RTEMS 6.1-rc2
Status register (STAT)
This group contains register bit definitions. More...
#define MEMSCRUB_STAT_RUNCOUNT_SHIFT   22
#define MEMSCRUB_STAT_RUNCOUNT_MASK   0xffc00000U
#define MEMSCRUB_STAT_RUNCOUNT_GET(_reg)
#define MEMSCRUB_STAT_RUNCOUNT_SET(_reg, _val)
#define MEMSCRUB_STAT_RUNCOUNT(_val)
#define MEMSCRUB_STAT_BLKCOUNT_SHIFT   14
#define MEMSCRUB_STAT_BLKCOUNT_MASK   0x3fc000U
#define MEMSCRUB_STAT_BLKCOUNT_GET(_reg)
#define MEMSCRUB_STAT_BLKCOUNT_SET(_reg, _val)
#define MEMSCRUB_STAT_BLKCOUNT(_val)
#define MEMSCRUB_STAT_DONE   0x2000U
#define MEMSCRUB_STAT_BURSTLEN_SHIFT   1
#define MEMSCRUB_STAT_BURSTLEN_MASK   0x1eU
#define MEMSCRUB_STAT_BURSTLEN_GET(_reg)
#define MEMSCRUB_STAT_BURSTLEN_SET(_reg, _val)
#define MEMSCRUB_STAT_BURSTLEN(_val)
#define MEMSCRUB_STAT_ACTIVE   0x1U
◆ MEMSCRUB_STAT_BLKCOUNT
#define MEMSCRUB_STAT_BLKCOUNT (   _val)
Value:
( ( ( _val ) << MEMSCRUB_STAT_BLKCOUNT_SHIFT ) & \
MEMSCRUB_STAT_BLKCOUNT_MASK )
◆ MEMSCRUB_STAT_BLKCOUNT_GET
#define MEMSCRUB_STAT_BLKCOUNT_GET (   _reg)
Value:
( ( ( _reg ) & MEMSCRUB_STAT_BLKCOUNT_MASK ) >> \
◆ MEMSCRUB_STAT_BLKCOUNT_SET
#define MEMSCRUB_STAT_BLKCOUNT_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~MEMSCRUB_STAT_BLKCOUNT_MASK ) | \
MEMSCRUB_STAT_BLKCOUNT_MASK ) )
◆ MEMSCRUB_STAT_BURSTLEN
#define MEMSCRUB_STAT_BURSTLEN (   _val)
Value:
( ( ( _val ) << MEMSCRUB_STAT_BURSTLEN_SHIFT ) & \
MEMSCRUB_STAT_BURSTLEN_MASK )
◆ MEMSCRUB_STAT_BURSTLEN_GET
#define MEMSCRUB_STAT_BURSTLEN_GET (   _reg)
Value:
( ( ( _reg ) & MEMSCRUB_STAT_BURSTLEN_MASK ) >> \
◆ MEMSCRUB_STAT_BURSTLEN_SET
#define MEMSCRUB_STAT_BURSTLEN_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~MEMSCRUB_STAT_BURSTLEN_MASK ) | \
MEMSCRUB_STAT_BURSTLEN_MASK ) )
◆ MEMSCRUB_STAT_RUNCOUNT
#define MEMSCRUB_STAT_RUNCOUNT (   _val)
Value:
( ( ( _val ) << MEMSCRUB_STAT_RUNCOUNT_SHIFT ) & \
MEMSCRUB_STAT_RUNCOUNT_MASK )
◆ MEMSCRUB_STAT_RUNCOUNT_GET
#define MEMSCRUB_STAT_RUNCOUNT_GET (   _reg)
Value:
( ( ( _reg ) & MEMSCRUB_STAT_RUNCOUNT_MASK ) >> \
◆ MEMSCRUB_STAT_RUNCOUNT_SET
#define MEMSCRUB_STAT_RUNCOUNT_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~MEMSCRUB_STAT_RUNCOUNT_MASK ) | \
MEMSCRUB_STAT_RUNCOUNT_MASK ) )
