RTEMS 6.1-rc2
#define | ctz(u) |
Counts the trailing zero bits of the given value considered as a 32-bit integer. | |
Interrupt Service Routine definition | |
#define | Enable_global_interrupt() cpu_irq_enable() |
#define | Disable_global_interrupt() cpu_irq_disable() |
#define | Is_global_interrupt_enabled() cpu_irq_is_enabled() |
#define ctz | ( | u | ) |
u | Value of which to count the trailing zero bits. |
