RTEMS 6.1-rc2
#define TIM_DMABURSTLENGTH_1TRANSFER   0x00000000U
#define TIM_DMABURSTLENGTH_2TRANSFERS   0x00000100U
#define TIM_DMABURSTLENGTH_3TRANSFERS   0x00000200U
#define TIM_DMABURSTLENGTH_4TRANSFERS   0x00000300U
#define TIM_DMABURSTLENGTH_5TRANSFERS   0x00000400U
#define TIM_DMABURSTLENGTH_6TRANSFERS   0x00000500U
#define TIM_DMABURSTLENGTH_7TRANSFERS   0x00000600U
#define TIM_DMABURSTLENGTH_8TRANSFERS   0x00000700U
#define TIM_DMABURSTLENGTH_9TRANSFERS   0x00000800U
#define TIM_DMABURSTLENGTH_10TRANSFERS   0x00000900U
#define TIM_DMABURSTLENGTH_11TRANSFERS   0x00000A00U
#define TIM_DMABURSTLENGTH_12TRANSFERS   0x00000B00U
#define TIM_DMABURSTLENGTH_13TRANSFERS   0x00000C00U
#define TIM_DMABURSTLENGTH_14TRANSFERS   0x00000D00U
#define TIM_DMABURSTLENGTH_15TRANSFERS   0x00000E00U
#define TIM_DMABURSTLENGTH_16TRANSFERS   0x00000F00U
#define TIM_DMABURSTLENGTH_17TRANSFERS   0x00001000U
#define TIM_DMABURSTLENGTH_18TRANSFERS   0x00001100U
◆ TIM_DMABURSTLENGTH_10TRANSFERS
The transfer is done to 10 registers starting from TIMx_CR1 + TIMx_DCR.DBA
◆ TIM_DMABURSTLENGTH_11TRANSFERS
The transfer is done to 11 registers starting from TIMx_CR1 + TIMx_DCR.DBA
◆ TIM_DMABURSTLENGTH_12TRANSFERS
The transfer is done to 12 registers starting from TIMx_CR1 + TIMx_DCR.DBA
◆ TIM_DMABURSTLENGTH_13TRANSFERS
The transfer is done to 13 registers starting from TIMx_CR1 + TIMx_DCR.DBA
◆ TIM_DMABURSTLENGTH_14TRANSFERS
The transfer is done to 14 registers starting from TIMx_CR1 + TIMx_DCR.DBA
◆ TIM_DMABURSTLENGTH_15TRANSFERS
The transfer is done to 15 registers starting from TIMx_CR1 + TIMx_DCR.DBA
◆ TIM_DMABURSTLENGTH_16TRANSFERS
The transfer is done to 16 registers starting from TIMx_CR1 + TIMx_DCR.DBA
◆ TIM_DMABURSTLENGTH_17TRANSFERS
The transfer is done to 17 registers starting from TIMx_CR1 + TIMx_DCR.DBA
◆ TIM_DMABURSTLENGTH_18TRANSFERS
The transfer is done to 18 registers starting from TIMx_CR1 + TIMx_DCR.DBA
◆ TIM_DMABURSTLENGTH_1TRANSFER
The transfer is done to 1 register starting from TIMx_CR1 + TIMx_DCR.DBA
◆ TIM_DMABURSTLENGTH_2TRANSFERS
The transfer is done to 2 registers starting from TIMx_CR1 + TIMx_DCR.DBA
◆ TIM_DMABURSTLENGTH_3TRANSFERS
The transfer is done to 3 registers starting from TIMx_CR1 + TIMx_DCR.DBA
◆ TIM_DMABURSTLENGTH_4TRANSFERS
The transfer is done to 4 registers starting from TIMx_CR1 + TIMx_DCR.DBA
◆ TIM_DMABURSTLENGTH_5TRANSFERS
The transfer is done to 5 registers starting from TIMx_CR1 + TIMx_DCR.DBA
◆ TIM_DMABURSTLENGTH_6TRANSFERS
The transfer is done to 6 registers starting from TIMx_CR1 + TIMx_DCR.DBA
◆ TIM_DMABURSTLENGTH_7TRANSFERS
The transfer is done to 7 registers starting from TIMx_CR1 + TIMx_DCR.DBA
◆ TIM_DMABURSTLENGTH_8TRANSFERS
The transfer is done to 8 registers starting from TIMx_CR1 + TIMx_DCR.DBA
◆ TIM_DMABURSTLENGTH_9TRANSFERS
The transfer is done to 9 registers starting from TIMx_CR1 + TIMx_DCR.DBA
