RTEMS 6.1-rc2
Files | Functions
Print Memory Buffer
file  dumpbuf.c
 Dump Buffer.
void rtems_print_buffer (const unsigned char *buffer, int length)
 Print memory buffer.
◆ rtems_print_buffer()
void rtems_print_buffer ( const unsigned char *  buffer,
const int  length
This method prints length bytes beginning at buffer in a nice format similar to what one would expect from a debugger or ROM monitor.
Parameters
[in]bufferis the address of the buffer
[in]lengthis the length of the buffer
Non-printable chars will appear as dots.
Parameters
bufferThe buffer we'll print.
lengthAmount of bytes from buffer we'll print. This can't be unsigned because we don't have a way to check if we're erroneously getting a negative length.
