RTEMS 6.1-rc2
GR1553B Hardware Configuration Register (HC)
This group contains register bit definitions. More...
#define GR1553B_HC_MOD   0x80000000U
#define GR1553B_HC_CVER   0x1000U
#define GR1553B_HC_XKEYS   0x800U
#define GR1553B_HC_ENDIAN_SHIFT   9
#define GR1553B_HC_ENDIAN_MASK   0x600U
#define GR1553B_HC_ENDIAN_GET(_reg)
#define GR1553B_HC_ENDIAN_SET(_reg, _val)
#define GR1553B_HC_ENDIAN(_val)
#define GR1553B_HC_SCLK   0x100U
#define GR1553B_HC_CCFREQ_SHIFT   0
#define GR1553B_HC_CCFREQ_MASK   0xffU
#define GR1553B_HC_CCFREQ_GET(_reg)
#define GR1553B_HC_CCFREQ_SET(_reg, _val)
#define GR1553B_HC_CCFREQ(_val)
◆ GR1553B_HC_CCFREQ
#define GR1553B_HC_CCFREQ (   _val)
Value:
( ( ( _val ) << GR1553B_HC_CCFREQ_SHIFT ) & \
GR1553B_HC_CCFREQ_MASK )
◆ GR1553B_HC_CCFREQ_GET
#define GR1553B_HC_CCFREQ_GET (   _reg)
Value:
( ( ( _reg ) & GR1553B_HC_CCFREQ_MASK ) >> \
◆ GR1553B_HC_CCFREQ_SET
#define GR1553B_HC_CCFREQ_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GR1553B_HC_CCFREQ_MASK ) | \
GR1553B_HC_CCFREQ_MASK ) )
◆ GR1553B_HC_ENDIAN
#define GR1553B_HC_ENDIAN (   _val)
Value:
( ( ( _val ) << GR1553B_HC_ENDIAN_SHIFT ) & \
GR1553B_HC_ENDIAN_MASK )
◆ GR1553B_HC_ENDIAN_GET
#define GR1553B_HC_ENDIAN_GET (   _reg)
Value:
( ( ( _reg ) & GR1553B_HC_ENDIAN_MASK ) >> \
◆ GR1553B_HC_ENDIAN_SET
#define GR1553B_HC_ENDIAN_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GR1553B_HC_ENDIAN_MASK ) | \
GR1553B_HC_ENDIAN_MASK ) )
