RTEMS 6.1-rc2
Modules | Files | Macros | Functions | Variables
spec:/testsuites/fatal-start-of-mandatory-processor-failed
This validation test suite contains a test case which triggers a fatal error during system initialization. More...
 spec:/score/smp/val/fatal-start-of-mandatory-processor-failed
 Tests a fatal error.
file  ts-fatal-start-of-mandatory-processor-failed.c
#define FATAL_SYSINIT_RUN   ScoreSmpValFatalStartOfMandatoryProcessorFailed_Run
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
#define CONFIGURE_MAXIMUM_PROCESSORS   2
#define CONFIGURE_SCHEDULER_EDF_SMP
#define CONFIGURE_SCHEDULER_TABLE_ENTRIES    RTEMS_SCHEDULER_TABLE_EDF_SMP( a, TEST_SCHEDULER_A_NAME )
#define CONFIGURE_SCHEDULER_ASSIGNMENTS
 RTEMS_SCHEDULER_EDF_SMP (a)
const char rtems_test_name [] = "TestsuitesFatalStartOfMandatoryProcessorFailed"
 Each test must define a test name string.
◆ CONFIGURE_SCHEDULER_ASSIGNMENTS
Value:
RTEMS_SCHEDULER_ASSIGN( 0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY ), \
