RTEMS 6.1-rc2
This general purpose performance test suite provides enough resources to run basic performance tests for all specified managers and functions. More...
Modules | |
spec:/rtems/barrier/val/perf | |
This test case provides a context to run Barrier Manager performance tests. | |
spec:/rtems/event/val/perf | |
This test case provides a context to run Event Manager performance tests. | |
spec:/rtems/message/val/perf | |
This test case provides a context to run Message Manager performance tests. | |
spec:/rtems/part/val/perf | |
This test case provides a context to run Partition Manager performance tests. | |
spec:/rtems/sem/val/perf | |
This test case provides a context to run Semaphore Manager performance tests. | |
spec:/rtems/task/val/perf | |
This test case provides a context to run Task Manager performance tests. | |
spec:/score/cpu/val/perf | |
This test case provides a context to run CPU port performance tests. | |
Files | |
file | ts-performance-no-clock-0.c |
#define | CONFIGURE_MAXIMUM_PROCESSORS 4 |
#define | CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER |
const char | rtems_test_name [] = "TestsuitesPerformanceNoClock0" |
Each test must define a test name string. | |
In SMP configurations, up to three scheduler instances using the SMP EDF scheduler are provided using up to four processors.
