RTEMS 6.1-rc2
Data Structures | Enumerator | Variables
Acmp
struct  _acmp_config
 Configuration for ACMP. More...
struct  _acmp_channel_config
 Configuration for channel. More...
struct  _acmp_filter_config
 Configuration for filter. More...
struct  _acmp_dac_config
 Configuration for DAC. More...
struct  _acmp_round_robin_config
 Configuration for round robin mode. More...
acmp_hysteresis_mode_t _acmp_config::hysteresisMode
bool _acmp_config::enableHighSpeed
bool _acmp_config::enableInvertOutput
bool _acmp_config::useUnfilteredOutput
bool _acmp_config::enablePinOut
uint32_t _acmp_channel_config::plusMuxInput
uint32_t _acmp_channel_config::minusMuxInput
bool _acmp_filter_config::enableSample
uint32_t _acmp_filter_config::filterCount
uint32_t _acmp_filter_config::filterPeriod
acmp_reference_voltage_source_t _acmp_dac_config::referenceVoltageSource
uint32_t _acmp_dac_config::DACValue
acmp_fixed_port_t _acmp_round_robin_config::fixedPort
uint32_t _acmp_round_robin_config::fixedChannelNumber
uint32_t _acmp_round_robin_config::checkerChannelMask
uint32_t _acmp_round_robin_config::sampleClockCount
uint32_t _acmp_round_robin_config::delayModulus
Driver version
enum  _acmp_interrupt_enable { kACMP_OutputRisingInterruptEnable = (1U << 0U) , kACMP_OutputFallingInterruptEnable = (1U << 1U) , kACMP_RoundRobinInterruptEnable = (1U << 2U) }
 Interrupt enable/disable mask. More...
enum  _acmp_status_flags { kACMP_OutputRisingEventFlag = CMP_C0_CFR_MASK , kACMP_OutputFallingEventFlag = CMP_C0_CFF_MASK , kACMP_OutputAssertEventFlag = CMP_C0_COUT_MASK }
 Status flag mask. More...
enum  _acmp_hysteresis_mode { kACMP_HysteresisLevel0 = 0U , kACMP_HysteresisLevel1 = 1U , kACMP_HysteresisLevel2 = 2U , kACMP_HysteresisLevel3 = 3U }
 Comparator hard block hysteresis control. More...
enum  _acmp_reference_voltage_source { kACMP_VrefSourceVin1 = 0U , kACMP_VrefSourceVin2 = 1U }
 CMP Voltage Reference source. More...
enum  _acmp_fixed_port { kACMP_FixedPlusPort = 0U , kACMP_FixedMinusPort = 1U }
 Fixed mux port. More...
typedef enum _acmp_hysteresis_mode acmp_hysteresis_mode_t
typedef enum _acmp_reference_voltage_source acmp_reference_voltage_source_t
typedef enum _acmp_fixed_port acmp_fixed_port_t
 Fixed mux port.
typedef struct _acmp_config acmp_config_t
typedef struct _acmp_channel_config acmp_channel_config_t
typedef struct _acmp_filter_config acmp_filter_config_t
typedef struct _acmp_dac_config acmp_dac_config_t
typedef struct _acmp_round_robin_config acmp_round_robin_config_t
#define FSL_ACMP_DRIVER_VERSION   (MAKE_VERSION(2U, 0U, 6U))
 ACMP driver version 2.0.6.
#define CMP_C0_CFx_MASK   (CMP_C0_CFR_MASK | CMP_C0_CFF_MASK)
 The mask of status flags cleared by writing 1.
#define CMP_C1_CHNn_MASK   0xFF0000U /* C1_CHN0 - C1_CHN7. */
#define CMP_C2_CHnF_MASK   0xFF0000U /* C2_CH0F - C2_CH7F. */
Initialization and deinitialization
void ACMP_Init (CMP_Type *base, const acmp_config_t *config)
 Initializes the ACMP.
void ACMP_Deinit (CMP_Type *base)
 Deinitializes the ACMP.
void ACMP_GetDefaultConfig (acmp_config_t *config)
 Gets the default configuration for ACMP.
Basic Operations
void ACMP_Enable (CMP_Type *base, bool enable)
 Enables or disables the ACMP.
void ACMP_SetChannelConfig (CMP_Type *base, const acmp_channel_config_t *config)
 Sets the channel configuration.
Advanced Operations
void ACMP_EnableDMA (CMP_Type *base, bool enable)
 Enables or disables DMA.
void ACMP_EnableWindowMode (CMP_Type *base, bool enable)
 Enables or disables window mode.
void ACMP_SetFilterConfig (CMP_Type *base, const acmp_filter_config_t *config)
 Configures the filter.
void ACMP_SetDACConfig (CMP_Type *base, const acmp_dac_config_t *config)
 Configures the internal DAC.
void ACMP_SetRoundRobinConfig (CMP_Type *base, const acmp_round_robin_config_t *config)
 Configures the round robin mode.
void ACMP_SetRoundRobinPreState (CMP_Type *base, uint32_t mask)
 Defines the pre-set state of channels in round robin mode.
void ACMP_ClearRoundRobinStatusFlags (CMP_Type *base, uint32_t mask)
 Clears the channel input changed flags in round robin mode.
Interrupts
void ACMP_EnableInterrupts (CMP_Type *base, uint32_t mask)
 Enables interrupts.
void ACMP_DisableInterrupts (CMP_Type *base, uint32_t mask)
 Disables interrupts.
Status
uint32_t ACMP_GetStatusFlags (CMP_Type *base)
 Gets status flags.
void ACMP_ClearStatusFlags (CMP_Type *base, uint32_t mask)
 Clears status flags.
Typedef Documentation
◆ acmp_channel_config_t
The comparator's port can be input from channel mux or DAC. If port input is from channel mux, detailed channel number for the mux should be configured.
◆ acmp_hysteresis_mode_t
See chip data sheet to get the actual hysteresis value with each level.
◆ _acmp_fixed_port
Fixed mux port.
kACMP_FixedPlusPort
Only the inputs to the Minus port are swept in each round.
Only the inputs to the Plus port are swept in each round.
◆ _acmp_hysteresis_mode
Offset is level 0 and Hysteresis is level 0.
Offset is level 0 and Hysteresis is level 1.
Offset is level 0 and Hysteresis is level 2.
Offset is level 0 and Hysteresis is level 3.
◆ _acmp_interrupt_enable
Enable the interrupt when comparator outputs rising.
Enable the interrupt when comparator outputs falling.
Enable the Round-Robin interrupt.
◆ _acmp_reference_voltage_source
Vin1 is selected as resistor ladder network supply reference Vin.
Vin2 is selected as resistor ladder network supply reference Vin.
◆ _acmp_status_flags
Status flag mask.
Rising-edge on compare output has occurred.
Falling-edge on compare output has occurred.
Return the current value of the analog comparator output.
◆ ACMP_ClearRoundRobinStatusFlags()
void ACMP_ClearRoundRobinStatusFlags ( CMP_Type base,
uint32_t  mask
Parameters
baseACMP peripheral base address.
maskMask of channel index. Available range is channel0:0x01 to channel7:0x80.
brief Clears the channel input changed flags in round robin mode.
param base ACMP peripheral base address. param mask Mask of channel index. Available range is channel0:0x01 to channel7:0x80.
◆ ACMP_ClearStatusFlags()
void ACMP_ClearStatusFlags ( CMP_Type base,
uint32_t  mask
Parameters
maskStatus flags mask. See "_acmp_status_flags".
brief Clears status flags.
param base ACMP peripheral base address. param mask Status flags mask. See "_acmp_status_flags".
◆ ACMP_Deinit()
void ACMP_Deinit ( CMP_Type base)
Parameters
brief Deinitializes the ACMP.
◆ ACMP_DisableInterrupts()
void ACMP_DisableInterrupts ( CMP_Type base,
uint32_t  mask
Parameters
maskInterrupts mask. See "_acmp_interrupt_enable".
brief Disables interrupts.
param base ACMP peripheral base address. param mask Interrupts mask. See "_acmp_interrupt_enable".
◆ ACMP_Enable()
void ACMP_Enable ( CMP_Type base,
bool  enable
Parameters
enableTrue to enable the ACMP.
brief Enables or disables the ACMP.
param base ACMP peripheral base address. param enable True to enable the ACMP.
◆ ACMP_EnableDMA()
void ACMP_EnableDMA ( CMP_Type base,
bool  enable
Parameters
enableTrue to enable DMA.
brief Enables or disables DMA.
param base ACMP peripheral base address. param enable True to enable DMA.
◆ ACMP_EnableInterrupts()
void ACMP_EnableInterrupts ( CMP_Type base,
uint32_t  mask
Enables interrupts.
Parameters
brief Enables interrupts.
◆ ACMP_EnableWindowMode()
void ACMP_EnableWindowMode ( CMP_Type base,
bool  enable
Parameters
enableTrue to enable window mode.
brief Enables or disables window mode.
param base ACMP peripheral base address. param enable True to enable window mode.
◆ ACMP_GetDefaultConfig()
void ACMP_GetDefaultConfig ( acmp_config_t config)
This function initializes the user configuration structure to default value. The default value are:
Example:
config->enableHighSpeed = false;
config->enableInvertOutput = false;
config->useUnfilteredOutput = false;
config->enablePinOut = false;
config->enableHysteresisBothDirections = false;
config->hysteresisMode = kACMP_hysteresisMode0;
Definition: deflate.c:114
Parameters
configPointer to ACMP configuration structure.
brief Gets the default configuration for ACMP.
Example: code config->enableHighSpeed = false; config->enableInvertOutput = false; config->useUnfilteredOutput = false; config->enablePinOut = false; config->enableHysteresisBothDirections = false; config->hysteresisMode = kACMP_hysteresisMode0; endcode
param config Pointer to ACMP configuration structure.
◆ ACMP_GetStatusFlags()
uint32_t ACMP_GetStatusFlags ( CMP_Type base)
Gets status flags.
Parameters
Returns
Status flags asserted mask. See "_acmp_status_flags".
brief Gets status flags.
param base ACMP peripheral base address. return Status flags asserted mask. See "_acmp_status_flags".
◆ ACMP_Init()
void ACMP_Init ( CMP_Type base,
const acmp_config_t config
The default configuration can be got by calling ACMP_GetDefaultConfig().
Parameters
brief Initializes the ACMP.
param base ACMP peripheral base address. param config Pointer to ACMP configuration structure.
◆ ACMP_SetChannelConfig()
void ACMP_SetChannelConfig ( CMP_Type base,
const acmp_channel_config_t config
Note that the plus/minus mux's setting is only valid when the positive/negative port's input isn't from DAC but from channel mux.
Example:
acmp_channel_config_t configStruct = {0};
configStruct.positivePortInput = kACMP_PortInputFromDAC;
configStruct.negativePortInput = kACMP_PortInputFromMux;
configStruct.minusMuxInput = 1U;
ACMP_SetChannelConfig(CMP0, &configStruct);
void ACMP_SetChannelConfig(CMP_Type *base, const acmp_channel_config_t *config)
Definition: fsl_acmp.c:230
uint32_t minusMuxInput
Definition: fsl_acmp.h:139
Definition: fsl_acmp.h:131
Parameters
configPointer to channel configuration structure.
brief Sets the channel configuration.
Example: code acmp_channel_config_t configStruct = {0}; configStruct.positivePortInput = kACMP_PortInputFromDAC; configStruct.negativePortInput = kACMP_PortInputFromMux; configStruct.minusMuxInput = 1U; ACMP_SetChannelConfig(CMP0, &configStruct); endcode
param base ACMP peripheral base address. param config Pointer to channel configuration structure.
◆ ACMP_SetDACConfig()
void ACMP_SetDACConfig ( CMP_Type base,
const acmp_dac_config_t config
Example:
acmp_dac_config_t configStruct = {0};
configStruct.DACValue = 20U;
configStruct.enableOutput = false;
configStruct.workMode = kACMP_DACWorkLowSpeedMode;
ACMP_SetDACConfig(CMP0, &configStruct);
uint32_t DACValue
Definition: fsl_acmp.h:154
void ACMP_SetDACConfig(CMP_Type *base, const acmp_dac_config_t *config)
Definition: fsl_acmp.c:348
acmp_reference_voltage_source_t referenceVoltageSource
Definition: fsl_acmp.h:153
@ kACMP_VrefSourceVin1
Definition: fsl_acmp.h:82
Definition: fsl_acmp.h:152
Parameters
configPointer to DAC configuration structure. "NULL" is for disabling the feature.
brief Configures the internal DAC.
Example: code acmp_dac_config_t configStruct = {0}; configStruct.referenceVoltageSource = kACMP_VrefSourceVin1; configStruct.DACValue = 20U; configStruct.enableOutput = false; configStruct.workMode = kACMP_DACWorkLowSpeedMode; ACMP_SetDACConfig(CMP0, &configStruct); endcode
param base ACMP peripheral base address. param config Pointer to DAC configuration structure. "NULL" is for disabling the feature.
◆ ACMP_SetFilterConfig()
void ACMP_SetFilterConfig ( CMP_Type base,
const acmp_filter_config_t config
The filter can be enabled when the filter count is bigger than 1, the filter period is greater than 0 and the sample clock is from divided bus clock or the filter is bigger than 1 and the sample clock is from external clock. Detailed usage can be got from the reference manual.
Example:
acmp_filter_config_t configStruct = {0};
configStruct.filterCount = 5U;
configStruct.filterPeriod = 200U;
configStruct.enableSample = false;
ACMP_SetFilterConfig(CMP0, &configStruct);
void ACMP_SetFilterConfig(CMP_Type *base, const acmp_filter_config_t *config)
Definition: fsl_acmp.c:315
bool enableSample
Definition: fsl_acmp.h:145
uint32_t filterPeriod
Definition: fsl_acmp.h:147
uint32_t filterCount
Definition: fsl_acmp.h:146
Definition: fsl_acmp.h:144
Parameters
configPointer to filter configuration structure.
brief Configures the filter.
Example: code acmp_filter_config_t configStruct = {0}; configStruct.filterCount = 5U; configStruct.filterPeriod = 200U; configStruct.enableSample = false; ACMP_SetFilterConfig(CMP0, &configStruct); endcode
param base ACMP peripheral base address. param config Pointer to filter configuration structure.
◆ ACMP_SetRoundRobinConfig()
void ACMP_SetRoundRobinConfig ( CMP_Type base,
const acmp_round_robin_config_t config
Example:
acmp_round_robin_config_t configStruct = {0};
configStruct.fixedChannelNumber = 3U;
configStruct.checkerChannelMask = 0xF7U;
configStruct.sampleClockCount = 0U;
configStruct.delayModulus = 0U;
ACMP_SetRoundRobinConfig(CMP0, &configStruct);
uint32_t checkerChannelMask
Definition: fsl_acmp.h:170
uint32_t fixedChannelNumber
Definition: fsl_acmp.h:169
uint32_t delayModulus
Definition: fsl_acmp.h:173
acmp_fixed_port_t fixedPort
Definition: fsl_acmp.h:168
uint32_t sampleClockCount
Definition: fsl_acmp.h:172
void ACMP_SetRoundRobinConfig(CMP_Type *base, const acmp_round_robin_config_t *config)
Definition: fsl_acmp.c:407
@ kACMP_FixedPlusPort
Definition: fsl_acmp.h:98
Definition: fsl_acmp.h:167
Parameters
configPointer to round robin mode configuration structure. "NULL" is for disabling the feature.
brief Configures the round robin mode.
Example: code acmp_round_robin_config_t configStruct = {0}; configStruct.fixedPort = kACMP_FixedPlusPort; configStruct.fixedChannelNumber = 3U; configStruct.checkerChannelMask = 0xF7U; configStruct.sampleClockCount = 0U; configStruct.delayModulus = 0U; ACMP_SetRoundRobinConfig(CMP0, &configStruct); endcode param base ACMP peripheral base address. param config Pointer to round robin mode configuration structure. "NULL" is for disabling the feature.
◆ ACMP_SetRoundRobinPreState()
void ACMP_SetRoundRobinPreState ( CMP_Type base,
uint32_t  mask
Note: The pre-state has different circuit with get-round-robin-result in the SOC even though they are same bits. So get-round-robin-result can't return the same value as the value are set by pre-state.
Parameters
maskMask of round robin channel index. Available range is channel0:0x01 to channel7:0x80.
brief Defines the pre-set state of channels in round robin mode.
param base ACMP peripheral base address. param mask Mask of round robin channel index. Available range is channel0:0x01 to channel7:0x80.
Variable Documentation
◆ checkerChannelMask
Mask of checker channel index. Available range is channel0:0x01 to channel7:0x80 for round-robin checker.
◆ DACValue
Value for DAC Output Voltage. Available range is 0-255.
◆ delayModulus
Comparator and DAC initialization delay modulus.
◆ enableHighSpeed
Enable High Speed (HS) comparison mode.
◆ enableInvertOutput
Enable inverted comparator output.
◆ enablePinOut
The comparator output is available on the associated pin.
◆ enableSample
Using external SAMPLE as sampling clock input, or using divided bus clock.
◆ filterCount
Filter Sample Count. Available range is 1-7, 0 would cause the filter disabled.
◆ filterPeriod
Filter Sample Period. The divider to bus clock. Available range is 0-255.
◆ fixedChannelNumber
Indicates which channel is fixed in the fixed mux port.
◆ fixedPort
Fixed mux port.
◆ hysteresisMode
Hysteresis mode.
◆ minusMuxInput
Minus mux input channel(0~7).
◆ plusMuxInput
Plus mux input channel(0~7).
◆ referenceVoltageSource
Supply voltage reference source.
◆ sampleClockCount
Specifies how many round-robin clock cycles(0~3) later the sample takes place.
◆ useUnfilteredOutput
Set compare output(COUT) to equal COUTA(true) or COUT(false).
