RTEMS 6.1-rc2
Processor Dependent Context Management
Destroys the context of the thread.
Initializes and validates the CPU context with values derived from the pattern parameter.
Clobbers all volatile registers with values derived from the pattern parameter.
Performs a context switch from the executing thread to the heir thread and does not return.
Performs a context switch from the executing thread to the heir thread.
From the highest level viewpoint, there are 2 types of context to save.
  1. Interrupt registers to save
  2. Task level registers to save
Since RTEMS handles integer and floating point contexts separately, this means we have the following 3 context items:
  1. task level context stuff:: Context_Control
  2. floating point task stuff:: Context_Control_fp
  3. special interrupt level context :: CPU_Interrupt_frame
On some processors, it is cost-effective to save only the callee preserved registers during a task context switch. This means that the ISR code needs to save those registers which do not persist across function calls. It is not mandatory to make this distinctions between the caller/callee saves registers for the purpose of minimizing context saved during task switch and on interrupts. If the cost of saving extra registers is minimal, simplicity is the choice. Save the same context on interrupt entry as for tasks in this case.
Additionally, if gdb is to be made aware of RTEMS tasks for this CPU, then care should be used in designing the context area.
On some CPUs with hardware floating point support, the Context_Control_fp structure will not be used or it simply consist of an array of a fixed number of bytes. This is done when the floating point context is dumped by a "FP save context" type instruction and the format is not really defined by the CPU. In this case, there is no need to figure out the exact format – only the size. Of course, although this is enough information for RTEMS, it is probably not enough for a debugger such as gdb. But that is another problem.
Port Specific Information:
XXX document implementation including references if appropriate
The size of the floating point context area. On some CPUs this will not be a "sizeof" because the format of the floating point area is not defined – only the size is. This is usually on CPUs with a "floating point save context" instruction.
Should be large enough to run all RTEMS tests. This ensures that a "reasonable" small application should not have any problems. The size shall be a power of two.
It must be implemented as a macro and an implementation is optional. The default implementation does nothing.
Parameters
[in]_the_threadThe corresponding thread.
[in]_the_contextThe context to destroy.
Initialize the context to a state suitable for starting a task after a context restore operation. Generally, this involves:
This routine generally does not set any unnecessary register in the context. The state of the "general data" registers is undefined at task start time.
The ISR dispatch disable field of the context must be cleared to zero if it is used by the CPU port. Otherwise, a thread restart results in unpredictable behaviour.
Parameters
[in]_the_contextis the context structure to be initialized
[in]_stack_baseis the lowest physical address of this task's stack
[in]_sizeis the size of this task's stack
[in]_isris the interrupt disable level
[in]_entry_pointis the thread's entry point. This is always _Thread_Handler
[in]_is_fpis TRUE if the thread is to be a floating point thread. This is typically only used on CPUs where the FPU may be easily disabled by software such as on the SPARC where the PSR contains an enable FPU bit.
[in]_tls_areaThe thread-local storage (TLS) area.
This routine switches from the executing context to the heir context.
Parameters
[out]executingpoints to the context of the currently executing task.
[in,out]heirpoints to the context of the heir task.
This routine shall be a strong alias to _CPU_Context_switch(). It shall be provided for all target architectures which support an SMP build configuration (RTEMS_SMP). The purpose is help to compiler to avoid generation of dead code in _Thread_Start_multitasking().
Parameters
This routine is generally used only to restart self in an efficient manner. It may simply be a label in _CPU_Context_switch.
Parameters
[in]new_contextpoints to the context to be restored.
NOTE: May be unnecessary to reload some registers.
This routine saves the floating point context passed to it.
Parameters
[in]fp_context_ptris a pointer to a pointer to a floating point context area
Returns
on output *fp_context_ptr will contain the address that should be used with _CPU_Context_restore_fp to restore this context.
This routine restores the floating point context passed to it.
Parameters
[in]fp_context_ptris a pointer to a pointer to a floating point context area to restore
Returns
on output *fp_context_ptr will contain the address that should be used with _CPU_Context_save_fp to save this context.
This function is used only in test sptests/spcontext01.
Parameters
[in]patternPattern used to generate distinct register values.
See also
_CPU_Context_validate().
This function will not return if the CPU context remains consistent. In case this function returns the CPU port is broken.
Parameters
See also
_CPU_Context_volatile_clobber().
