha
pxp_alpha_mode_t _pxp_as_blend_config::alphaMode
pxp_rop_mode_t _pxp_as_blend_config::ropMode
pxp_csc2_mode_t _pxp_csc2_config::mode
float _pxp_csc2_config::A1
float _pxp_csc2_config::A2
float _pxp_csc2_config::A3
float _pxp_csc2_config::B1
float _pxp_csc2_config::B2
float _pxp_csc2_config::B3
float _pxp_csc2_config::C1
float _pxp_csc2_config::C2
float _pxp_csc2_config::C3
int16_t _pxp_csc2_config::D1
int16_t _pxp_csc2_config::D2
int16_t _pxp_csc2_config::D3
pxp_lut_lookup_mode_t _pxp_lut_config::lookupMode
pxp_lut_out_mode_t _pxp_lut_config::outMode
uint32_t _pxp_lut_config::cfaValue
uint32_t _pxp_dither_final_lut_data::data_3_0
uint32_t _pxp_dither_final_lut_data::data_7_4
uint32_t _pxp_dither_final_lut_data::data_11_8
uint32_t _pxp_dither_final_lut_data::data_15_12
uint32_t _pxp_dither_config::enableDither0: 1
uint32_t _pxp_dither_config::enableDither1: 1
uint32_t _pxp_dither_config::enableDither2: 1
uint32_t _pxp_dither_config::ditherMode0: 3
uint32_t _pxp_dither_config::ditherMode1: 3
uint32_t _pxp_dither_config::ditherMode2: 3
uint32_t _pxp_dither_config::quantBitNum: 3
uint32_t _pxp_dither_config::lutMode: 2
uint32_t _pxp_dither_config::idxMatrixSize0: 2
uint32_t _pxp_dither_config::idxMatrixSize1: 2
uint32_t _pxp_dither_config::idxMatrixSize2: 2
uint32_t _pxp_dither_config::enableFinalLut: 1
uint32_t _pxp_dither_config::__pad0__: 8
uint32_t pxp_porter_duff_config_t::enable: 1
uint32_t pxp_porter_duff_config_t::srcFactorMode: 2
uint32_t pxp_porter_duff_config_t::dstGlobalAlphaMode: 2
uint32_t pxp_porter_duff_config_t::dstAlphaMode: 1
uint32_t pxp_porter_duff_config_t::dstColorMode: 1
uint32_t pxp_porter_duff_config_t::__pad0__: 1
uint32_t pxp_porter_duff_config_t::dstFactorMode: 2
uint32_t pxp_porter_duff_config_t::srcGlobalAlphaMode: 2
uint32_t pxp_porter_duff_config_t::srcAlphaMode: 1
uint32_t pxp_porter_duff_config_t::srcColorMode: 1
uint32_t pxp_porter_duff_config_t::__pad1__: 2
uint32_t pxp_porter_duff_config_t::dstGlobalAlpha: 8
uint32_t pxp_porter_duff_config_t::srcGlobalAlpha: 8
uint32_t _pxp_pic_copy_config::srcPicBaseAddr
uint16_t _pxp_pic_copy_config::srcPitchBytes
uint16_t _pxp_pic_copy_config::srcOffsetX
uint16_t _pxp_pic_copy_config::srcOffsetY
uint32_t _pxp_pic_copy_config::destPicBaseAddr
uint16_t _pxp_pic_copy_config::destPitchBytes
uint16_t _pxp_pic_copy_config::destOffsetX
uint16_t _pxp_pic_copy_config::destOffsetY
uint16_t _pxp_pic_copy_config::width
uint16_t _pxp_pic_copy_config::height
pxp_as_pixel_format_t _pxp_pic_copy_config::pixelFormat
Driver version
enum  _pxp_interrupt_enable { kPXP_CompleteInterruptEnable = PXP_CTRL_IRQ_ENABLE_MASK , kPXP_CommandLoadInterruptEnable = PXP_CTRL_NEXT_IRQ_ENABLE_MASK , kPXP_LutDmaLoadInterruptEnable }
 PXP interrupts to enable. More...
enum  _pxp_flags {
  kPXP_CompleteFlag = PXP_STAT_IRQ0_MASK , kPXP_Axi0WriteErrorFlag = PXP_STAT_AXI_WRITE_ERROR_0_MASK , kPXP_Axi0ReadErrorFlag = PXP_STAT_AXI_READ_ERROR_0_MASK , kPXP_CommandLoadFlag = PXP_STAT_NEXT_IRQ_MASK ,
  kPXP_LutDmaLoadFlag = PXP_STAT_LUT_DMA_LOAD_DONE_IRQ_MASK
 PXP status flags. More...
enum  _pxp_flip_mode { kPXP_FlipDisable = 0U , kPXP_FlipHorizontal = 0x01U , kPXP_FlipVertical = 0x02U , kPXP_FlipBoth = 0x03U }
 PXP output flip mode. More...
enum  _pxp_rotate_position { kPXP_RotateOutputBuffer = 0U , kPXP_RotateProcessSurface }
 PXP rotate mode. More...
enum  _pxp_rotate_degree { kPXP_Rotate0 = 0U , kPXP_Rotate90 , kPXP_Rotate180 , kPXP_Rotate270 }
 PXP rotate degree. More...
enum  _pxp_interlaced_output_mode { kPXP_OutputProgressive = 0U , kPXP_OutputField0 , kPXP_OutputField1 , kPXP_OutputInterlaced }
 PXP interlaced output mode. More...
enum  _pxp_output_pixel_format {
  kPXP_OutputPixelFormatARGB8888 = 0x0 , kPXP_OutputPixelFormatRGB888 = 0x4 , kPXP_OutputPixelFormatRGB888P = 0x5 , kPXP_OutputPixelFormatARGB1555 = 0x8 ,
  kPXP_OutputPixelFormatARGB4444 = 0x9 , kPXP_OutputPixelFormatRGB555 = 0xC , kPXP_OutputPixelFormatRGB444 = 0xD , kPXP_OutputPixelFormatRGB565 = 0xE ,
  kPXP_OutputPixelFormatYUV1P444 = 0x10 , kPXP_OutputPixelFormatUYVY1P422 = 0x12 , kPXP_OutputPixelFormatVYUY1P422 = 0x13 , kPXP_OutputPixelFormatY8 = 0x14 ,
  kPXP_OutputPixelFormatY4 = 0x15 , kPXP_OutputPixelFormatYUV2P422 = 0x18 , kPXP_OutputPixelFormatYUV2P420 = 0x19 , kPXP_OutputPixelFormatYVU2P422 = 0x1A ,
  kPXP_OutputPixelFormatYVU2P420 = 0x1B
 PXP output buffer format. More...
enum  _pxp_ps_pixel_format {
  kPXP_PsPixelFormatRGB888 = 0x4 , kPXP_PsPixelFormatRGB555 = 0xC , kPXP_PsPixelFormatRGB444 = 0xD , kPXP_PsPixelFormatRGB565 = 0xE ,
  kPXP_PsPixelFormatYUV1P444 = 0x10 , kPXP_PsPixelFormatUYVY1P422 = 0x12 , kPXP_PsPixelFormatVYUY1P422 = 0x13 , kPXP_PsPixelFormatY8 = 0x14 ,
  kPXP_PsPixelFormatY4 = 0x15 , kPXP_PsPixelFormatYUV2P422 = 0x18 , kPXP_PsPixelFormatYUV2P420 = 0x19 , kPXP_PsPixelFormatYVU2P422 = 0x1A ,
  kPXP_PsPixelFormatYVU2P420 = 0x1B , kPXP_PsPixelFormatYVU422 = 0x1E , kPXP_PsPixelFormatYVU420 = 0x1F
 PXP process surface buffer pixel format. More...
enum  _pxp_ps_yuv_format { kPXP_PsYUVFormatYUV = 0U , kPXP_PsYUVFormatYCbCr }
 PXP process surface buffer YUV format. More...
enum  _pxp_as_pixel_format {
  kPXP_AsPixelFormatARGB8888 = 0x0 , kPXP_AsPixelFormatRGB888 = 0x4 , kPXP_AsPixelFormatARGB1555 = 0x8 , kPXP_AsPixelFormatARGB4444 = 0x9 ,
  kPXP_AsPixelFormatRGB555 = 0xC , kPXP_AsPixelFormatRGB444 = 0xD , kPXP_AsPixelFormatRGB565 = 0xE
 PXP alpha surface buffer pixel format. More...
enum  _pxp_alpha_mode { kPXP_AlphaEmbedded , kPXP_AlphaOverride , kPXP_AlphaMultiply , kPXP_AlphaRop }
 PXP alpha mode during blending. More...
enum  _pxp_rop_mode {
  kPXP_RopMaskAs = 0x0 , kPXP_RopMaskNotAs = 0x1 , kPXP_RopMaskAsNot = 0x2 , kPXP_RopMergeAs = 0x3 ,
  kPXP_RopMergeNotAs = 0x4 , kPXP_RopMergeAsNot = 0x5 , kPXP_RopNotCopyAs = 0x6 , kPXP_RopNot = 0x7 ,
  kPXP_RopNotMaskAs = 0x8 , kPXP_RopNotMergeAs = 0x9 , kPXP_RopXorAs = 0xA , kPXP_RopNotXorAs = 0xB
 PXP ROP mode during blending. More...
enum  _pxp_block_size { kPXP_BlockSize8 = 0U , kPXP_BlockSize16 }
 PXP process block size. More...
enum  _pxp_csc1_mode { kPXP_Csc1YUV2RGB = 0U , kPXP_Csc1YCbCr2RGB }
 PXP CSC1 mode. More...
enum  _pxp_csc2_mode { kPXP_Csc2YUV2RGB = 0U , kPXP_Csc2YCbCr2RGB , kPXP_Csc2RGB2YUV , kPXP_Csc2RGB2YCbCr }
 PXP CSC2 mode. More...
enum  _pxp_lut_lookup_mode { kPXP_LutCacheRGB565 = 0U , kPXP_LutDirectY8 , kPXP_LutDirectRGB444 , kPXP_LutDirectRGB454 }
 PXP LUT lookup mode. More...
enum  _pxp_lut_out_mode { kPXP_LutOutY8 = 1U , kPXP_LutOutRGBW4444CFA , kPXP_LutOutRGB888 }
 PXP LUT output mode. More...
enum  _pxp_lut_8k_bank { kPXP_Lut8kBank0 = 0U , kPXP_Lut8kBank1 }
 PXP LUT 8K bank index used when lookup mode is kPXP_LutDirectRGB444. More...
enum  _pxp_ram { kPXP_RamDither0Lut = 0U , kPXP_RamDither1Lut = 3U , kPXP_RamDither2Lut = 4U }
 PXP internal memory. More...
enum  _pxp_dither_mode {
  kPXP_DitherPassThrough = 0U , kPXP_DitherFloydSteinberg = 1U , kPXP_DitherAtkinson = 2U , kPXP_DitherOrdered = 3U ,
  kPXP_DitherQuantOnly = 4U , kPXP_DitherSierra = 5U
 PXP dither mode. More...
enum  _pxp_dither_lut_mode { kPXP_DitherLutOff = 0U , kPXP_DitherLutPreDither , kPXP_DitherLutPostDither }
 PXP dither LUT mode. More...
enum  _pxp_dither_matrix_size { kPXP_DitherMatrix4 = 0 , kPXP_DitherMatrix8 , kPXP_DitherMatrix16 }
 PXP dither matrix size. More...
enum  { kPXP_PorterDuffFactorOne = 0U , kPXP_PorterDuffFactorZero , kPXP_PorterDuffFactorStraight , kPXP_PorterDuffFactorInversed }
 Porter Duff factor mode. . More...
enum  { kPXP_PorterDuffGlobalAlpha = 0U , kPXP_PorterDuffLocalAlpha , kPXP_PorterDuffScaledAlpha }
 Porter Duff global alpha mode. . More...
enum  { kPXP_PorterDuffAlphaStraight = 0U , kPXP_PorterDuffAlphaInversed }
 Porter Duff alpha mode. . More...
enum  { kPXP_PorterDuffColorStraight = 0 , kPXP_PorterDuffColorInversed = 1 , kPXP_PorterDuffColorNoAlpha = 0 , kPXP_PorterDuffColorWithAlpha = 1 }
 Porter Duff color mode. . More...
enum  _pxp_porter_duff_blend_mode {
  kPXP_PorterDuffSrc = 0 , kPXP_PorterDuffAtop , kPXP_PorterDuffOver , kPXP_PorterDuffIn ,
  kPXP_PorterDuffOut , kPXP_PorterDuffDst , kPXP_PorterDuffDstAtop , kPXP_PorterDuffDstOver ,
  kPXP_PorterDuffDstIn , kPXP_PorterDuffDstOut , kPXP_PorterDuffXor , kPXP_PorterDuffClear ,
  kPXP_PorterDuffMax
typedef enum _pxp_flip_mode pxp_flip_mode_t
typedef enum _pxp_rotate_position pxp_rotate_position_t
 PXP rotate mode.
typedef enum _pxp_rotate_degree pxp_rotate_degree_t
 PXP rotate degree.
typedef enum _pxp_interlaced_output_mode pxp_interlaced_output_mode_t
typedef enum _pxp_output_pixel_format pxp_output_pixel_format_t
typedef struct _pxp_output_buffer_config pxp_output_buffer_config_t
typedef enum _pxp_ps_pixel_format pxp_ps_pixel_format_t
typedef enum _pxp_ps_yuv_format pxp_ps_yuv_format_t
typedef struct _pxp_ps_buffer_config pxp_ps_buffer_config_t
typedef enum _pxp_as_pixel_format pxp_as_pixel_format_t
typedef struct _pxp_as_buffer_config pxp_as_buffer_config_t
typedef enum _pxp_alpha_mode pxp_alpha_mode_t
typedef enum _pxp_rop_mode pxp_rop_mode_t
typedef struct _pxp_as_blend_config pxp_as_blend_config_t
typedef enum _pxp_block_size pxp_block_size_t
typedef enum _pxp_csc1_mode pxp_csc1_mode_t
 PXP CSC1 mode.
typedef enum _pxp_csc2_mode pxp_csc2_mode_t
 PXP CSC2 mode.
typedef struct _pxp_csc2_config pxp_csc2_config_t
typedef enum _pxp_lut_lookup_mode pxp_lut_lookup_mode_t
typedef enum _pxp_lut_out_mode pxp_lut_out_mode_t
typedef enum _pxp_lut_8k_bank pxp_lut_8k_bank_t
typedef struct _pxp_lut_config pxp_lut_config_t
typedef enum _pxp_ram pxp_ram_t
typedef struct _pxp_dither_final_lut_data pxp_dither_final_lut_data_t
typedef struct _pxp_dither_config pxp_dither_config_t
typedef enum _pxp_porter_duff_blend_mode pxp_porter_duff_blend_mode_t
typedef struct _pxp_pic_copy_config pxp_pic_copy_config_t
#define FSL_PXP_DRIVER_VERSION   (MAKE_VERSION(2, 4, 1))
#define PXP_SHARE_ROTATE   0
#define PXP_USE_PATH   0
Initialization and deinitialization
void PXP_Init (PXP_Type *base)
 Initialize the PXP.
void PXP_Deinit (PXP_Type *base)
 De-initialize the PXP.
void PXP_Reset (PXP_Type *base)
 Reset the PXP.
void PXP_ResetControl (PXP_Type *base)
 Reset the PXP and the control register to initialized state.
Alpha surface
void PXP_SetAlphaSurfaceBufferConfig (PXP_Type *base, const pxp_as_buffer_config_t *config)
 Set the alpha surface input buffer configuration.
void PXP_SetAlphaSurfaceBlendConfig (PXP_Type *base, const pxp_as_blend_config_t *config)
 Set the alpha surface blending configuration.
void PXP_SetAlphaSurfaceOverlayColorKey (PXP_Type *base, uint32_t colorKeyLow, uint32_t colorKeyHigh)
 Set the alpha surface overlay color key.
void PXP_SetAlphaSurfacePosition (PXP_Type *base, uint16_t upperLeftX, uint16_t upperLeftY, uint16_t lowerRightX, uint16_t lowerRightY)
 Set the alpha surface position in output buffer.
Process surface
void PXP_SetProcessSurfaceBufferConfig (PXP_Type *base, const pxp_ps_buffer_config_t *config)
 Set the process surface input buffer configuration.
void PXP_SetProcessSurfaceScaler (PXP_Type *base, uint16_t inputWidth, uint16_t inputHeight, uint16_t outputWidth, uint16_t outputHeight)
 Set the process surface scaler configuration.
void PXP_SetProcessSurfacePosition (PXP_Type *base, uint16_t upperLeftX, uint16_t upperLeftY, uint16_t lowerRightX, uint16_t lowerRightY)
 Set the process surface position in output buffer.
void PXP_SetProcessSurfaceColorKey (PXP_Type *base, uint32_t colorKeyLow, uint32_t colorKeyHigh)
 Set the process surface color key.
Output buffer
void PXP_SetOutputBufferConfig (PXP_Type *base, const pxp_output_buffer_config_t *config)
 Set the PXP outpt buffer configuration.
void PXP_BuildRect (PXP_Type *base, pxp_output_pixel_format_t outFormat, uint32_t value, uint16_t width, uint16_t height, uint16_t pitch, uint32_t outAddr)
 Build a solid rectangle of given pixel value.
Command queue
void PXP_SetNextCommand (PXP_Type *base, void *commandAddr)
 Set the next command.
Color space conversion
void PXP_SetCsc2Config (PXP_Type *base, const pxp_csc2_config_t *config)
 Set the CSC2 configuration.
void PXP_SetCsc1Mode (PXP_Type *base, pxp_csc1_mode_t mode)
 Set the CSC1 mode.
LUT operations
void PXP_SetLutConfig (PXP_Type *base, const pxp_lut_config_t *config)
 Set the LUT configuration.
status_t PXP_LoadLutTable (PXP_Type *base, pxp_lut_lookup_mode_t lookupMode, uint32_t bytesNum, uint32_t memAddr, uint16_t lutStartAddr)
 Set the look up table to PXP.
Porter Duff
void PXP_SetPorterDuffConfig (PXP_Type *base, const pxp_porter_duff_config_t *config)
 Set the Porter Duff configuration.
status_t PXP_GetPorterDuffConfig (pxp_porter_duff_blend_mode_t mode, pxp_porter_duff_config_t *config)
 Get the Porter Duff configuration by blend mode.
Buffer copy
status_t PXP_StartPictureCopy (PXP_Type *base, const pxp_pic_copy_config_t *config)
 Copy picture from one buffer to another buffer.
status_t PXP_StartMemCopy (PXP_Type *base, uint32_t srcAddr, uint32_t destAddr, uint32_t size)
 Copy continous memory.
status_t PXP_MemCopy (PXP_Type *base, uint32_t srcAddr, uint32_t destAddr, uint32_t size)
Typedef Documentation
◆ pxp_csc2_config_t
Converting from YUV/YCbCr color spaces to the RGB color space uses the following equation structure:
R = A1(Y+D1) + A2(U+D2) + A3(V+D3) G = B1(Y+D1) + B2(U+D2) + B3(V+D3) B = C1(Y+D1) + C2(U+D2) + C3(V+D3)
Converting from the RGB color space to YUV/YCbCr color spaces uses the following equation structure:
Y = A1*R + A2*G + A3*B + D1 U = B1*R + B2*G + B3*B + D2 V = C1*R + C2*G + C3*B + D3
◆ pxp_rop_mode_t
Explanation:
  • AS: Alpha surface
  • PS: Process surface
  • nAS: Alpha surface NOT value
  • nPS: Process surface NOT value
◆ anonymous enum
anonymous enum
Use 1.
Use 0.
Use straight alpha.
Use inversed alpha.
◆ anonymous enum
anonymous enum
Use global alpha.
Use local alpha in each pixel.
Use global alpha * local alpha.
◆ anonymous enum
anonymous enum
Use straight alpha, s0_alpha' = s0_alpha.
Use inversed alpha, s0_alpha' = 0xFF - s0_alpha.
◆ anonymous enum
anonymous enum
Deprecated:
Use kPXP_PorterDuffColorNoAlpha.
Deprecated:
Use kPXP_PorterDuffColorWithAlpha.
s0_pixel' = s0_pixel.
s0_pixel' = s0_pixel * s0_alpha".
◆ _pxp_alpha_mode
kPXP_AlphaEmbedded
The alpha surface pixel alpha value will be used for blend.
kPXP_AlphaOverride
The user defined alpha value will be used for blend directly.
kPXP_AlphaMultiply
The alpha surface pixel alpha value scaled the user defined alpha value will be used for blend, for example, pixel alpha set set to 200, user defined alpha set to 100, then the reault alpha is 200 * 100 / 255.
kPXP_AlphaRop
Raster operation.
◆ _pxp_as_pixel_format
32-bit pixels with alpha.
32-bit pixels without alpha (unpacked 24-bit format)
16-bit pixels with alpha.
16-bit pixels without alpha.
◆ _pxp_block_size
kPXP_BlockSize8
Process 8x8 pixel blocks.
kPXP_BlockSize16
Process 16x16 pixel blocks.
◆ _pxp_csc1_mode
PXP CSC1 mode.
kPXP_Csc1YUV2RGB
YUV to RGB.
kPXP_Csc1YCbCr2RGB
YCbCr to RGB.
◆ _pxp_csc2_mode
PXP CSC2 mode.
kPXP_Csc2YUV2RGB
YUV to RGB.
kPXP_Csc2YCbCr2RGB
YCbCr to RGB.
kPXP_Csc2RGB2YUV
RGB to YUV.
kPXP_Csc2RGB2YCbCr
RGB to YCbCr.
◆ _pxp_dither_lut_mode
kPXP_DitherLutOff
The LUT memory is not used for LUT, could be used as ordered dither index matrix.
Use LUT at the pre-dither stage, The pre-dither LUT could only be used in Floyd mode or Atkinson mode, which are not supported by current PXP module.
Use LUT at the post-dither stage.
◆ _pxp_dither_matrix_size
kPXP_DitherMatrix4
The dither index matrix is 4x4.
kPXP_DitherMatrix8
The dither index matrix is 8x8.
kPXP_DitherMatrix16
The dither index matrix is 16x16.
◆ _pxp_dither_mode
PXP dither mode.
Pass through, no dither.
Floyd-Steinberg. For dither engine 0 only.
kPXP_DitherAtkinson
Atkinson. For dither engine 0 only.
kPXP_DitherOrdered
Ordered dither.
No dithering, only quantization.
kPXP_DitherSierra
Sierra. For dither engine 0 only.
◆ _pxp_flags
enum _pxp_flags
PXP status flags.
Note
These enumerations are meant to be OR'd together to form a bit mask.
kPXP_CompleteFlag
PXP process completed. bit 0
PXP encountered an AXI write error and processing has been terminated. bit 1
PXP encountered an AXI read error and processing has been terminated. bit 2
The command set by PXP_SetNextCommand has been loaded, could set new command. bit 3
kPXP_LutDmaLoadFlag
The LUT table has been loaded by DMA. bit 8
◆ _pxp_flip_mode
kPXP_FlipDisable
Flip disable.
kPXP_FlipHorizontal
Horizontal flip.
kPXP_FlipVertical
Vertical flip.
kPXP_FlipBoth
Flip both directions.
◆ _pxp_interlaced_output_mode
All data written in progressive format to output buffer 0.
kPXP_OutputField0
Only write field 0 data to output buffer 0.
kPXP_OutputField1
Only write field 1 data to output buffer 0.
Field 0 write to buffer 0, field 1 write to buffer 1.
◆ _pxp_interrupt_enable
PXP process completed. bit 1
Interrupt to show that the command set by PXP_SetNextCommand has been loaded. bit 2
The LUT table has been loaded by DMA. bit 3
◆ _pxp_lut_8k_bank
kPXP_Lut8kBank0
The first 8K bank used.
kPXP_Lut8kBank1
The second 8K bank used.
◆ _pxp_lut_lookup_mode
kPXP_LutCacheRGB565
LUT ADDR = R[7:3],G[7:2],B[7:3]. Use all 16KB of LUT for indirect cached 128KB lookup.
kPXP_LutDirectY8
LUT ADDR = 16'b0,Y[7:0]. Use the first 256 bytes of LUT. Only third data path byte is tranformed.
LUT ADDR = R[7:4],G[7:4],B[7:4]. Use one 8KB bank of LUT selected by PXP_Select8kLutBank.
LUT ADDR = R[7:4],G[7:3],B[7:4]. Use all 16KB of LUT.
◆ _pxp_lut_out_mode
kPXP_LutOutY8
R/Y byte lane 2 lookup, bytes 1,0 bypassed.
Byte lane 2 = CFA_Y8, byte lane 1,0 = RGBW4444.
kPXP_LutOutRGB888
RGB565->RGB888 conversion for Gamma correction.
◆ _pxp_output_pixel_format
24-bit pixels without alpha (packed 24-bit format)
32-bit pixels (1-plane XYUV unpacked).
16-bit pixels (1-plane U0,Y0,V0,Y1 interleaved bytes)
16-bit pixels (1-plane V0,Y0,U0,Y1 interleaved bytes)
8-bit monochrome pixels (1-plane Y luma output)
4-bit monochrome pixels (1-plane Y luma, 4 bit truncation)
16-bit pixels (2-plane UV interleaved bytes)
16-bit pixels (2-plane UV)
16-bit pixels (2-plane VU interleaved bytes)
16-bit pixels (2-plane VU)
◆ _pxp_porter_duff_blend_mode
kPXP_PorterDuffSrc
Source Only
kPXP_PorterDuffAtop
Source Atop
kPXP_PorterDuffOver
Source Over
kPXP_PorterDuffIn
Source In.
kPXP_PorterDuffOut
Source Out.
kPXP_PorterDuffDst
Destination Only.
Destination Atop.
Destination Over.
Destination In.
Destination Out.
kPXP_PorterDuffXor
XOR.
Clear.
◆ _pxp_ps_pixel_format
16-bit pixels (3-plane)
◆ _pxp_ps_yuv_format
kPXP_PsYUVFormatYUV
YUV format.
YCbCr format.
◆ _pxp_ram
enum _pxp_ram
kPXP_RamDither0Lut
Dither 0 LUT memory.
kPXP_RamDither1Lut
Dither 1 LUT memory.
kPXP_RamDither2Lut
Dither 2 LUT memory.
◆ _pxp_rop_mode
Explanation:
  • AS: Alpha surface
kPXP_RopMaskAs
AS AND PS.
kPXP_RopMaskNotAs
nAS AND PS.
kPXP_RopMaskAsNot
AS AND nPS.
kPXP_RopMergeAs
AS OR PS.
kPXP_RopMergeNotAs
nAS OR PS.
kPXP_RopMergeAsNot
AS OR nPS.
kPXP_RopNotCopyAs
nAS.
kPXP_RopNot
nPS.
kPXP_RopNotMaskAs
AS NAND PS.
kPXP_RopNotMergeAs
AS NOR PS.
kPXP_RopXorAs
AS XOR PS.
kPXP_RopNotXorAs
AS XNOR PS.
◆ _pxp_rotate_degree
PXP rotate degree.
kPXP_Rotate0
Clock wise rotate 0 deg.
kPXP_Rotate90
Clock wise rotate 90 deg.
kPXP_Rotate180
Clock wise rotate 180 deg.
kPXP_Rotate270
Clock wise rotate 270 deg.
◆ _pxp_rotate_position
PXP rotate mode.
Rotate the output buffer.
Rotate the process surface.
◆ PXP_BuildRect()
void PXP_BuildRect ( PXP_Type base,
uint32_t  value,
uint16_t  width,
uint16_t  height,
uint16_t  pitch,
uint32_t  outAddr
Parameters
basePXP peripheral base address.
outFormatoutput pixel format.
valueThe value of the pixel to be filled in the rectangle in ARGB8888 format.
widthwidth of the rectangle.
heightheight of the rectangle.
pitchoutput pitch in byte.
outAddraddress of the memory to store the rectangle.
brief Build a solid rectangle of given pixel value.
param base PXP peripheral base address. param outFormat output pixel format. param value The value of the pixel to be filled in the rectangle in ARGB8888 format. param width width of the rectangle. param height height of the rectangle. param pitch output pitch in byte. param outAddr address of the memory to store the rectangle.
◆ PXP_Deinit()
void PXP_Deinit ( PXP_Type base)
This function disables the PXP peripheral clock.
Parameters
brief De-initialize the PXP.
◆ PXP_GetPorterDuffConfig()
status_t PXP_GetPorterDuffConfig ( pxp_porter_duff_blend_mode_t  mode,
pxp_porter_duff_config_t config
The FactorMode are selected based on blend mode, the AlphaMode are set to kPXP_PorterDuffAlphaStraight, the ColorMode are set to kPXP_PorterDuffColorWithAlpha, the GlobalAlphaMode are set to kPXP_PorterDuffLocalAlpha. These values could be modified after calling this function.
Parameters
modeThe blend mode.
configPointer to the configuration.
Return values
kStatus_SuccessSuccessfully get the configuratoin.
kStatus_InvalidArgumentThe blend mode not supported.
brief Get the Porter Duff configuration by blend mode.
param mode The blend mode. param config Pointer to the configuration. retval kStatus_Success Successfully get the configuratoin. retval kStatus_InvalidArgument The blend mode not supported.
◆ PXP_Init()
void PXP_Init ( PXP_Type base)
Initialize the PXP.
This function enables the PXP peripheral clock, and resets the PXP registers to default status.
Parameters
brief Initialize the PXP.
◆ PXP_LoadLutTable()
status_t PXP_LoadLutTable ( PXP_Type base,
uint32_t  bytesNum,
uint32_t  memAddr,
If lookup mode is DIRECT mode, this function loads bytesNum of values from the address memAddr into PXP LUT address lutStartAddr. So this function allows only update part of the PXP LUT.
If lookup mode is CACHE mode, this function sets the new address to memAddr and invalid the PXP LUT cache.
Parameters
lookupModeWhich lookup mode is used. Note that this parameter is only used to distinguish DIRECT mode and CACHE mode, it does not change the register value PXP_LUT_CTRL[LOOKUP_MODE]. To change that value, use function PXP_SetLutConfig.
bytesNumHow many bytes to set. This value must be divisable by 8.
memAddrAddress of look up table to set.
lutStartAddrThe LUT value will be loaded to LUT from index lutAddr. It should be 8 bytes aligned.
Return values
kStatus_SuccessLoad successfully.
kStatus_InvalidArgumentFailed because of invalid argument.
brief Set the look up table to PXP.
If lookup mode is DIRECT mode, this function loads p bytesNum of values from the address p memAddr into PXP LUT address p lutStartAddr. So this function allows only update part of the PXP LUT.
If lookup mode is CACHE mode, this function sets the new address to p memAddr and invalid the PXP LUT cache.
param base PXP peripheral base address. param lookupMode Which lookup mode is used. Note that this parameter is only used to distinguish DIRECT mode and CACHE mode, it does not change the register value PXP_LUT_CTRL[LOOKUP_MODE]. To change that value, use function ref PXP_SetLutConfig. param bytesNum How many bytes to set. This value must be divisable by 8. param memAddr Address of look up table to set. param lutStartAddr The LUT value will be loaded to LUT from index lutAddr. It should be 8 bytes aligned.
retval kStatus_Success Load successfully. retval kStatus_InvalidArgument Failed because of invalid argument.
◆ PXP_MemCopy()
status_t PXP_MemCopy ( PXP_Type base,
uint32_t  srcAddr,
uint32_t  destAddr,
uint32_t  size
Note
This function resets the old PXP settings, which means the settings like rotate, flip, will be reseted to disabled status.
Compare with @PXP_StartMemCopy, this function supports size not aligned to 512 bytes. This function returns when copy finished, upper layer doesn't need to wait kPXP_CompleteFlag.
Parameters
srcAddrSource memory address.
destAddrDestination memory address.
sizeHow many bytes to copy, should be 512 byte aligned.
Return values
kStatus_SuccessSuccessfully started the copy process.
kStatus_InvalidArgumentInvalid argument.
brief Copy continous memory.
param base PXP peripheral base address. retval kStatus_Success Successfully started the copy process. retval kStatus_InvalidArgument Invalid argument.
◆ PXP_Reset()
void PXP_Reset ( PXP_Type base)
Reset the PXP.
This function resets the PXP peripheral registers to default status.
Parameters
brief Reset the PXP.
◆ PXP_ResetControl()
void PXP_ResetControl ( PXP_Type base)
Parameters
brief Reset the PXP and the control register to initialized state.
◆ PXP_SetAlphaSurfaceBlendConfig()
void PXP_SetAlphaSurfaceBlendConfig ( PXP_Type base,
const pxp_as_blend_config_t config
Parameters
configPointer to the configuration structure.
brief Set the alpha surface blending configuration.
param base PXP peripheral base address. param config Pointer to the configuration structure.
◆ PXP_SetAlphaSurfaceBufferConfig()
void PXP_SetAlphaSurfaceBufferConfig ( PXP_Type base,
const pxp_as_buffer_config_t config
Parameters
brief Set the alpha surface input buffer configuration.
param base PXP peripheral base address. param config Pointer to the configuration.
◆ PXP_SetAlphaSurfaceOverlayColorKey()
void PXP_SetAlphaSurfaceOverlayColorKey ( PXP_Type base,
If a pixel in the current overlay image with a color that falls in the range from the p colorKeyLow to p colorKeyHigh range, it will use the process surface pixel value for that location. If no PS image is present or if the PS image also matches its colorkey range, the PS background color is used.
Parameters
colorKeyLowColor key low range.
colorKeyHighColor key high range.
Note
Colorkey operations are higher priority than alpha or ROP operations
brief Set the alpha surface overlay color key.
param base PXP peripheral base address. param colorKeyLow Color key low range. param colorKeyHigh Color key high range.
note Colorkey operations are higher priority than alpha or ROP operations
◆ PXP_SetAlphaSurfacePosition()
void PXP_SetAlphaSurfacePosition ( PXP_Type base,
Parameters
upperLeftXX of the upper left corner.
upperLeftYY of the upper left corner.
lowerRightXX of the lower right corner.
lowerRightYY of the lower right corner.
brief Set the alpha surface position in output buffer.
param base PXP peripheral base address. param upperLeftX X of the upper left corner. param upperLeftY Y of the upper left corner. param lowerRightX X of the lower right corner. param lowerRightY Y of the lower right corner.
◆ PXP_SetCsc1Mode()
void PXP_SetCsc1Mode ( PXP_Type base,
Set the CSC1 mode.
The CSC1 module receives scaled YUV/YCbCr444 pixels from the scale engine and converts the pixels to the RGB888 color space. It could only be used by process surface.
Parameters
modeThe conversion mode.
brief Set the CSC1 mode.
param base PXP peripheral base address. param mode The conversion mode.
◆ PXP_SetCsc2Config()
void PXP_SetCsc2Config ( PXP_Type base,
const pxp_csc2_config_t config
The CSC2 module receives pixels in any color space and can convert the pixels into any of RGB, YUV, or YCbCr color spaces. The output pixels are passed onto the LUT and rotation engine for further processing
Parameters
brief Set the CSC2 configuration.
◆ PXP_SetLutConfig()
void PXP_SetLutConfig ( PXP_Type base,
const pxp_lut_config_t config
The lookup table (LUT) is used to modify pixels in a manner that is not linear and that cannot be achieved by the color space conversion modules. To setup the LUT, the complete workflow is:
  1. Use PXP_SetLutConfig to set the configuration, such as the lookup mode.
  2. Use PXP_LoadLutTable to load the lookup table to PXP.
  3. Use PXP_EnableLut to enable the function.
Parameters
brief Set the LUT configuration.
  1. Use ref PXP_SetLutConfig to set the configuration, such as the lookup mode.
  2. Use ref PXP_LoadLutTable to load the lookup table to PXP.
  3. Use ref PXP_EnableLut to enable the function.
◆ PXP_SetNextCommand()
void PXP_SetNextCommand ( PXP_Type base,
void *  commandAddr
The PXP supports a primitive ability to queue up one operation while the current operation is running. Workflow:
  1. Prepare the PXP register values except STAT, CSCCOEFn, NEXT in the memory in the order they appear in the register map.
  2. Call this function sets the new operation to PXP.
  3. There are two methods to check whether the PXP has loaded the new operation. The first method is using PXP_IsNextCommandPending. If there is new operation not loaded by the PXP, this function returns true. The second method is checking the flag kPXP_CommandLoadFlag, if command loaded, this flag asserts. User could enable interrupt kPXP_CommandLoadInterruptEnable to get the loaded signal in interrupt way.
  4. When command loaded by PXP, a new command could be set using this function.
uint32_t pxp_command1[48];
uint32_t pxp_command2[48];
pxp_command1[0] = ...;
pxp_command1[1] = ...;
pxp_command2[0] = ...;
pxp_command2[1] = ...;
while (PXP_IsNextCommandPending(PXP))
PXP_SetNextCommand(PXP, pxp_command1);
PXP_SetNextCommand(PXP, pxp_command2);
#define PXP
Definition: MIMXRT1052.h:39363
void PXP_SetNextCommand(PXP_Type *base, void *commandAddr)
Definition: fsl_pxp.c:736
Parameters
commandAddrAddress of the new command.
brief Set the next command.
  3. There are two methods to check whether the PXP has loaded the new operation. The first method is using ref PXP_IsNextCommandPending. If there is new operation not loaded by the PXP, this function returns true. The second method is checking the flag ref kPXP_CommandLoadFlag, if command loaded, this flag asserts. User could enable interrupt ref kPXP_CommandLoadInterruptEnable to get the loaded signal in interrupt way.
param base PXP peripheral base address. param commandAddr Address of the new command.
◆ PXP_SetOutputBufferConfig()
void PXP_SetOutputBufferConfig ( PXP_Type base,
const pxp_output_buffer_config_t config
Parameters
brief Set the PXP outpt buffer configuration.
◆ PXP_SetPorterDuffConfig()
void PXP_SetPorterDuffConfig ( PXP_Type base,
const pxp_porter_duff_config_t config
Parameters
brief Set the Porter Duff configuration.
◆ PXP_SetProcessSurfaceBufferConfig()
void PXP_SetProcessSurfaceBufferConfig ( PXP_Type base,
const pxp_ps_buffer_config_t config
Parameters
brief Set the process surface input buffer configuration.
◆ PXP_SetProcessSurfaceColorKey()
void PXP_SetProcessSurfaceColorKey ( PXP_Type base,
If the PS image matches colorkey range, the PS background color is output. Set colorKeyLow to 0xFFFFFFFF and colorKeyHigh to 0 will disable the colorkeying.
Parameters
brief Set the process surface color key.
If the PS image matches colorkey range, the PS background color is output. Set p colorKeyLow to 0xFFFFFFFF and p colorKeyHigh to 0 will disable the colorkeying.
◆ PXP_SetProcessSurfacePosition()
void PXP_SetProcessSurfacePosition ( PXP_Type base,
Parameters
brief Set the process surface position in output buffer.
◆ PXP_SetProcessSurfaceScaler()
void PXP_SetProcessSurfaceScaler ( PXP_Type base,
The valid down scale fact is 1/(2^12) ~ 16.
Parameters
inputWidthInput image width.
inputHeightInput image height.
outputWidthOutput image width.
outputHeightOutput image height.
brief Set the process surface scaler configuration.
param base PXP peripheral base address. param inputWidth Input image width. param inputHeight Input image height. param outputWidth Output image width. param outputHeight Output image height.
◆ PXP_StartMemCopy()
status_t PXP_StartMemCopy ( PXP_Type base,
uint32_t  srcAddr,
uint32_t  destAddr,
uint32_t  size
Note
The copy size should be 512 byte aligned.
Parameters
Return values
◆ PXP_StartPictureCopy()
status_t PXP_StartPictureCopy ( PXP_Type base,
const pxp_pic_copy_config_t config
This function copies a rectangle from one buffer to another buffer.
                   Source buffer:
srcPicBaseAddr
|  (srcOffsetX, srcOffsetY)                                 |
|           |                   | height                    |
|                 width                                     |
|                       srcPicthBytes                       |
                  Destination buffer:
destPicBaseAddr
|  (destOffsetX, destOffsetY)               |
|       |                   | height        |
|             width                         |
|                  destPicthBytes           |
Note
Parameters
configPointer to the picture copy configuration structure.
Return values
brief Copy picture from one buffer to another buffer.
Variable Documentation
◆ A1
A1.
◆ A2
A2.
◆ A3
A3.
◆ alpha
User defined alpha value, only used when alphaMode is kPXP_AlphaOverride or kPXP_AlphaRop.
◆ alphaMode
Alpha mode.
◆ B1
B1.
◆ B2
B2.
◆ B3
B3.
◆ buffer0Addr
Output buffer 0 address.
◆ buffer1Addr
Output buffer 1 address, used for UV data in YUV 2-plane mode, or field 1 in output interlaced mode.
◆ bufferAddr [1/2]
Input buffer address for the first panel.
◆ bufferAddr [2/2]
Input buffer address.
◆ bufferAddrU
Input buffer address for the second panel.
◆ bufferAddrV
Input buffer address for the third panel.
◆ C1
C1.
◆ C2
C2.
◆ C3
C3.
◆ cfaValue
The CFA value used when look up mode is kPXP_LutOutRGBW4444CFA.
◆ D1
D1.
◆ D2
D2.
◆ D3
D3.
◆ data_11_8
Data 11 to data 8. Data 8 is the least significant byte.
◆ data_15_12
Data 15 to data 12. Data 12 is the least significant byte.
◆ data_3_0
Data 3 to data 0. Data 0 is the least significant byte.
◆ data_7_4
Data 7 to data 4. Data 4 is the least significant byte.
◆ destOffsetX
Copy position in destination picture.
◆ destOffsetY
◆ destPicBaseAddr
Destination picture base address.
◆ destPitchBytes
Pitch of the destination buffer.
◆ ditherMode0
Dither mode for dither engine 0. See _pxp_dither_mode.
◆ ditherMode1
Dither mode for dither engine 1. See _pxp_dither_mode.
◆ ditherMode2
Dither mode for dither engine 2. See _pxp_dither_mode.
◆ dstAlphaMode
Destination layer (or PS, s0) alpha mode, see pxp_porter_duff_alpha_mode.
◆ dstColorMode
Destination layer (or PS, s0) color mode, see pxp_porter_duff_color_mode.
◆ dstFactorMode
Destination layer (or PS, s0) factor mode, see pxp_porter_duff_factor_mode.
◆ dstGlobalAlpha
Destination layer (or PS, s0) global alpha value, 0~255.
◆ dstGlobalAlphaMode
Destination layer (or PS, s0) global alpha mode, see pxp_porter_duff_global_alpha_mode.
◆ enable
Enable or disable Porter Duff.
◆ enableDither0
Enable dither engine 0 or not, set 1 to enable, 0 to disable.
◆ enableDither1
Enable dither engine 1 or not, set 1 to enable, 0 to disable.
◆ enableDither2
Enable dither engine 2 or not, set 1 to enable, 0 to disable.
◆ enableFinalLut
Enable the final LUT, set 1 to enable, 0 to disable.
◆ height [1/2]
How many lines in output buffer.
◆ height [2/2]
Lines to copy.
◆ idxMatrixSize0
Size of index matrix used for dither for dither engine 0, see _pxp_dither_matrix_size.
◆ idxMatrixSize1
Size of index matrix used for dither for dither engine 1, see _pxp_dither_matrix_size.
◆ idxMatrixSize2
Size of index matrix used for dither for dither engine 2, see _pxp_dither_matrix_size.
◆ interlacedMode
Interlaced output mode.
◆ invertAlpha
Set true to invert the alpha.
◆ lookupMode
Look up mode.
◆ lutMode
How to use the memory LUT, see _pxp_dither_lut_mode. This must be set to kPXP_DitherLutOff if any dither engine uses kPXP_DitherOrdered mode.
◆ mode
Convertion mode.
◆ outMode
Out mode.
◆ pitchBytes [1/3]
Number of bytes between two vertically adjacent pixels.
◆ pitchBytes [2/3]
◆ pitchBytes [3/3]
◆ pixelFormat [1/4]
Output buffer pixel format.
◆ pixelFormat [2/4]
PS buffer pixel format.
◆ pixelFormat [3/4]
AS buffer pixel format.
◆ pixelFormat [4/4]
Buffer pixel format.
◆ quantBitNum
Number of bits quantize down to, the valid value is 1~7.
◆ ropMode
ROP mode, only valid when alphaMode is kPXP_AlphaRop.
◆ srcAlphaMode
Source layer (or AS, s1) alpha mode, see pxp_porter_duff_alpha_mode.
◆ srcColorMode
Source layer (or AS, s1) color mode, see pxp_porter_duff_color_mode.
◆ srcFactorMode
Source layer (or AS, s1) factor mode, see pxp_porter_duff_factor_mode.
◆ srcGlobalAlpha
Source layer (or AS, s1) global alpha value, 0~255.
◆ srcGlobalAlphaMode
Source layer (or AS, s1) global alpha mode, see pxp_porter_duff_global_alpha_mode.
◆ srcOffsetX
Copy position in source picture.
◆ srcOffsetY
◆ srcPicBaseAddr
Source picture base address.
◆ srcPitchBytes
Pitch of the source buffer.
◆ swapByte
For each 16 bit word, set true to swap the two bytes.
◆ width [1/2]
Pixels per line.
◆ width [2/2]
Pixel number each line to copy.
