RTEMS 6.1-rc2
struct | _aoi_event_config |
AOI event configuration structure. More... | |
#define | AOI AOI0 |
Driver version | |
enum | _aoi_input_config { kAOI_LogicZero = 0x0U , kAOI_InputSignal = 0x1U , kAOI_InvInputSignal = 0x2U , kAOI_LogicOne = 0x3U } |
AOI input configurations. More... | |
enum | _aoi_event { kAOI_Event0 = 0x0U , kAOI_Event1 = 0x1U , kAOI_Event2 = 0x2U , kAOI_Event3 = 0x3U } |
AOI event indexes, where an event is the collection of the four product terms (0, 1, 2, and 3) and the four signal inputs (A, B, C, and D). More... | |
typedef enum _aoi_input_config | aoi_input_config_t |
AOI input configurations. | |
typedef enum _aoi_event | aoi_event_t |
AOI event indexes, where an event is the collection of the four product terms (0, 1, 2, and 3) and the four signal inputs (A, B, C, and D). | |
typedef struct _aoi_event_config | aoi_event_config_t |
AOI event configuration structure. | |
#define | FSL_AOI_DRIVER_VERSION (MAKE_VERSION(2, 0, 1)) |
AOI Initialization | |
void | AOI_Init (AOI_Type *base) |
Initializes an AOI instance for operation. | |
void | AOI_Deinit (AOI_Type *base) |
Deinitializes an AOI instance for operation. | |
AOI Get Set Operation | |
void | AOI_GetEventLogicConfig (AOI_Type *base, aoi_event_t event, aoi_event_config_t *config) |
Gets the Boolean evaluation associated. | |
void | AOI_SetEventLogicConfig (AOI_Type *base, aoi_event_t event, const aoi_event_config_t *eventConfig) |
Configures an AOI event. | |
#define AOI AOI0 |
AOI peripheral address
#define FSL_AOI_DRIVER_VERSION (MAKE_VERSION(2, 0, 1)) |
Version 2.0.1.
typedef struct _aoi_event_config aoi_event_config_t |
Defines structure _aoi_event_config and use the AOI_SetEventLogicConfig() function to make whole event configuration.
typedef enum _aoi_input_config aoi_input_config_t |
The selection item represents the Boolean evaluations.
enum _aoi_event |
void AOI_Deinit | ( | AOI_Type * | base | ) |
This function shutdowns AOI module.
base | AOI peripheral address. |
brief Deinitializes an AOI instance for operation.
param base AOI peripheral address.
void AOI_GetEventLogicConfig | ( | AOI_Type * | base, |
aoi_event_t | event, | ||
aoi_event_config_t * | config | ||
This function returns the Boolean evaluation associated.
Example:
event | Index of the event which will be set of type aoi_event_t. |
config | Selected input configuration . |
brief Gets the Boolean evaluation associated.
Example: code aoi_event_config_t demoEventLogicStruct;
AOI_GetEventLogicConfig(AOI, kAOI_Event0, &demoEventLogicStruct); endcode
param base AOI peripheral address. param event Index of the event which will be set of type aoi_event_t. param config Selected input configuration .
void AOI_Init | ( | AOI_Type * | base | ) |
This function un-gates the AOI clock.
brief Initializes an AOI instance for operation.
void AOI_SetEventLogicConfig | ( | AOI_Type * | base, |
const aoi_event_config_t * | eventConfig | ||
This function configures an AOI event according to the aoiEventConfig structure. This function configures all inputs (A, B, C, and D) of all product terms (0, 1, 2, and 3) of a desired event.
Example:
event | Event which will be configured of type aoi_event_t. |
eventConfig | Pointer to type aoi_event_config_t structure. The user is responsible for filling out the members of this structure and passing the pointer to this function. |
brief Configures an AOI event.
demoEventLogicStruct.PT0AC = kAOI_InvInputSignal; demoEventLogicStruct.PT0BC = kAOI_InputSignal; demoEventLogicStruct.PT0CC = kAOI_LogicOne; demoEventLogicStruct.PT0DC = kAOI_LogicOne;
demoEventLogicStruct.PT1AC = kAOI_LogicZero; demoEventLogicStruct.PT1BC = kAOI_LogicOne; demoEventLogicStruct.PT1CC = kAOI_LogicOne; demoEventLogicStruct.PT1DC = kAOI_LogicOne;
demoEventLogicStruct.PT2AC = kAOI_LogicZero; demoEventLogicStruct.PT2BC = kAOI_LogicOne; demoEventLogicStruct.PT2CC = kAOI_LogicOne; demoEventLogicStruct.PT2DC = kAOI_LogicOne;
demoEventLogicStruct.PT3AC = kAOI_LogicZero; demoEventLogicStruct.PT3BC = kAOI_LogicOne; demoEventLogicStruct.PT3CC = kAOI_LogicOne; demoEventLogicStruct.PT3DC = kAOI_LogicOne;
AOI_SetEventLogicConfig(AOI, kAOI_Event0, demoEventLogicStruct); endcode
param base AOI peripheral address. param event Event which will be configured of type aoi_event_t. param eventConfig Pointer to type aoi_event_config_t structure. The user is responsible for filling out the members of this structure and passing the pointer to this function.
aoi_input_config_t _aoi_event_config::PT0AC |
Product term 0 input A
aoi_input_config_t _aoi_event_config::PT0BC |
Product term 0 input B
aoi_input_config_t _aoi_event_config::PT0CC |
Product term 0 input C
aoi_input_config_t _aoi_event_config::PT0DC |
Product term 0 input D
aoi_input_config_t _aoi_event_config::PT1AC |
Product term 1 input A
aoi_input_config_t _aoi_event_config::PT1BC |
Product term 1 input B
aoi_input_config_t _aoi_event_config::PT1CC |
Product term 1 input C
aoi_input_config_t _aoi_event_config::PT1DC |
Product term 1 input D
aoi_input_config_t _aoi_event_config::PT2AC |
Product term 2 input A
aoi_input_config_t _aoi_event_config::PT2BC |
Product term 2 input B
aoi_input_config_t _aoi_event_config::PT2CC |
Product term 2 input C
aoi_input_config_t _aoi_event_config::PT2DC |
Product term 2 input D
aoi_input_config_t _aoi_event_config::PT3AC |
Product term 3 input A
aoi_input_config_t _aoi_event_config::PT3BC |
Product term 3 input B
aoi_input_config_t _aoi_event_config::PT3CC |
Product term 3 input C
aoi_input_config_t _aoi_event_config::PT3DC |
Product term 3 input D
