RTEMS 6.1-rc2
Modules | Files | Data Structures | Macros | Functions | Variables
SPARC64 Board Support Packages. More...
 Generic
 Generic.
 MM
 MM.
 Niagara
 Niagara.
 USIII
 USIII Board Support Package.
file  arch.h
 Various sparc64-specific macros.
file  boot.h
file  regdef.h
file  stack.h
file  arch.h
 Various sun4u-specific macros.
struct  utask_t
struct  taskmap_t
struct  memzone_t
struct  memmap_t
struct  bootinfo_t
#define ASI_AIUP   0x10 /** Access to primary context with user privileges. */
#define ASI_AIUS   0x11 /** Access to secondary context with user privileges. */
#define NWINDOWS   8 /** Number of register window sets. */
#define VMA   0x4000
#define LMA   VMA
#define TASKMAP_MAX_RECORDS   32
#define MEMMAP_MAX_RECORDS   32
#define BOOTINFO_TASK_NAME_BUFLEN   32
#define PSTATE_IE_BIT   (1 << 1)
#define PSTATE_AM_BIT   (1 << 3)
#define PSTATE_AG_BIT   (1 << 0)
#define PSTATE_IG_BIT   (1 << 11)
#define PSTATE_MG_BIT   (1 << 10)
#define PSTATE_PRIV_BIT   (1 << 2)
#define PSTATE_PEF_BIT   (1 << 4)
#define TSTATE_PSTATE_SHIFT   8
#define TSTATE_PRIV_BIT   (PSTATE_PRIV_BIT << TSTATE_PSTATE_SHIFT)
#define TSTATE_IE_BIT   (PSTATE_IE_BIT << TSTATE_PSTATE_SHIFT)
#define TSTATE_PEF_BIT   (PSTATE_PEF_BIT << TSTATE_PSTATE_SHIFT)
#define TSTATE_CWP_MASK   0x1f
#define WSTATE_NORMAL(n)   (n)
#define WSTATE_OTHER(n)   ((n) << 3)
#define ICBUS_CONFIG_MID_SHIFT   17
#define STACK_ITEM_SIZE   8
#define STACK_ALIGNMENT   16
#define STACK_WINDOW_SAVE_AREA_SIZE   (16 * STACK_ITEM_SIZE)
#define STACK_ARG_SAVE_AREA_SIZE   (6 * STACK_ITEM_SIZE)
#define STACK_BIAS   2047
#define STACK_ARG0   0
#define STACK_ARG1   8
#define STACK_ARG2   16
#define STACK_ARG3   24
#define STACK_ARG4   32
#define STACK_ARG5   40
#define STACK_ARG6   48
#define ASI_NUCLEUS_QUAD_LDD   0x24 /** ASI for 16-byte atomic loads. */
#define ASI_DCACHE_TAG   0x47 /** ASI D-Cache Tag. */
#define ASI_ICBUS_CONFIG   0x4a /** ASI of the UPA_CONFIG/FIREPLANE_CONFIG register. */
void arch_pre_main (void)
bootinfo_t bootinfo
◆ STACK_ALIGNMENT
According to SPARC Compliance Definition, every stack frame is 16-byte aligned.
◆ STACK_ARG_SAVE_AREA_SIZE
Six extended words for first six arguments.
◆ STACK_BIAS
By convention, the actual top of the stack is sp + STACK_BIAS.
◆ STACK_WINDOW_SAVE_AREA_SIZE
16-extended-word save area for i[0-7] and l[0-7] registers.
