RTEMS 6.1-rc2
Modules | Files | Macros | Variables
spec:/testsuites/validation-acfg-1
This validation test suite is used to validate the default value of application configuration options where all optional BSP provided settings are disabled. More...
 spec:/acfg/val/disabled-bsp-settings
 Tests the default values of application configuration options where all optional BSP provided settings are disabled.
file  ts-validation-acfg-1.c
#define CONFIGURE_INITIAL_EXTENSIONS   { .fatal = FatalExtension }
#define CONFIGURE_DISABLE_BSP_SETTINGS
#define CONFIGURE_IDLE_TASK_STORAGE_SIZE   RTEMS_MINIMUM_STACK_SIZE
#define CONFIGURE_MAXIMUM_TASKS   1
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
const char rtems_test_name [] = "TestsuitesValidationAcfg1"
 Each test must define a test name string.
◆ CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
Value:
#define RTEMS_DEFAULT_ATTRIBUTES
This attribute constant represents the default attribute set.
Definition: attr.h:147
#define RTEMS_TASK_STORAGE_SIZE(_size, _attributes)
Gets the recommended task storage area size for the size and task attributes.
Definition: tasks.h:384
#define RTEMS_MINIMUM_STACK_SIZE
This compile time constant provides the minimum task stack size recommended for the target architectu...
Definition: tasks.h:331
