RTEMS 6.1-rc2
Files | Data Structures | Typedefs | Enumerations | Functions
file  tc-intr-set-affinity.c
struct  RtemsIntrReqSetAffinity_Entry
struct  RtemsIntrReqSetAffinity_Context
 Test context for spec:/rtems/intr/req/set-affinity test case. More...
typedef RtemsIntrReqSetAffinity_Context Context
enum  RtemsIntrReqSetAffinity_Pre_Vector { RtemsIntrReqSetAffinity_Pre_Vector_Valid , RtemsIntrReqSetAffinity_Pre_Vector_Invalid , RtemsIntrReqSetAffinity_Pre_Vector_NA }
enum  RtemsIntrReqSetAffinity_Pre_CPUSetSize { RtemsIntrReqSetAffinity_Pre_CPUSetSize_Askew , RtemsIntrReqSetAffinity_Pre_CPUSetSize_Normal , RtemsIntrReqSetAffinity_Pre_CPUSetSize_Huge , RtemsIntrReqSetAffinity_Pre_CPUSetSize_NA }
enum  RtemsIntrReqSetAffinity_Pre_CPUSetOnline { RtemsIntrReqSetAffinity_Pre_CPUSetOnline_Valid , RtemsIntrReqSetAffinity_Pre_CPUSetOnline_Empty , RtemsIntrReqSetAffinity_Pre_CPUSetOnline_NA }
enum  RtemsIntrReqSetAffinity_Pre_CPUSetHuge { RtemsIntrReqSetAffinity_Pre_CPUSetHuge_NotZero , RtemsIntrReqSetAffinity_Pre_CPUSetHuge_Zero , RtemsIntrReqSetAffinity_Pre_CPUSetHuge_NA }
enum  RtemsIntrReqSetAffinity_Pre_CPUSet { RtemsIntrReqSetAffinity_Pre_CPUSet_Valid , RtemsIntrReqSetAffinity_Pre_CPUSet_Null , RtemsIntrReqSetAffinity_Pre_CPUSet_NA }
enum  RtemsIntrReqSetAffinity_Pre_CanSetAffinity { RtemsIntrReqSetAffinity_Pre_CanSetAffinity_Yes , RtemsIntrReqSetAffinity_Pre_CanSetAffinity_No , RtemsIntrReqSetAffinity_Pre_CanSetAffinity_NA }
enum  RtemsIntrReqSetAffinity_Post_Status {
  RtemsIntrReqSetAffinity_Post_Status_Ok , RtemsIntrReqSetAffinity_Post_Status_InvAddr , RtemsIntrReqSetAffinity_Post_Status_InvId , RtemsIntrReqSetAffinity_Post_Status_InvNum ,
  RtemsIntrReqSetAffinity_Post_Status_Unsat , RtemsIntrReqSetAffinity_Post_Status_NA
enum  RtemsIntrReqSetAffinity_Post_SetAffinity { RtemsIntrReqSetAffinity_Post_SetAffinity_Set , RtemsIntrReqSetAffinity_Post_SetAffinity_Nop , RtemsIntrReqSetAffinity_Post_SetAffinity_NA }
 T_TEST_CASE_FIXTURE (RtemsIntrReqSetAffinity, &RtemsIntrReqSetAffinity_Fixture)
