RTEMS 6.1-rc2
Data Structures | Enumerator | Variables
Csi_driver
struct  _csi_config
 Configuration to initialize the CSI module. More...
struct  _csi_handle
 CSI handle structure. More...
uint16_t _csi_config::width
uint16_t _csi_config::height
uint32_t _csi_config::polarityFlags
uint8_t _csi_config::bytesPerPixel
uint16_t _csi_config::linePitch_Bytes
csi_work_mode_t _csi_config::workMode
csi_data_bus_t _csi_config::dataBus
bool _csi_config::useExtVsync
uint32_t _csi_handle::frameBufferQueue [CSI_DRIVER_ACTUAL_QUEUE_SIZE]
volatile uint8_t _csi_handle::queueWriteIdx
volatile uint8_t _csi_handle::queueReadIdx
void *volatile _csi_handle::emptyBuffer
volatile uint8_t _csi_handle::emptyBufferCnt
volatile uint8_t _csi_handle::activeBufferNum
volatile bool _csi_handle::transferStarted
csi_transfer_callback_t _csi_handle::callback
void * _csi_handle::userData
Driver version
enum  { kStatus_CSI_NoEmptyBuffer = MAKE_STATUS(kStatusGroup_CSI, 0) , kStatus_CSI_NoFullBuffer = MAKE_STATUS(kStatusGroup_CSI, 1) , kStatus_CSI_QueueFull = MAKE_STATUS(kStatusGroup_CSI, 2) , kStatus_CSI_FrameDone = MAKE_STATUS(kStatusGroup_CSI, 3) }
 Error codes for the CSI driver. More...
enum  _csi_work_mode { kCSI_GatedClockMode = CSI_CR1_GCLK_MODE(1U) , kCSI_NonGatedClockMode = 0U , kCSI_CCIR656ProgressiveMode = CSI_CR1_CCIR_EN(1U) }
 CSI work mode. More...
enum  _csi_data_bus { kCSI_DataBus8Bit , kCSI_DataBus16Bit , kCSI_DataBus24Bit }
 CSI data bus witdh. More...
enum  _csi_polarity_flags {
  kCSI_HsyncActiveLow = 0U , kCSI_HsyncActiveHigh = CSI_CR1_HSYNC_POL_MASK , kCSI_DataLatchOnRisingEdge = CSI_CR1_REDGE_MASK , kCSI_DataLatchOnFallingEdge = 0U ,
  kCSI_VsyncActiveHigh = 0U , kCSI_VsyncActiveLow = CSI_CR1_SOF_POL_MASK
 CSI signal polarity. More...
enum  _csi_fifo { kCSI_RxFifo = (1U << 0U) , kCSI_StatFifo = (1U << 1U) , kCSI_AllFifo = 0x01 | 0x02 }
 The CSI FIFO, used for FIFO operation. More...
enum  _csi_interrupt_enable {
  kCSI_EndOfFrameInterruptEnable = CSI_CR1_EOF_INT_EN_MASK , kCSI_ChangeOfFieldInterruptEnable = CSI_CR1_COF_INT_EN_MASK , kCSI_StatFifoOverrunInterruptEnable = CSI_CR1_SF_OR_INTEN_MASK , kCSI_RxFifoOverrunInterruptEnable = CSI_CR1_RF_OR_INTEN_MASK ,
  kCSI_StatFifoDmaDoneInterruptEnable = CSI_CR1_SFF_DMA_DONE_INTEN_MASK , kCSI_StatFifoFullInterruptEnable = CSI_CR1_STATFF_INTEN_MASK , kCSI_RxBuffer1DmaDoneInterruptEnable = CSI_CR1_FB2_DMA_DONE_INTEN_MASK , kCSI_RxBuffer0DmaDoneInterruptEnable = CSI_CR1_FB1_DMA_DONE_INTEN_MASK ,
  kCSI_RxFifoFullInterruptEnable = CSI_CR1_RXFF_INTEN_MASK , kCSI_StartOfFrameInterruptEnable = CSI_CR1_SOF_INTEN_MASK , kCSI_EccErrorInterruptEnable = CSI_CR3_ECC_INT_EN_MASK , kCSI_AhbResErrorInterruptEnable = CSI_CR3_HRESP_ERR_EN_MASK ,
  kCSI_BaseAddrChangeErrorInterruptEnable = CSI_CR18_BASEADDR_CHANGE_ERROR_IE_MASK << 6U , kCSI_Field0DoneInterruptEnable = CSI_CR18_FIELD0_DONE_IE_MASK << 6U , kCSI_Field1DoneInterruptEnable = CSI_CR18_DMA_FIELD1_DONE_IE_MASK << 6U
 CSI feature interrupt source. More...
enum  _csi_flags {
  kCSI_RxFifoDataReadyFlag = CSI_SR_DRDY_MASK , kCSI_EccErrorFlag = CSI_SR_ECC_INT_MASK , kCSI_AhbResErrorFlag = CSI_SR_HRESP_ERR_INT_MASK , kCSI_ChangeOfFieldFlag = CSI_SR_COF_INT_MASK ,
  kCSI_Field0PresentFlag = CSI_SR_F1_INT_MASK , kCSI_Field1PresentFlag = CSI_SR_F2_INT_MASK , kCSI_StartOfFrameFlag = CSI_SR_SOF_INT_MASK , kCSI_EndOfFrameFlag = CSI_SR_EOF_INT_MASK ,
  kCSI_RxFifoFullFlag = CSI_SR_RxFF_INT_MASK , kCSI_RxBuffer1DmaDoneFlag = CSI_SR_DMA_TSF_DONE_FB2_MASK , kCSI_RxBuffer0DmaDoneFlag = CSI_SR_DMA_TSF_DONE_FB1_MASK , kCSI_StatFifoFullFlag = CSI_SR_STATFF_INT_MASK ,
  kCSI_StatFifoDmaDoneFlag = CSI_SR_DMA_TSF_DONE_SFF_MASK , kCSI_StatFifoOverrunFlag = CSI_SR_SF_OR_INT_MASK , kCSI_RxFifoOverrunFlag = CSI_SR_RF_OR_INT_MASK , kCSI_Field0DoneFlag = CSI_SR_DMA_FIELD0_DONE_MASK ,
  kCSI_Field1DoneFlag = CSI_SR_DMA_FIELD1_DONE_MASK , kCSI_BaseAddrChangeErrorFlag = CSI_SR_BASEADDR_CHHANGE_ERROR_MASK
 CSI status flags. More...
typedef enum _csi_work_mode csi_work_mode_t
 CSI work mode.
typedef enum _csi_data_bus csi_data_bus_t
 CSI data bus witdh.
typedef struct _csi_config csi_config_t
typedef enum _csi_fifo csi_fifo_t
typedef struct _csi_handle csi_handle_t
typedef void(* csi_transfer_callback_t) (CSI_Type *base, csi_handle_t *handle, status_t status, void *userData)
 CSI transfer callback function.
#define FSL_CSI_DRIVER_VERSION   (MAKE_VERSION(2, 1, 5))
#define CSI_REG_CR1(base)   (base)->CR1
#define CSI_REG_CR2(base)   (base)->CR2
#define CSI_REG_CR3(base)   (base)->CR3
#define CSI_REG_CR18(base)   (base)->CR18
#define CSI_REG_SR(base)   (base)->SR
#define CSI_REG_DMASA_FB1(base)   (base)->DMASA_FB1
#define CSI_REG_DMASA_FB2(base)   (base)->DMASA_FB2
#define CSI_REG_IMAG_PARA(base)   (base)->IMAG_PARA
#define CSI_REG_FBUF_PARA(base)   (base)->FBUF_PARA
#define CSI_DRIVER_QUEUE_SIZE   4U
 Size of the frame buffer queue used in CSI transactional function.
#define CSI_DRIVER_FRAG_MODE   0U
 Enable fragment capture function or not.
#define CSI_DRIVER_ACTUAL_QUEUE_SIZE   (CSI_DRIVER_QUEUE_SIZE + 1U)
#define CSI_CR1_INT_EN_MASK   0xFFFF0000U
#define CSI_CR3_INT_EN_MASK   0x000000FFU
#define CSI_CR18_INT_EN_MASK   0x0000FF00U
Initialization and deinitialization
status_t CSI_Init (CSI_Type *base, const csi_config_t *config)
 Initialize the CSI.
void CSI_Deinit (CSI_Type *base)
 De-initialize the CSI.
void CSI_Reset (CSI_Type *base)
 Reset the CSI.
void CSI_GetDefaultConfig (csi_config_t *config)
 Get the default configuration for to initialize the CSI.
Module operation
void CSI_ClearFifo (CSI_Type *base, csi_fifo_t fifo)
 Clear the CSI FIFO.
void CSI_ReflashFifoDma (CSI_Type *base, csi_fifo_t fifo)
 Reflash the CSI FIFO DMA.
void CSI_EnableFifoDmaRequest (CSI_Type *base, csi_fifo_t fifo, bool enable)
 Enable or disable the CSI FIFO DMA request.
void CSI_SetRxBufferAddr (CSI_Type *base, uint8_t index, uint32_t addr)
 Set the RX frame buffer address.
Interrupts
void CSI_EnableInterrupts (CSI_Type *base, uint32_t mask)
 Enables CSI interrupt requests.
void CSI_DisableInterrupts (CSI_Type *base, uint32_t mask)
 Disable CSI interrupt requests.
Transactional
status_t CSI_TransferCreateHandle (CSI_Type *base, csi_handle_t *handle, csi_transfer_callback_t callback, void *userData)
 Initializes the CSI handle.
status_t CSI_TransferStart (CSI_Type *base, csi_handle_t *handle)
 Start the transfer using transactional functions.
status_t CSI_TransferStop (CSI_Type *base, csi_handle_t *handle)
 Stop the transfer using transactional functions.
status_t CSI_TransferSubmitEmptyBuffer (CSI_Type *base, csi_handle_t *handle, uint32_t frameBuffer)
 Submit empty frame buffer to queue.
status_t CSI_TransferGetFullBuffer (CSI_Type *base, csi_handle_t *handle, uint32_t *frameBuffer)
 Get one full frame buffer from queue.
void CSI_TransferHandleIRQ (CSI_Type *base, csi_handle_t *handle)
 CSI IRQ handle function.
Typedef Documentation
◆ csi_transfer_callback_t
When a new frame is received and saved to the frame buffer queue, the callback is called and the pass the status kStatus_CSI_FrameDone to upper layer.
◆ csi_work_mode_t
CSI work mode.
The CCIR656 interlace mode is not supported currently.
◆ anonymous enum
anonymous enum
No empty frame buffer in queue to load to CSI.
No full frame buffer in queue to read out.
Queue is full, no room to save new empty buffer.
New frame received and saved to queue.
◆ _csi_data_bus
CSI data bus witdh.
kCSI_DataBus8Bit
8-bit data bus.
kCSI_DataBus16Bit
16-bit data bus.
kCSI_DataBus24Bit
24-bit data bus.
◆ _csi_fifo
enum _csi_fifo
kCSI_RxFifo
RXFIFO.
kCSI_StatFifo
STAT FIFO.
kCSI_AllFifo
Both RXFIFO and STAT FIFO.
◆ _csi_flags
enum _csi_flags
CSI status flags.
The following status register flags can be cleared:
  • kCSI_EccErrorFlag
  • kCSI_AhbResErrorFlag
  • kCSI_ChangeOfFieldFlag
  • kCSI_StartOfFrameFlag
  • kCSI_EndOfFrameFlag
  • kCSI_RxBuffer1DmaDoneFlag
  • kCSI_RxBuffer0DmaDoneFlag
  • kCSI_StatFifoDmaDoneFlag
  • kCSI_StatFifoOverrunFlag
  • kCSI_RxFifoOverrunFlag
  • kCSI_Field0DoneFlag
  • kCSI_Field1DoneFlag
  • kCSI_BaseAddrChangeErrorFlag
RXFIFO data ready.
kCSI_EccErrorFlag
ECC error detected.
Hresponse (AHB bus response) Error.
Change of field.
Field 0 present in CCIR mode.
Field 1 present in CCIR mode.
Start of frame (SOF) detected.
kCSI_EndOfFrameFlag
End of frame (EOF) detected.
kCSI_RxFifoFullFlag
RXFIFO full (Number of data reaches trigger level).
RX frame buffer 1 DMA transfer done.
RX frame buffer 0 DMA transfer done.
STAT FIFO full (Reach trigger level).
STAT FIFO DMA transfer done.
STAT FIFO overrun.
RXFIFO overrun.
kCSI_Field0DoneFlag
Field 0 transfer done.
kCSI_Field1DoneFlag
Field 1 transfer done.
The DMA output buffer base address changes before DMA completed.
◆ _csi_interrupt_enable
End of frame interrupt enable.
Change of field interrupt enable.
STAT FIFO overrun interrupt enable.
RXFIFO overrun interrupt enable.
STAT FIFO DMA done interrupt enable.
STAT FIFO full interrupt enable.
RXFIFO full interrupt enable.
Start of frame (SOF) interrupt enable.
ECC error detection interrupt enable.
AHB response Error interrupt enable.
Field 0 done interrupt enable.
Field 1 done interrupt enable.
◆ _csi_polarity_flags
kCSI_HsyncActiveLow
HSYNC is active low.
HSYNC is active high.
Pixel data latched at rising edge of pixel clock.
Pixel data latched at falling edge of pixel clock.
VSYNC is active high.
kCSI_VsyncActiveLow
VSYNC is active low.
◆ _csi_work_mode
CSI work mode.
kCSI_GatedClockMode
HSYNC, VSYNC, and PIXCLK signals are used.
CCIR656 progressive mode.
◆ CSI_ClearFifo()
void CSI_ClearFifo ( CSI_Type base,
csi_fifo_t  fifo
Clear the CSI FIFO.
This function clears the CSI FIFO.
Parameters
baseCSI peripheral base address.
fifoThe FIFO to clear.
brief Clear the CSI FIFO.
param base CSI peripheral base address. param fifo The FIFO to clear.
◆ CSI_Deinit()
void CSI_Deinit ( CSI_Type base)
This function disables the CSI peripheral clock.
Parameters
brief De-initialize the CSI.
◆ CSI_DisableInterrupts()
void CSI_DisableInterrupts ( CSI_Type base,
uint32_t  mask
Parameters
maskThe interrupts to disable, pass in as OR'ed value of _csi_interrupt_enable.
brief Disable CSI interrupt requests.
param base CSI peripheral base address. param mask The interrupts to disable, pass in as OR'ed value of ref _csi_interrupt_enable.
◆ CSI_EnableFifoDmaRequest()
void CSI_EnableFifoDmaRequest ( CSI_Type base,
csi_fifo_t  fifo,
bool  enable
Parameters
fifoThe FIFO DMA reques to enable or disable.
enableTrue to enable, false to disable.
brief Enable or disable the CSI FIFO DMA request.
param base CSI peripheral base address. param fifo The FIFO DMA reques to enable or disable. param enable True to enable, false to disable.
◆ CSI_EnableInterrupts()
void CSI_EnableInterrupts ( CSI_Type base,
uint32_t  mask
Parameters
maskThe interrupts to enable, pass in as OR'ed value of _csi_interrupt_enable.
brief Enables CSI interrupt requests.
param base CSI peripheral base address. param mask The interrupts to enable, pass in as OR'ed value of ref _csi_interrupt_enable.
◆ CSI_GetDefaultConfig()
void CSI_GetDefaultConfig ( csi_config_t config)
The default configuration value is:
config->width = 320U;
config->height = 240U;
config->bytesPerPixel = 2U;
config->linePitch_Bytes = 320U * 2U;
config->useExtVsync = true;
@ kCSI_DataBus8Bit
Definition: fsl_csi.h:114
@ kCSI_GatedClockMode
Definition: fsl_csi.h:104
@ kCSI_DataLatchOnRisingEdge
Definition: fsl_csi.h:124
@ kCSI_HsyncActiveHigh
Definition: fsl_csi.h:123
Definition: deflate.c:114
Parameters
configPointer to the CSI configuration.
brief Get the default configuration for to initialize the CSI.
code config->width = 320U; config->height = 240U; config->polarityFlags = kCSI_HsyncActiveHigh | kCSI_DataLatchOnRisingEdge; config->bytesPerPixel = 2U; config->linePitch_Bytes = 320U * 2U; config->workMode = kCSI_GatedClockMode; config->dataBus = kCSI_DataBus8Bit; config->useExtVsync = true; endcode
param config Pointer to the CSI configuration.
◆ CSI_Init()
status_t CSI_Init ( CSI_Type base,
const csi_config_t config
Initialize the CSI.
This function enables the CSI peripheral clock, and resets the CSI registers.
Parameters
configPointer to the configuration structure.
Return values
kStatus_SuccessInitialize successfully.
kStatus_InvalidArgumentInitialize failed because of invalid argument.
brief Initialize the CSI.
param base CSI peripheral base address. param config Pointer to the configuration structure.
retval kStatus_Success Initialize successfully. retval kStatus_InvalidArgument Initialize failed because of invalid argument.
◆ CSI_ReflashFifoDma()
void CSI_ReflashFifoDma ( CSI_Type base,
csi_fifo_t  fifo
This function reflashes the CSI FIFO DMA.
For RXFIFO, there are two frame buffers. When the CSI module started, it saves the frames to frame buffer 0 then frame buffer 1, the two buffers will be written by turns. After reflash DMA using this function, the CSI is reset to save frame to buffer 0.
Parameters
fifoThe FIFO DMA to reflash.
brief Reflash the CSI FIFO DMA.
param base CSI peripheral base address. param fifo The FIFO DMA to reflash.
◆ CSI_Reset()
void CSI_Reset ( CSI_Type base)
Reset the CSI.
This function resets the CSI peripheral registers to default status.
Parameters
brief Reset the CSI.
◆ CSI_SetRxBufferAddr()
void CSI_SetRxBufferAddr ( CSI_Type base,
uint8_t  index,
uint32_t  addr
Parameters
indexBuffer index.
addrFrame buffer address to set.
brief Set the RX frame buffer address.
param base CSI peripheral base address. param index Buffer index. param addr Frame buffer address to set.
◆ CSI_TransferCreateHandle()
status_t CSI_TransferCreateHandle ( CSI_Type base,
csi_handle_t handle,
void *  userData
This function initializes CSI handle, it should be called before any other CSI transactional functions.
Parameters
handlePointer to the handle structure.
callbackCallback function for CSI transfer.
userDataCallback function parameter.
Return values
kStatus_SuccessHandle created successfully.
brief Initializes the CSI handle.
param base CSI peripheral base address. param handle Pointer to the handle structure. param callback Callback function for CSI transfer. param userData Callback function parameter.
retval kStatus_Success Handle created successfully.
◆ CSI_TransferGetFullBuffer()
status_t CSI_TransferGetFullBuffer ( CSI_Type base,
uint32_t *  frameBuffer
After the transfer started using function CSI_TransferStart, the incoming frames will be saved to the empty frame buffers in queue. This function gets the full-filled frame buffer from the queue. If there is no full frame buffer in queue, this function returns error.
Parameters
frameBufferFull frame buffer.
Return values
kStatus_SuccessStarted successfully.
kStatus_CSI_NoFullBufferThere is no full frame buffer in queue.
brief Get one full frame buffer from queue.
After the transfer started using function ref CSI_TransferStart, the incoming frames will be saved to the empty frame buffers in queue. This function gets the full-filled frame buffer from the queue. If there is no full frame buffer in queue, this function returns error.
param base CSI peripheral base address. param handle Pointer to the handle structure. param frameBuffer Full frame buffer.
retval kStatus_Success Started successfully. retval kStatus_CSI_NoFullBuffer There is no full frame buffer in queue.
◆ CSI_TransferHandleIRQ()
void CSI_TransferHandleIRQ ( CSI_Type base,
csi_handle_t handle
This function handles the CSI IRQ request to work with CSI driver transactional APIs.
Parameters
handleCSI handle pointer.
brief CSI IRQ handle function.
param base CSI peripheral base address. param handle CSI handle pointer.
◆ CSI_TransferStart()
status_t CSI_TransferStart ( CSI_Type base,
csi_handle_t handle
When the empty frame buffers have been submit to CSI driver using function CSI_TransferSubmitEmptyBuffer, user could call this function to start the transfer. The incoming frame will be saved to the empty frame buffer, and user could be optionally notified through callback function.
Parameters
Return values
kStatus_CSI_NoEmptyBufferCould not start because no empty frame buffer in queue.
brief Start the transfer using transactional functions.
When the empty frame buffers have been submit to CSI driver using function ref CSI_TransferSubmitEmptyBuffer, user could call this function to start the transfer. The incoming frame will be saved to the empty frame buffer, and user could be optionally notified through callback function.
retval kStatus_Success Started successfully. retval kStatus_CSI_NoEmptyBuffer Could not start because no empty frame buffer in queue.
◆ CSI_TransferStop()
status_t CSI_TransferStop ( CSI_Type base,
csi_handle_t handle
The driver does not clean the full frame buffers in queue. In other words, after calling this function, user still could get the full frame buffers in queue using function CSI_TransferGetFullBuffer.
Parameters
Return values
kStatus_SuccessStoped successfully.
brief Stop the transfer using transactional functions.
The driver does not clean the full frame buffers in queue. In other words, after calling this function, user still could get the full frame buffers in queue using function ref CSI_TransferGetFullBuffer.
retval kStatus_Success Stoped successfully.
◆ CSI_TransferSubmitEmptyBuffer()
status_t CSI_TransferSubmitEmptyBuffer ( CSI_Type base,
This function could be called before CSI_TransferStart or after CSI_TransferStart. If there is no room in queue to store the empty frame buffer, this function returns error.
Parameters
frameBufferEmpty frame buffer to submit.
Return values
kStatus_CSI_QueueFullCould not submit because there is no room in queue.
brief Submit empty frame buffer to queue.
This function could be called before ref CSI_TransferStart or after ref CSI_TransferStart. If there is no room in queue to store the empty frame buffer, this function returns error.
param base CSI peripheral base address. param handle Pointer to the handle structure. param frameBuffer Empty frame buffer to submit.
retval kStatus_Success Started successfully. retval kStatus_CSI_QueueFull Could not submit because there is no room in queue.
Variable Documentation
◆ activeBufferNum
How many frame buffers are in progres currently.
◆ bytesPerPixel
Bytes per pixel, valid values are:
  • 2: Used for RGB565, YUV422, and so on.
  • 4: Used for XRGB8888, XYUV444, and so on.
◆ callback
Callback function.
◆ dataBus
Data bus width.
◆ emptyBuffer
void* volatile _csi_handle::emptyBuffer
Pointer to maintain the empty frame buffers.
◆ emptyBufferCnt
Empty frame buffers count.
◆ frameBufferQueue
uint32_t _csi_handle::frameBufferQueue[CSI_DRIVER_ACTUAL_QUEUE_SIZE]
Frame buffer queue.
◆ height
Lines of the input frame.
◆ linePitch_Bytes
Frame buffer line pitch, must be 8-byte aligned.
◆ polarityFlags
Timing signal polarity flags, OR'ed value of _csi_polarity_flags.
◆ queueReadIdx
Pointer to read out the item.
◆ queueWriteIdx
Pointer to save incoming item.
◆ transferStarted
User has called CSI_TransferStart to start frame receiving.
◆ useExtVsync
In CCIR656 progressive mode, set true to use external VSYNC signal, set false to use internal VSYNC signal decoded from SOF.
◆ userData
void* _csi_handle::userData
CSI callback function parameter.
◆ width
Pixels of the input frame.
◆ workMode
CSI work mode.
