RTEMS 6.1-rc2
#define __HAL_SYSCFG_BREAK_AXISRAM_DBL_ECC_LOCK()   SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_AXISRAML)
 SYSCFG Break AXIRAM double ECC lock. Enable and lock the connection of AXIRAM double ECC error to TIM1/8/15/16/17 and HRTIMER Break input.
#define __HAL_SYSCFG_BREAK_ITCM_DBL_ECC_LOCK()   SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_ITCML)
 SYSCFG Break ITCM double ECC lock. Enable and lock the connection of ITCM double ECC error to TIM1/8/15/16/17 and HRTIMER Break input.
#define __HAL_SYSCFG_BREAK_DTCM_DBL_ECC_LOCK()   SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_DTCML)
 SYSCFG Break DTCM double ECC lock. Enable and lock the connection of DTCM double ECC error to TIM1/8/15/16/17 and HRTIMER Break input.
#define __HAL_SYSCFG_BREAK_SRAM1_DBL_ECC_LOCK()   SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_SRAM1L)
 SYSCFG Break SRAM1 double ECC lock. Enable and lock the connection of SRAM1 double ECC error to TIM1/8/15/16/17 and HRTIMER Break input.
#define __HAL_SYSCFG_BREAK_SRAM2_DBL_ECC_LOCK()   SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_SRAM2L)
 SYSCFG Break SRAM2 double ECC lock. Enable and lock the connection of SRAM2 double ECC error to TIM1/8/15/16/17 and HRTIMER Break input.
#define __HAL_SYSCFG_BREAK_SRAM3_DBL_ECC_LOCK()   SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_SRAM3L)
 SYSCFG Break SRAM3 double ECC lock. Enable and lock the connection of SRAM3 double ECC error to TIM1/8/15/16/17 and HRTIMER Break input.
#define __HAL_SYSCFG_BREAK_SRAM4_DBL_ECC_LOCK()   SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_SRAM4L)
 SYSCFG Break SRAM4 double ECC lock. Enable and lock the connection of SRAM4 double ECC error to TIM1/8/15/16/17 and HRTIMER Break input.
#define __HAL_SYSCFG_BREAK_BKRAM_DBL_ECC_LOCK()   SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_BKRAML)
 SYSCFG Break Backup SRAM double ECC lock. Enable and lock the connection of Backup SRAM double ECC error to TIM1/8/15/16/17 and HRTIMER Break input.
#define __HAL_SYSCFG_BREAK_CM7_LOCKUP_LOCK()   SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_CM7L)
 SYSCFG Break Cortex-M7 Lockup lock. Enable and lock the connection of Cortex-M7 LOCKUP output to TIM1/8/15/16/17 and HRTIMER Break input.
#define __HAL_SYSCFG_BREAK_FLASH_DBL_ECC_LOCK()   SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_FLASHL)
 SYSCFG Break FLASH double ECC lock. Enable and lock the connection of Flash double ECC error connection to TIM1/8/15/16/17 and HRTIMER Break input.
#define __HAL_SYSCFG_BREAK_PVD_LOCK()   SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_PVDL)
 SYSCFG Break PVD lock. Enable and lock the PVD connection to Timer1/8/15/16/17 and HRTIMER Break input, as well as the PVDE and PLS[2:0] in the PWR_CR1 register.
#define __HAL_SYSCFG_FASTMODEPLUS_ENABLE(__FASTMODEPLUS__)
 Fast-mode Plus driving capability enable/disable macros.
#define __HAL_SYSCFG_FASTMODEPLUS_DISABLE(__FASTMODEPLUS__)
◆ __HAL_SYSCFG_BREAK_AXISRAM_DBL_ECC_LOCK
#define __HAL_SYSCFG_BREAK_AXISRAM_DBL_ECC_LOCK ( )    SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_AXISRAML)
Note
The selected configuration is locked and can be unlocked only by system reset. This feature is available on STM32H7 rev.B and above.
◆ __HAL_SYSCFG_BREAK_BKRAM_DBL_ECC_LOCK
#define __HAL_SYSCFG_BREAK_BKRAM_DBL_ECC_LOCK ( )    SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_BKRAML)
Note
◆ __HAL_SYSCFG_BREAK_CM7_LOCKUP_LOCK
#define __HAL_SYSCFG_BREAK_CM7_LOCKUP_LOCK ( )    SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_CM7L)
Note
◆ __HAL_SYSCFG_BREAK_DTCM_DBL_ECC_LOCK
#define __HAL_SYSCFG_BREAK_DTCM_DBL_ECC_LOCK ( )    SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_DTCML)
Note
◆ __HAL_SYSCFG_BREAK_FLASH_DBL_ECC_LOCK
#define __HAL_SYSCFG_BREAK_FLASH_DBL_ECC_LOCK ( )    SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_FLASHL)
Note
◆ __HAL_SYSCFG_BREAK_ITCM_DBL_ECC_LOCK
#define __HAL_SYSCFG_BREAK_ITCM_DBL_ECC_LOCK ( )    SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_ITCML)
Note
◆ __HAL_SYSCFG_BREAK_PVD_LOCK
#define __HAL_SYSCFG_BREAK_PVD_LOCK ( )    SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_PVDL)
Note
◆ __HAL_SYSCFG_BREAK_SRAM1_DBL_ECC_LOCK
#define __HAL_SYSCFG_BREAK_SRAM1_DBL_ECC_LOCK ( )    SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_SRAM1L)
Note
◆ __HAL_SYSCFG_BREAK_SRAM2_DBL_ECC_LOCK
#define __HAL_SYSCFG_BREAK_SRAM2_DBL_ECC_LOCK ( )    SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_SRAM2L)
Note
◆ __HAL_SYSCFG_BREAK_SRAM3_DBL_ECC_LOCK
#define __HAL_SYSCFG_BREAK_SRAM3_DBL_ECC_LOCK ( )    SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_SRAM3L)
Note
◆ __HAL_SYSCFG_BREAK_SRAM4_DBL_ECC_LOCK
#define __HAL_SYSCFG_BREAK_SRAM4_DBL_ECC_LOCK ( )    SET_BIT(SYSCFG->CFGR, SYSCFG_CFGR_SRAM4L)
Note
◆ __HAL_SYSCFG_FASTMODEPLUS_DISABLE
#define __HAL_SYSCFG_FASTMODEPLUS_DISABLE (   __FASTMODEPLUS__)
Value:
do {assert_param(IS_SYSCFG_FASTMODEPLUS((__FASTMODEPLUS__)));\
CLEAR_BIT(SYSCFG->PMCR, (__FASTMODEPLUS__));\
}while(0)
◆ __HAL_SYSCFG_FASTMODEPLUS_ENABLE
#define __HAL_SYSCFG_FASTMODEPLUS_ENABLE (   __FASTMODEPLUS__)
Value:
SET_BIT(SYSCFG->PMCR, (__FASTMODEPLUS__));\
}while(0)
Parameters
__FASTMODEPLUS__This parameter can be a value of :
