RTEMS 6.1-rc2
Files | Data Structures | Functions
Tests an event constant and number of the Event Manager using the Classic and system event sets of the executing task. More...
file  tr-event-constant.c
file  tr-event-constant.h
struct  RtemsEventValEventConstant_Context
 Test context for spec:/rtems/event/val/event-constant test case. More...
void RtemsEventValEventConstant_Run (rtems_event_set event, int number)
 Runs the parameterized test case.
This test case performs the following actions:
◆ RtemsEventValEventConstant_Run()
void RtemsEventValEventConstant_Run ( rtems_event_set  event,
int  number
Parameters
eventis the event constant.
numberis the event number.
