RTEMS 6.1-rc2
Data Structures | Enumerator | Variables
Flexram
struct  _flexram_allocate_ram
 FLEXRAM allocate ocram, itcm, dtcm size. More...
const uint8_t _flexram_allocate_ram::ocramBankNum
const uint8_t _flexram_allocate_ram::dtcmBankNum
const uint8_t _flexram_allocate_ram::itcmBankNum
Driver version
enum  { kFLEXRAM_BankNotUsed = 0U , kFLEXRAM_BankOCRAM = 1U , kFLEXRAM_BankDTCM = 2U , kFLEXRAM_BankITCM = 3U }
 FLEXRAM bank type. More...
enum  _flexram_bank_allocate_src { kFLEXRAM_BankAllocateThroughHardwareFuse = 0U , kFLEXRAM_BankAllocateThroughBankCfg = 1U , kFLEXRAM_BankAllocateThroughHardwareFuse = 0U , kFLEXRAM_BankAllocateThroughBankCfg = 1U }
 FLEXRAM bank allocate source. More...
typedef enum _flexram_bank_allocate_src flexram_bank_allocate_src_t
typedef struct _flexram_allocate_ram flexram_allocate_ram_t
status_t FLEXRAM_AllocateRam (flexram_allocate_ram_t *config)
 FLEXRAM allocate on-chip ram for OCRAM,ITCM,DTCM This function is independent of FLEXRAM_Init, it can be called directly if ram re-allocate is needed.
#define FSL_SOC_FLEXRAM_ALLOCATE_DRIVER_VERSION   (MAKE_VERSION(2, 0, 2))
 SOC_FLEXRAM_ALLOCATE driver version 2.0.2.
Driver version
 FLEXRAM allocates OCRAM, ITCM, DTCM size.
Driver version
enum  { kFLEXRAM_Read = 0U , kFLEXRAM_Write = 1U }
 Flexram write/read selection. More...
enum  { kFLEXRAM_OCRAMAccessError = FLEXRAM_INT_STATUS_OCRAM_ERR_STATUS_MASK , kFLEXRAM_DTCMAccessError = FLEXRAM_INT_STATUS_DTCM_ERR_STATUS_MASK , kFLEXRAM_ITCMAccessError = FLEXRAM_INT_STATUS_ITCM_ERR_STATUS_MASK , kFLEXRAM_InterruptStatusAll }
 Interrupt status flag mask. More...
enum  _flexram_tcm_access_mode { kFLEXRAM_TCMAccessFastMode = 0U , kFLEXRAM_TCMAccessWaitMode = 1U }
 FLEXRAM TCM access mode. Fast access mode expected to be finished in 1-cycle; Wait access mode expected to be finished in 2-cycle. Wait access mode is a feature of the flexram and it should be used when the CPU clock is too fast to finish TCM access in 1-cycle. Normally, fast mode is the default mode, the efficiency of the TCM access will better. More...
enum  {
  kFLEXRAM_TCMSize32KB = 32 * 1024U , kFLEXRAM_TCMSize64KB = 64 * 1024U , kFLEXRAM_TCMSize128KB = 128 * 1024U , kFLEXRAM_TCMSize256KB = 256 * 1024U ,
  kFLEXRAM_TCMSize512KB = 512 * 1024U
 FLEXRAM TCM support size. More...
typedef enum _flexram_tcm_access_mode flexram_tcm_access_mode_t
#define FSL_FLEXRAM_DRIVER_VERSION   (MAKE_VERSION(2U, 2U, 0U))
 Driver version.
#define FLEXRAM_ECC_ERROR_DETAILED_INFO    0U /* Define to zero means get raw ECC error information, which needs parse it by user. */
 Get ECC error detailed information.
Initialization and de-initialization
void FLEXRAM_Init (FLEXRAM_Type *base)
 FLEXRAM module initialization function.
void FLEXRAM_Deinit (FLEXRAM_Type *base)
 De-initializes the FLEXRAM.
◆ anonymous enum
anonymous enum
FLEXRAM bank type.
bank is not used
kFLEXRAM_BankOCRAM
bank is OCRAM
kFLEXRAM_BankDTCM
bank is DTCM
kFLEXRAM_BankITCM
bank is ITCM
◆ anonymous enum
anonymous enum
kFLEXRAM_Read
read
kFLEXRAM_Write
write
◆ anonymous enum
anonymous enum
OCRAM accesses unallocated address
DTCM accesses unallocated address
ITCM accesses unallocated address
all the interrupt status mask
◆ anonymous enum
anonymous enum
TCM total size be 32KB
TCM total size be 64KB
TCM total size be 128KB
TCM total size be 256KB
TCM total size be 512KB
◆ anonymous enum
anonymous enum
FLEXRAM bank type.
bank is not used
kFLEXRAM_BankOCRAM
bank is OCRAM
kFLEXRAM_BankDTCM
bank is DTCM
kFLEXRAM_BankITCM
bank is ITCM
◆ _flexram_bank_allocate_src [1/2]
allocate ram through hardware fuse value
allocate ram through FLEXRAM_BANK_CFG
◆ _flexram_bank_allocate_src [2/2]
◆ _flexram_tcm_access_mode
fast access mode
wait access mode
◆ FLEXRAM_AllocateRam()
status_t FLEXRAM_AllocateRam ( flexram_allocate_ram_t config)
FLEXRAM allocates an on-chip ram for OCRAM, ITCM and DTCM. This function is independent from FLEXRAM_Init, and can be called directly if ram re-allocate is needed.
Parameters
configallocate configuration.
Return values
kStatus_InvalidArgumentthe argument is invalid kStatus_Success allocate success
Parameters
configAllocate configuration.
Return values
kStatus_InvalidArgumentWhen the argument is invalid.
kStatus_SuccessUpon allocate success.
brief FLEXRAM allocate on-chip ram for OCRAM,ITCM,DTCM This function is independent of FLEXRAM_Init, it can be called directly if ram re-allocate is needed. param config allocate configuration. retval kStatus_InvalidArgument the argument is invalid kStatus_Success allocate success
Parameters
Return values
◆ FLEXRAM_Deinit()
void FLEXRAM_Deinit ( FLEXRAM_Type base)
brief Deinitializes the FLEXRAM.
◆ FLEXRAM_Init()
void FLEXRAM_Init ( FLEXRAM_Type base)
Parameters
baseFLEXRAM base address.
brief FLEXRAM module initialization function.
param base FLEXRAM base address.
Variable Documentation
◆ dtcmBankNum
dtcm bank number to allocate, the number should be power of 2
DTCM bank number to allocate, the number should be power of 2.
◆ itcmBankNum
itcm bank number to allocate, the number should be power of 2
ITCM bank number to allocate, the number should be power of 2.
◆ ocramBankNum
ocram banknumber which the SOC support
OCRAM banknumber which the SOC support.
