RTEMS 6.1-rc2
Files | Data Structures | Typedefs | Functions
Tests a signal constant of the Signal Manager using the signal set of the executing task. More...
file  tr-signal-constant.c
file  tr-signal-constant.h
struct  RtemsSignalValSignalConstant_Context
 Test context for spec:/rtems/signal/val/signal-constant test case. More...
typedef RtemsSignalValSignalConstant_Context Context
void RtemsSignalValSignalConstant_Run (rtems_signal_set signal, int number)
 Runs the parameterized test case.
This test case performs the following actions:
◆ RtemsSignalValSignalConstant_Run()
void RtemsSignalValSignalConstant_Run ( rtems_signal_set  signal,
int  number
Parameters
signalis the signal constant.
numberis the signal number.
