RTEMS 6.1-rc2
Files | Data Structures | Macros | Typedefs | Functions | Variables
NXP MPC8260ADS Board Support Package. More...
file  bsp.h
 Global BSP definitions.
struct  bcsr
#define RTEMS_BSP_NETWORK_DRIVER_NAME   "eth1"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_enet_driver_attach
typedef struct bcsr BCSR
int rtems_enet_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching)
void * bsp_idle_thread (uintptr_t ignored)
 Optimized idle task.
void cpu_init (void)
int mbx8xx_console_get_configuration (void)
uint32_t bsp_serial_per_sec
◆ bsp_idle_thread()
void * bsp_idle_thread ( uintptr_t  ignored)
This BSP provides its own IDLE thread to override the RTEMS one.
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
#include <bsp.h>
#define CONFIGURE_INIT
#define CONFIGURE_IDLE_TASK_BODY bsp_idle_thread
#include <confdefs.h>
This header file evaluates the application configuration options defined by the application.
The MSR[POW] bit is set to put the CPU into the low power mode defined in HID0. HID0 is set during starup in start.S.
#include <bsp.h>
