RTEMS 6.1-rc2
Data Structures | Enumerator | Variables
Kpp
struct  _kpp_config
 Lists of KPP status. More...
uint8_t _kpp_config::activeRow
uint8_t _kpp_config::activeColumn
uint16_t _kpp_config::interrupt
Driver version
enum  _kpp_interrupt_enable { kKPP_keyDepressInterrupt = KPP_KPSR_KDIE_MASK , kKPP_keyReleaseInterrupt = KPP_KPSR_KRIE_MASK }
 List of interrupts supported by the peripheral. This enumeration uses one-bot encoding to allow a logical OR of multiple members. Members usually map to interrupt enable bits in one or more peripheral registers. More...
enum  _kpp_sync_operation { kKPP_ClearKeyDepressSyncChain = KPP_KPSR_KDSC_MASK , kKPP_SetKeyReleasesSyncChain = KPP_KPSR_KRSS_MASK }
 Lists of KPP synchronize chain operation. More...
typedef enum _kpp_interrupt_enable kpp_interrupt_enable_t
typedef enum _kpp_sync_operation kpp_sync_operation_t
typedef struct _kpp_config kpp_config_t
#define FSL_KPP_DRIVER_VERSION   (MAKE_VERSION(2, 0, 0))
 KPP driver version 2.0.0.
#define KPP_KEYPAD_COLUMNNUM_MAX   (8U)
#define KPP_KEYPAD_ROWNUM_MAX   (8U)
Initialization and De-initialization
void KPP_Init (KPP_Type *base, kpp_config_t *configure)
 KPP initialize. This function ungates the KPP clock and initializes KPP. This function must be called before calling any other KPP driver functions.
void KPP_Deinit (KPP_Type *base)
 Deinitializes the KPP module and gates the clock. This function gates the KPP clock. As a result, the KPP module doesn't work after calling this function.
KPP Basic Operation
void KPP_keyPressScanning (KPP_Type *base, uint8_t *data, uint32_t clockSrc_Hz)
 Keypad press scanning.
◆ _kpp_interrupt_enable
Keypad depress interrupt source
Keypad release interrupt source
◆ _kpp_sync_operation
Keypad depress interrupt status.
Keypad release interrupt status.
◆ KPP_Deinit()
void KPP_Deinit ( KPP_Type base)
Parameters
baseKPP peripheral base address.
brief Deinitializes the KPP module and gates the clock. This function gates the KPP clock. As a result, the KPP module doesn't work after calling this function.
param base KPP peripheral base address.
◆ KPP_Init()
void KPP_Init ( KPP_Type base,
kpp_config_t configure
Parameters
configureThe KPP configuration structure pointer.
brief KPP initialize. This function ungates the KPP clock and initializes KPP. This function must be called before calling any other KPP driver functions.
param base KPP peripheral base address. param configure The KPP configuration structure pointer.
◆ KPP_keyPressScanning()
void KPP_keyPressScanning ( KPP_Type base,
uint8_t *  data,
This function will scanning all columns and rows. so all scanning data will be stored in the data pointer.
Parameters
dataKPP key press scanning data. The data buffer should be prepared with length at least equal to KPP_KEYPAD_COLUMNNUM_MAX * KPP_KEYPAD_ROWNUM_MAX. the data pointer is recommended to be a array like uint8_t data[KPP_KEYPAD_COLUMNNUM_MAX]. for example the data[2] = 4, that means in column 1 row 2 has a key press event.
clockSrc_HzSource clock.
brief Keypad press scanning.
param base KPP peripheral base address. param data KPP key press scanning data. The data buffer should be prepared with length at least equal to KPP_KEYPAD_COLUMNNUM_MAX * KPP_KEYPAD_ROWNUM_MAX. the data pointer is recommended to be a array like uint8_t data[KPP_KEYPAD_COLUMNNUM_MAX]. for example the data[2] = 4, that means in column 1 row 2 has a key press event. param clockSrc_Hz Source clock.
Variable Documentation
◆ activeColumn
The column number: bit 7 ~ 0 represents the column 7 ~ 0.
◆ activeRow
The row number: bit 7 ~ 0 represents the row 7 ~ 0.
◆ interrupt
KPP interrupt source. A logical OR of "kpp_interrupt_enable_t".
