RTEMS 6.1-rc2
#define TIM_TRGO_RESET   0x00000000U
#define TIM_TRGO_ENABLE   TIM_CR2_MMS_0
#define TIM_TRGO_UPDATE   TIM_CR2_MMS_1
#define TIM_TRGO_OC1   (TIM_CR2_MMS_1 | TIM_CR2_MMS_0)
#define TIM_TRGO_OC1REF   TIM_CR2_MMS_2
#define TIM_TRGO_OC2REF   (TIM_CR2_MMS_2 | TIM_CR2_MMS_0)
#define TIM_TRGO_OC3REF   (TIM_CR2_MMS_2 | TIM_CR2_MMS_1)
#define TIM_TRGO_OC4REF   (TIM_CR2_MMS_2 | TIM_CR2_MMS_1 | TIM_CR2_MMS_0)
◆ TIM_TRGO_ENABLE
TIMx_CR1.CEN bit is used as trigger output (TRGO)
◆ TIM_TRGO_OC1
Capture or a compare match 1 is used as trigger output (TRGO)
◆ TIM_TRGO_OC1REF
OC1REF signal is used as trigger output (TRGO)
◆ TIM_TRGO_OC2REF
OC2REF signal is used as trigger output(TRGO)
◆ TIM_TRGO_OC3REF
OC3REF signal is used as trigger output(TRGO)
◆ TIM_TRGO_OC4REF
OC4REF signal is used as trigger output(TRGO)
◆ TIM_TRGO_RESET
TIMx_EGR.UG bit is used as trigger output (TRGO)
◆ TIM_TRGO_UPDATE
Update event is used as trigger output (TRGO)
