RTEMS 6.1-rc2
Modules | Files | Macros | Functions
SMDK2410 Board Support Package. More...
 SMC Disk Driver
 SMC Disk Driver Support.
file  bsp.h
 Global BSP definitons.
#define BSP_FEATURE_IRQ_EXTENSION
#define BSP_OSC_FREQ   12000000
 12 MHz oscillator
#define M_MDIV   81
 FCLK=133Mhz.
#define M_PDIV   2
#define M_SDIV   1
#define M_CLKDIVN   2
 HCLK=FCLK/2, PCLK=FCLK/2.
#define REFEN   0x1
 enable refresh
#define TREFMD   0x0
 CBR(CAS before RAS)/auto refresh.
#define Trp   0x0
 2 clk
#define Trc   0x3
 7 clk
#define Tchr   0x2
 3 clk
void * bsp_idle_thread (uintptr_t ignored)
 This BSP provides its own IDLE thread to override the RTEMS one.
uint32_t get_FCLK (void)
 functions to get the differents s3c2400 clks
uint32_t get_HCLK (void)
uint32_t get_PCLK (void)
uint32_t get_UCLK (void)
◆ bsp_idle_thread()
void * bsp_idle_thread ( uintptr_t  ignored)
So we prototype it and define the constant confdefs.h expects to configure a BSP specific one.
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
#include <bsp.h>
#define CONFIGURE_INIT
#define CONFIGURE_IDLE_TASK_BODY bsp_idle_thread
#include <confdefs.h>
This header file evaluates the application configuration options defined by the application.
Optimized idle task.
The MSR[POW] bit is set to put the CPU into the low power mode defined in HID0. HID0 is set during starup in start.S.
#include <bsp.h>
