RTEMS 6.1-rc2
Files | Macros | Functions
BF537-STAMP Board Support Package. More...
file  bsp.h
 Global BSP definitions.
#define BSP_DATA_CACHE_CONFIG   (3 << DMEM_CONTROL_DMC_SHIFT)
#define PLL_CSEL   0x0000 /* CCLK = VCO */
#define PLL_SSEL   0x0003 /* SCLK = CCLK/3 */
#define PLL_MSEL   0x3A00 /* VCO = 29xCLKIN */
#define PLL_DF   0x0001 /* CLKIN = XTL/2 */
#define CCLK   500000000 /* CORE CLOCK */
#define SCLK   100000000 /* SYSTEM CLOCK */
#define CONSOLE_FORCE_BAUD   57600
#define L1_DATA_SRAM_A   0xff800000L
#define FIFOLENGTH   0x100
#define rtems_bsp_delay(microseconds)
#define RAM_START   0
#define RAM_END   0x4000000
#define RTEMS_BSP_NETWORK_DRIVER_NAME   "eth1"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH   bf537Stamp_network_driver_attach
void setLED (uint8_t value)
uint8_t getLEDs (void)
void setLEDs (uint8_t value)
uint8_t getButtons (void)
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
void Init_RTC (void)
int bf537Stamp_network_driver_attach (struct rtems_bsdnet_ifconfig *, int)
◆ rtems_bsp_delay
#define rtems_bsp_delay (   microseconds)
Value:
