RTEMS 6.1-rc2
SDRAM configuration register 1 (SDCFG1)
This group contains register bit definitions. More...
#define MMCTRL_SDCFG1_RF   0x80000000U
#define MMCTRL_SDCFG1_TRP   0x40000000U
#define MMCTRL_SDCFG1_TRFC_SHIFT   27
#define MMCTRL_SDCFG1_TRFC_MASK   0x38000000U
#define MMCTRL_SDCFG1_TRFC_GET(_reg)
#define MMCTRL_SDCFG1_TRFC_SET(_reg, _val)
#define MMCTRL_SDCFG1_TRFC(_val)
#define MMCTRL_SDCFG1_TC   0x4000000U
#define MMCTRL_SDCFG1_BANKSZ_SHIFT   23
#define MMCTRL_SDCFG1_BANKSZ_MASK   0x3800000U
#define MMCTRL_SDCFG1_BANKSZ_GET(_reg)
#define MMCTRL_SDCFG1_BANKSZ_SET(_reg, _val)
#define MMCTRL_SDCFG1_BANKSZ(_val)
#define MMCTRL_SDCFG1_COLSZ_SHIFT   21
#define MMCTRL_SDCFG1_COLSZ_MASK   0x600000U
#define MMCTRL_SDCFG1_COLSZ_GET(_reg)
#define MMCTRL_SDCFG1_COLSZ_SET(_reg, _val)
#define MMCTRL_SDCFG1_COLSZ(_val)
#define MMCTRL_SDCFG1_COMMAND_SHIFT   18
#define MMCTRL_SDCFG1_COMMAND_MASK   0x1c0000U
#define MMCTRL_SDCFG1_COMMAND_GET(_reg)
#define MMCTRL_SDCFG1_COMMAND_SET(_reg, _val)
#define MMCTRL_SDCFG1_COMMAND(_val)
#define MMCTRL_SDCFG1_MS   0x10000U
#define MMCTRL_SDCFG1_64   0x8000U
#define MMCTRL_SDCFG1_RFLOAD_SHIFT   0
#define MMCTRL_SDCFG1_RFLOAD_MASK   0x7fffU
#define MMCTRL_SDCFG1_RFLOAD_GET(_reg)
#define MMCTRL_SDCFG1_RFLOAD_SET(_reg, _val)
#define MMCTRL_SDCFG1_RFLOAD(_val)
◆ MMCTRL_SDCFG1_BANKSZ
#define MMCTRL_SDCFG1_BANKSZ (   _val)
Value:
( ( ( _val ) << MMCTRL_SDCFG1_BANKSZ_SHIFT ) & \
MMCTRL_SDCFG1_BANKSZ_MASK )
◆ MMCTRL_SDCFG1_BANKSZ_GET
#define MMCTRL_SDCFG1_BANKSZ_GET (   _reg)
Value:
( ( ( _reg ) & MMCTRL_SDCFG1_BANKSZ_MASK ) >> \
◆ MMCTRL_SDCFG1_BANKSZ_SET
#define MMCTRL_SDCFG1_BANKSZ_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~MMCTRL_SDCFG1_BANKSZ_MASK ) | \
MMCTRL_SDCFG1_BANKSZ_MASK ) )
◆ MMCTRL_SDCFG1_COLSZ
#define MMCTRL_SDCFG1_COLSZ (   _val)
Value:
( ( ( _val ) << MMCTRL_SDCFG1_COLSZ_SHIFT ) & \
MMCTRL_SDCFG1_COLSZ_MASK )
◆ MMCTRL_SDCFG1_COLSZ_GET
#define MMCTRL_SDCFG1_COLSZ_GET (   _reg)
Value:
( ( ( _reg ) & MMCTRL_SDCFG1_COLSZ_MASK ) >> \
◆ MMCTRL_SDCFG1_COLSZ_SET
#define MMCTRL_SDCFG1_COLSZ_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~MMCTRL_SDCFG1_COLSZ_MASK ) | \
MMCTRL_SDCFG1_COLSZ_MASK ) )
◆ MMCTRL_SDCFG1_COMMAND
#define MMCTRL_SDCFG1_COMMAND (   _val)
Value:
( ( ( _val ) << MMCTRL_SDCFG1_COMMAND_SHIFT ) & \
MMCTRL_SDCFG1_COMMAND_MASK )
◆ MMCTRL_SDCFG1_COMMAND_GET
#define MMCTRL_SDCFG1_COMMAND_GET (   _reg)
Value:
( ( ( _reg ) & MMCTRL_SDCFG1_COMMAND_MASK ) >> \
◆ MMCTRL_SDCFG1_COMMAND_SET
#define MMCTRL_SDCFG1_COMMAND_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~MMCTRL_SDCFG1_COMMAND_MASK ) | \
MMCTRL_SDCFG1_COMMAND_MASK ) )
◆ MMCTRL_SDCFG1_RFLOAD
#define MMCTRL_SDCFG1_RFLOAD (   _val)
Value:
( ( ( _val ) << MMCTRL_SDCFG1_RFLOAD_SHIFT ) & \
MMCTRL_SDCFG1_RFLOAD_MASK )
◆ MMCTRL_SDCFG1_RFLOAD_GET
#define MMCTRL_SDCFG1_RFLOAD_GET (   _reg)
Value:
( ( ( _reg ) & MMCTRL_SDCFG1_RFLOAD_MASK ) >> \
◆ MMCTRL_SDCFG1_RFLOAD_SET
#define MMCTRL_SDCFG1_RFLOAD_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~MMCTRL_SDCFG1_RFLOAD_MASK ) | \
MMCTRL_SDCFG1_RFLOAD_MASK ) )
◆ MMCTRL_SDCFG1_TRFC
#define MMCTRL_SDCFG1_TRFC (   _val)
Value:
( ( ( _val ) << MMCTRL_SDCFG1_TRFC_SHIFT ) & \
MMCTRL_SDCFG1_TRFC_MASK )
◆ MMCTRL_SDCFG1_TRFC_GET
#define MMCTRL_SDCFG1_TRFC_GET (   _reg)
Value:
( ( ( _reg ) & MMCTRL_SDCFG1_TRFC_MASK ) >> \
◆ MMCTRL_SDCFG1_TRFC_SET
#define MMCTRL_SDCFG1_TRFC_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~MMCTRL_SDCFG1_TRFC_MASK ) | \
MMCTRL_SDCFG1_TRFC_MASK ) )
