RTEMS 6.1-rc2
struct | _domain_slot_config |
Key Manager slot configuration structure. More... | |
keymgr_lock_t | _domain_slot_config::lockControl |
keymgr_allow_t | _domain_slot_config::allowUser |
keymgr_allow_t | _domain_slot_config::allowNonSecure |
keymgr_lock_t | _domain_slot_config::lockList |
uint8_t | _domain_slot_config::whiteList |
Driver version | |
enum | _keymgr_lock { kKEYMGR_Unlock = 0u , kKEYMGR_Lock = 1u } |
enum | _keymgr_allow { kKEYMGR_Disallow = 0u , kKEYMGR_Allow = 1u } |
enum | _keymgr_slot { kKEYMGR_Slot0 = 0u , kKEYMGR_Slot1 = 1u , kKEYMGR_Slot2 = 2u , kKEYMGR_Slot3 = 3u , kKEYMGR_Slot4 = 4u } |
typedef enum _keymgr_lock | keymgr_lock_t |
typedef enum _keymgr_allow | keymgr_allow_t |
typedef enum _keymgr_slot | keymgr_slot_t |
typedef struct _domain_slot_config | domain_slot_config_t |
Key Manager slot configuration structure. | |
status_t | KEYMGR_MasterKeyControll (KEY_MANAGER_Type *base, keymgr_select_t select, keymgr_lock_t lock) |
Configures Master key settings. | |
status_t | KEYMGR_OTFAD1KeyControll (KEY_MANAGER_Type *base, keymgr_select_t select, keymgr_lock_t lock) |
Configures OTFAD1 key settings. | |
status_t | KEYMGR_OTFAD2KeyControll (KEY_MANAGER_Type *base, keymgr_select_t select, keymgr_lock_t lock) |
Configures OTFAD2 key settings. | |
void | KEYMGR_IEEKeyReload (KEY_MANAGER_Type *base) |
Restart load key signal for IEE. | |
void | KEYMGR_PUFKeyLock (KEY_MANAGER_Type *base, keymgr_lock_t lock) |
Lock the key select from PUF. | |
status_t | KEYMGR_SlotControl (KEY_MANAGER_Type *base, domain_slot_config_t *config, keymgr_slot_t slot) |
Configures Slot Domain control. | |
void | KEYMGR_Init (KEY_MANAGER_Type *base) |
Resets Key Manager module to factory default values. | |
status_t | KEYMGR_GetDefaultConfig (domain_slot_config_t *config) |
Sets the default configuration of Key manager slot. | |
#define | FSL_KEYMGR_DRIVER_VERSION (MAKE_VERSION(2, 0, 2)) |
Key Manager driver version. Version 2.0.2. | |
#define | KEYMGR_IEE_RELOAD 1u |
#define | KEYMGR_SEL_OCOTP 0u |
#define | KEYMGR_SEL_UDF 0u |
#define | KEYMGR_SEL_PUF 1u |
#define | keymgr_select_t uint8_t |
#define FSL_KEYMGR_DRIVER_VERSION (MAKE_VERSION(2, 0, 2)) |
Current version: 2.0.2
Change log:
status_t KEYMGR_GetDefaultConfig | ( | domain_slot_config_t * | config | ) |
This function initialize Key Manager slot config structure to default values.
config | Pointer to slot configuration structure. |
brief Sets the default configuration of Key manager slot.
param config Pointer to slot configuration structure.
void KEYMGR_IEEKeyReload | ( | KEY_MANAGER_Type * | base | ) |
This function genrates Key Manager's restart signal for IEE key.
base | Key Manager peripheral address. |
brief Restart load key signal for IEE.
param base Key Manager peripheral address.
void KEYMGR_Init | ( | KEY_MANAGER_Type * | base | ) |
This function performs hardware reset of Key Manager module.
brief Enables clock for Key Manager module.
This function enables clocks for Key Manager module.
status_t KEYMGR_MasterKeyControll | ( | KEY_MANAGER_Type * | base, |
keymgr_select_t | select, | ||
keymgr_lock_t | lock | ||
This function configures Key Manager's setting for Master key.
select | select source for Master key. |
lock | setting for lock Master key. |
brief Configures Master key settings.
param base Key Manager peripheral address. param select select source for Master key. param lock setting for lock Master key. return status of Master key control operation
status_t KEYMGR_OTFAD1KeyControll | ( | KEY_MANAGER_Type * | base, |
This function configures Key Manager's setting for OTFAD1 key.
select | select source for OTFAD1 key. |
lock | setting for lock OTFAD1 key. |
brief Configures OTFAD1 key settings.
param base Key Manager peripheral address. param select select source for OTFAD1 key. param lock setting for lock OTFAD1 key. return status of OTFAD1 key control operation
status_t KEYMGR_OTFAD2KeyControll | ( | KEY_MANAGER_Type * | base, |
This function configures Key Manager's setting for OTFAD2 key.
select | select source for OTFAD2 key. |
lock | setting for lock OTFAD2 key. |
brief Configures OTFAD2 key settings.
param base Key Manager peripheral address. param select select source for OTFAD2 key. param lock setting for lock OTFAD2 key. return status of OTFAD2 key control operation
void KEYMGR_PUFKeyLock | ( | KEY_MANAGER_Type * | base, |
This function locks selection of key for PUF.
lock | Setting for selection of key for PUF. |
brief Lock the key select from PUF.
status_t KEYMGR_SlotControl | ( | KEY_MANAGER_Type * | base, |
domain_slot_config_t * | config, | ||
keymgr_slot_t | slot | ||
This function configures domain slot control which locks and allows writes.
slot | Select slot to be configured. |
brief Configures Slot Domain control.
param base Key Manager peripheral address. param config Pointer to slot configuration structure. param slot Select slot to be configured.
keymgr_allow_t _domain_slot_config::allowNonSecure |
Allow non-secure write access to domain control register or domain register.
keymgr_allow_t _domain_slot_config::allowUser |
Allow user write access to domain control register or domain register.
keymgr_lock_t _domain_slot_config::lockControl |
Lock control register of slot.
keymgr_lock_t _domain_slot_config::lockList |
Lock whitelist. SLOTx_CTRL[WHITE_LIST] cannot be changed.
uint8_t _domain_slot_config::whiteList |
Domains that on the Whitelist can change given slot. Each field represents one domain. Bit0~Bit3 represent DOMAIN0~DOMAIN3 respectively.
