RTEMS 6.1-rc2
Cache_armv7_m7
Control for cortex-m7 L1 cache
void L1CACHE_InvalidateICacheByRange (uint32_t address, uint32_t size_byte)
 Invalidate cortex-m7 L1 instruction cache by range.
Unified Cache Control for all caches (cortex-m7 L1 cache + l2 pl310)
Mainly used for many drivers for easy cache operation.
void ICACHE_InvalidateByRange (uint32_t address, uint32_t size_byte)
 Invalidates all instruction caches by range.
void DCACHE_InvalidateByRange (uint32_t address, uint32_t size_byte)
 Invalidates all data caches by range.
void DCACHE_CleanByRange (uint32_t address, uint32_t size_byte)
 Cleans all data caches by range.
void DCACHE_CleanInvalidateByRange (uint32_t address, uint32_t size_byte)
 Cleans and Invalidates all data caches by range.
Driver version
#define FSL_CACHE_DRIVER_VERSION   (MAKE_VERSION(2, 0, 4))
 cache driver version 2.0.4.
Driver version
◆ DCACHE_CleanByRange()
void DCACHE_CleanByRange ( uint32_t  address,
uint32_t  size_byte
Both cortex-m7 L1 cache line and L2 PL310 cache line length is 32-byte.
Parameters
addressThe physical address.
size_bytesize of the memory to be cleaned.
Note
address and size should be aligned to cache line size 32-Byte due to the cache operation unit is one cache line. The startAddr here will be forced to align to the cache line size if startAddr is not aligned. For the size_byte, application should make sure the alignment or make sure the right operation order if the size_byte is not aligned.
brief Cleans all data caches by range.
param address The physical address. param size_byte size of the memory to be cleaned. note address and size should be aligned to cache line size 32-Byte due to the cache operation unit is one cache line. The startAddr here will be forced to align to the cache line size if startAddr is not aligned. For the size_byte, application should make sure the alignment or make sure the right operation order if the size_byte is not aligned.
Parameters
Note
◆ DCACHE_CleanInvalidateByRange()
void DCACHE_CleanInvalidateByRange ( uint32_t  address,
uint32_t  size_byte
Parameters
size_bytesize of the memory to be cleaned and invalidated.
Note
brief Cleans and Invalidates all data caches by range.
param address The physical address. param size_byte size of the memory to be cleaned and invalidated. note address and size should be aligned to cache line size 32-Byte due to the cache operation unit is one cache line. The startAddr here will be forced to align to the cache line size if startAddr is not aligned. For the size_byte, application should make sure the alignment or make sure the right operation order if the size_byte is not aligned.
Parameters
Note
◆ DCACHE_InvalidateByRange()
void DCACHE_InvalidateByRange ( uint32_t  address,
uint32_t  size_byte
Parameters
size_bytesize of the memory to be invalidated.
Note
brief Invalidates all data caches by range.
param address The physical address. param size_byte size of the memory to be invalidated. note address and size should be aligned to cache line size 32-Byte due to the cache operation unit is one cache line. The startAddr here will be forced to align to the cache line size if startAddr is not aligned. For the size_byte, application should make sure the alignment or make sure the right operation order if the size_byte is not aligned.
Parameters
Note
◆ ICACHE_InvalidateByRange()
void ICACHE_InvalidateByRange ( uint32_t  address,
uint32_t  size_byte
Parameters
Note
brief Invalidates all instruction caches by range.
Parameters
Note
◆ L1CACHE_InvalidateICacheByRange()
void L1CACHE_InvalidateICacheByRange ( uint32_t  address,
uint32_t  size_byte
Parameters
addressThe start address of the memory to be invalidated.
size_byteThe memory size.
Note
The start address and size_byte should be 32-byte(FSL_FEATURE_L1ICACHE_LINESIZE_BYTE) aligned. The startAddr here will be forced to align to L1 I-cache line size if startAddr is not aligned. For the size_byte, application should make sure the alignment or make sure the right operation order if the size_byte is not aligned.
brief Invalidates cortex-m4 L1 instrument cache by range.
param address The start address of the memory to be invalidated. param size_byte The memory size. note The start address and size_byte should be 16-Byte(FSL_FEATURE_L1ICACHE_LINESIZE_BYTE) aligned.
Parameters
Note
brief Invalidate cortex-m7 L1 instruction cache by range.
param address The start address of the memory to be invalidated. param size_byte The memory size. note The start address and size_byte should be 32-byte(FSL_FEATURE_L1ICACHE_LINESIZE_BYTE) aligned. The startAddr here will be forced to align to L1 I-cache line size if startAddr is not aligned. For the size_byte, application should make sure the alignment or make sure the right operation order if the size_byte is not aligned.
