Test support functions.
More...
enum | RTEMS_TEST_STATE {
RTEMS_TEST_STATE_PASS
, RTEMS_TEST_STATE_FAIL
, RTEMS_TEST_STATE_USER_INPUT
, RTEMS_TEST_STATE_INDETERMINATE
RTEMS_TEST_STATE_BENCHMARK
| Test states.
void | rtems_test_fatal_extension (rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code) |
| Fatal extension for tests.
int | rtems_test_begin (const char *name, const RTEMS_TEST_STATE state) |
| Prints a begin of test message using printf().
int | rtems_test_end (const char *name) |
| Prints an end of test message using printf().
RTEMS_NO_RETURN void | rtems_test_exit (int status) |
| Exit the test without calling exit() since it closes stdin, etc and pulls in stdio code.
void | rtems_test_parallel (rtems_test_parallel_context *ctx, rtems_test_parallel_worker_setup worker_setup, const rtems_test_parallel_job *jobs, size_t job_count) |
| Runs a bunch of jobs in parallel on all processors of the system.
void | rtems_test_busy_cpu_usage (time_t seconds, long nanoseconds) |
| Performs a busy loop for the specified seconds and nanoseconds based on the CPU usage of the executing thread.
RTEMS_NO_RETURN void | rtems_test_run (rtems_task_argument arg, const RTEMS_TEST_STATE state) |
| Runs the test cases of the RTEMS Test Framework using a default configuration in the context of a task.
void | rtems_test_gcov_dump_info (void) |
| Dumps the gcov information as a base64 encoded gcfn and gcda data stream using rtems_put_char().
int | rtems_test_printf (const char *format,...) RTEMS_PRINTFLIKE(1 |
| Prints via the RTEMS test printer.
const char | rtems_test_name [] |
| Each test must define a test name string.
rtems_printer | rtems_test_printer |
| Provides an RTEMS printer for tests.
◆ rtems_test_parallel_worker_setup
Worker task setup handler.
Called during rtems_test_parallel() to optionally setup a worker task before it is started.
- Parameters
[in] | ctx | The parallel context. |
[in] | worker_index | The worker index. |
[in] | worker_id | The worker task identifier. |
◆ rtems_test_begin()
- Returns
- As specified by printf().
◆ rtems_test_busy_cpu_usage()
void rtems_test_busy_cpu_usage |
time_t |
seconds, |
long |
nanoseconds |
This function continuously reads the CPU usage of the executing thread. This operation may lead to a scheduler instance lock contention in SMP configurations.
- Parameters
[in] | seconds | The busy seconds. |
[in] | nanoseconds | The busy nanoseconds. |
◆ rtems_test_end()
int rtems_test_end |
const char * |
name | ) |
- Returns
◆ rtems_test_parallel()
The worker tasks inherit the priority of the executing task.
There are SMP barriers before and after the job body.
- Parameters
[in] | worker_setup | Optional handler to setup a worker task before it is started. |
[in] | jobs | The table of jobs. |
[in] | job_count | The count of jobs in the job table. |
◆ rtems_test_printf()
int rtems_test_printf |
const char * |
format, |
- Returns
- Returns the count of output characters as specified by printf().
◆ rtems_test_run()
The application must provide rtems_test_name.
- Parameters
arg | is the task argument. |
state | is the test state. |
