RTEMS 6.1-rc2
PCI trace Control and Status register (TCTRC)
This group contains register bit definitions. More...
#define GRPCI2_TCTRC_TRIG_INDEX_SHIFT   16
#define GRPCI2_TCTRC_TRIG_INDEX_MASK   0xffff0000U
#define GRPCI2_TCTRC_TRIG_INDEX_GET(_reg)
#define GRPCI2_TCTRC_TRIG_INDEX_SET(_reg, _val)
#define GRPCI2_TCTRC_TRIG_INDEX(_val)
#define GRPCI2_TCTRC_AR   0x8000U
#define GRPCI2_TCTRC_EN   0x4000U
#define GRPCI2_TCTRC_DEPTH_SHIFT   4
#define GRPCI2_TCTRC_DEPTH_MASK   0xff0U
#define GRPCI2_TCTRC_DEPTH_GET(_reg)
#define GRPCI2_TCTRC_DEPTH_SET(_reg, _val)
#define GRPCI2_TCTRC_DEPTH(_val)
#define GRPCI2_TCTRC_SO   0x2U
#define GRPCI2_TCTRC_SA   0x1U
◆ GRPCI2_TCTRC_DEPTH
#define GRPCI2_TCTRC_DEPTH (   _val)
Value:
( ( ( _val ) << GRPCI2_TCTRC_DEPTH_SHIFT ) & \
GRPCI2_TCTRC_DEPTH_MASK )
◆ GRPCI2_TCTRC_DEPTH_GET
#define GRPCI2_TCTRC_DEPTH_GET (   _reg)
Value:
( ( ( _reg ) & GRPCI2_TCTRC_DEPTH_MASK ) >> \
◆ GRPCI2_TCTRC_DEPTH_SET
#define GRPCI2_TCTRC_DEPTH_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GRPCI2_TCTRC_DEPTH_MASK ) | \
GRPCI2_TCTRC_DEPTH_MASK ) )
◆ GRPCI2_TCTRC_TRIG_INDEX
#define GRPCI2_TCTRC_TRIG_INDEX (   _val)
Value:
( ( ( _val ) << GRPCI2_TCTRC_TRIG_INDEX_SHIFT ) & \
GRPCI2_TCTRC_TRIG_INDEX_MASK )
◆ GRPCI2_TCTRC_TRIG_INDEX_GET
#define GRPCI2_TCTRC_TRIG_INDEX_GET (   _reg)
Value:
( ( ( _reg ) & GRPCI2_TCTRC_TRIG_INDEX_MASK ) >> \
◆ GRPCI2_TCTRC_TRIG_INDEX_SET
#define GRPCI2_TCTRC_TRIG_INDEX_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GRPCI2_TCTRC_TRIG_INDEX_MASK ) | \
GRPCI2_TCTRC_TRIG_INDEX_MASK ) )
