This group contains the linker sets API.
More...
file | linkersets.h |
| This header file provides the linker sets API.
#define | RTEMS_LINKER_SET_BEGIN(set) _Linker_set_##set##_begin |
#define | RTEMS_LINKER_SET_END(set) _Linker_set_##set##_end |
#define | RTEMS_LINKER_SET_ALIGN(type) RTEMS_ALIGNED( RTEMS_ALIGNOF( type ) ) |
#define | RTEMS_LINKER_ROSET_DECLARE(set, type) |
#define | RTEMS_LINKER_ROSET(set, type) |
#define | RTEMS_LINKER_ROSET_ITEM_ORDERED_DECLARE(set, type, item, order) |
#define | RTEMS_LINKER_ROSET_ITEM_DECLARE(set, type, item) |
#define | RTEMS_LINKER_ROSET_ITEM_REFERENCE(set, type, item) |
#define | RTEMS_LINKER_ROSET_ITEM_ORDERED(set, type, item, order) |
#define | RTEMS_LINKER_ROSET_ITEM(set, type, item) |
#define | RTEMS_LINKER_ROSET_CONTENT(set, decl) |
#define | RTEMS_LINKER_RWSET_DECLARE(set, type) |
#define | RTEMS_LINKER_RWSET(set, type) |
#define | RTEMS_LINKER_RWSET_ITEM_ORDERED_DECLARE(set, type, item, order) |
#define | RTEMS_LINKER_RWSET_ITEM_DECLARE(set, type, item) |
#define | RTEMS_LINKER_RWSET_ITEM_REFERENCE(set, type, item) |
#define | RTEMS_LINKER_RWSET_ITEM_ORDERED(set, type, item, order) |
#define | RTEMS_LINKER_RWSET_ITEM(set, type, item) |
#define | RTEMS_LINKER_RWSET_CONTENT(set, decl) |
#define | RTEMS_LINKER_SET_SIZE(set) |
#define | RTEMS_LINKER_SET_ITEM_COUNT(set) |
#define | RTEMS_LINKER_SET_IS_EMPTY(set) ( RTEMS_LINKER_SET_SIZE( set ) == 0 ) |
#define | RTEMS_LINKER_SET_FOREACH(set, item) |
◆ RTEMS_LINKER_ROSET
#define RTEMS_LINKER_ROSET |
set, |
type |
Value: RTEMS_LINKER_SET_ALIGN( type ) type const RTEMS_LINKER_SET_BEGIN( set )[ 0 ] \
RTEMS_SECTION(
".rtemsroset." #set
".begin" )
RTEMS_USED; \
RTEMS_LINKER_SET_ALIGN( type ) type const RTEMS_LINKER_SET_END( set )[ 0 ] \
RTEMS_SECTION(
".rtemsroset." #set
".end" )
RTEMS_USED
#define RTEMS_USED
Tells the compiler that the variable or function is used.
Definition: basedefs.h:924
◆ RTEMS_LINKER_ROSET_CONTENT
#define RTEMS_LINKER_ROSET_CONTENT |
set, |
decl |
Value: decl \
RTEMS_SECTION( ".rtemsroset." #set ".content" )
◆ RTEMS_LINKER_ROSET_DECLARE
#define RTEMS_LINKER_ROSET_DECLARE |
set, |
type |
Value: extern RTEMS_LINKER_SET_ALIGN( type ) type \
const RTEMS_LINKER_SET_BEGIN( set )[]; \
const RTEMS_LINKER_SET_END( set )[]
◆ RTEMS_LINKER_ROSET_ITEM
#define RTEMS_LINKER_ROSET_ITEM |
set, |
type, |
item |
Value: RTEMS_LINKER_SET_ALIGN( type ) type const _Linker_set_##set##_##item \
RTEMS_SECTION(
".rtemsroset." #set
".content.1" )
RTEMS_USED
◆ RTEMS_LINKER_ROSET_ITEM_DECLARE
#define RTEMS_LINKER_ROSET_ITEM_DECLARE |
set, |
type, |
item |
Value: extern RTEMS_LINKER_SET_ALIGN( type ) type const _Linker_set_##set##_##item \
RTEMS_SECTION( ".rtemsroset." #set ".content.1" )
◆ RTEMS_LINKER_ROSET_ITEM_ORDERED
#define RTEMS_LINKER_ROSET_ITEM_ORDERED |
set, |
type, |
item, |
order |
RTEMS_SECTION(
".rtemsroset." #set
".content.0." RTEMS_XSTRING( order ) ) \
#define RTEMS_XSTRING(...)
Stringifies the expansion of the arguments.
Definition: basedefs.h:987
◆ RTEMS_LINKER_ROSET_ITEM_ORDERED_DECLARE
#define RTEMS_LINKER_ROSET_ITEM_ORDERED_DECLARE |
set, |
type, |
item, |
order |
RTEMS_SECTION(
".rtemsroset." #set
◆ RTEMS_LINKER_ROSET_ITEM_REFERENCE
#define RTEMS_LINKER_ROSET_ITEM_REFERENCE |
set, |
type, |
item |
Value: static RTEMS_LINKER_SET_ALIGN( type ) type \
const * const _Set_reference_##set##_##item \
RTEMS_SECTION(
".rtemsroset.reference" )
RTEMS_USED = \
&_Linker_set_##set##_##item
◆ RTEMS_LINKER_RWSET
#define RTEMS_LINKER_RWSET |
set, |
type |
Value: RTEMS_LINKER_SET_ALIGN( type ) type RTEMS_LINKER_SET_BEGIN( set )[ 0 ] \
RTEMS_SECTION(
".rtemsrwset." #set
".begin" )
RTEMS_USED; \
RTEMS_LINKER_SET_ALIGN( type ) type RTEMS_LINKER_SET_END( set )[ 0 ] \
RTEMS_SECTION(
".rtemsrwset." #set
".end" )
RTEMS_USED
◆ RTEMS_LINKER_RWSET_CONTENT
#define RTEMS_LINKER_RWSET_CONTENT |
set, |
decl |
Value: decl \
RTEMS_SECTION( ".rtemsrwset." #set ".content" )
◆ RTEMS_LINKER_RWSET_DECLARE
#define RTEMS_LINKER_RWSET_DECLARE |
set, |
type |
Value: extern RTEMS_LINKER_SET_ALIGN( type ) type RTEMS_LINKER_SET_BEGIN( set )[]; \
extern RTEMS_LINKER_SET_ALIGN( type ) type RTEMS_LINKER_SET_END( set )[]
◆ RTEMS_LINKER_RWSET_ITEM
#define RTEMS_LINKER_RWSET_ITEM |
set, |
type, |
item |
Value: RTEMS_LINKER_SET_ALIGN( type ) type _Linker_set_##set##_##item \
RTEMS_SECTION(
".rtemsrwset." #set
".content.1" )
RTEMS_USED
◆ RTEMS_LINKER_RWSET_ITEM_DECLARE
#define RTEMS_LINKER_RWSET_ITEM_DECLARE |
set, |
type, |
item |
Value: extern RTEMS_LINKER_SET_ALIGN( type ) type _Linker_set_##set##_##item \
RTEMS_SECTION( ".rtemsrwset." #set ".content.1" )
◆ RTEMS_LINKER_RWSET_ITEM_ORDERED
#define RTEMS_LINKER_RWSET_ITEM_ORDERED |
set, |
type, |
item, |
order |
RTEMS_SECTION(
".rtemsrwset." #set
◆ RTEMS_LINKER_RWSET_ITEM_ORDERED_DECLARE
#define RTEMS_LINKER_RWSET_ITEM_ORDERED_DECLARE |
set, |
type, |
item, |
order |
RTEMS_SECTION(
".rtemsrwset." #set
◆ RTEMS_LINKER_RWSET_ITEM_REFERENCE
#define RTEMS_LINKER_RWSET_ITEM_REFERENCE |
set, |
type, |
item |
RTEMS_SECTION(
RTEMS_USED = \
◆ RTEMS_LINKER_SET_FOREACH
#define RTEMS_LINKER_SET_FOREACH |
set, |
item |
Value: for ( \
item = (void *) _Linker_set_Obfuscate( RTEMS_LINKER_SET_BEGIN( set ) ) ; \
item != RTEMS_LINKER_SET_END( set ) ; \
++item \
◆ RTEMS_LINKER_SET_ITEM_COUNT
#define RTEMS_LINKER_SET_ITEM_COUNT |
set | ) |
Value: ( RTEMS_LINKER_SET_SIZE( set ) \
/ sizeof( RTEMS_LINKER_SET_BEGIN( set )[ 0 ] ) )
◆ RTEMS_LINKER_SET_SIZE
#define RTEMS_LINKER_SET_SIZE |
set | ) |
Value: ( _Linker_set_Obfuscate( RTEMS_LINKER_SET_END( set ) ) \
- _Linker_set_Obfuscate( RTEMS_LINKER_SET_BEGIN( set ) ) )
