RTEMS 6.1-rc2
Modules | Files | Data Structures | Macros | Typedefs | Functions
This test case provides a context to run Task Manager performance tests. More...
 spec:/rtems/task/req/perf-construct
 spec:/rtems/task/req/perf-restart
 spec:/rtems/task/req/perf-restart-preempt
 spec:/rtems/task/req/perf-restart-self
 spec:/rtems/task/req/perf-set-scheduler-nop
 spec:/rtems/task/req/perf-start
 spec:/rtems/task/req/perf-start-preempt
file  tc-task-performance.c
struct  RtemsTaskValPerf_Context
 Test context for spec:/rtems/task/val/perf test case. More...
#define EVENT_RESTART   RTEMS_EVENT_0
#define EVENT_SET_END   RTEMS_EVENT_1
#define EVENT_BUSY   RTEMS_EVENT_2
typedef RtemsTaskValPerf_Context Context
 RTEMS_ALIGNED (RTEMS_TASK_STORAGE_ALIGNMENT)
 T_TEST_CASE_FIXTURE (RtemsTaskValPerf, &RtemsTaskValPerf_Fixture)
