RTEMS 6.1-rc2
#define __HAL_PWR_AVD_EXTI_ENABLE_IT()   SET_BIT(EXTI->IMR1, PWR_EXTI_LINE_AVD)
 Enable the AVD EXTI Line 16.
#define __HAL_PWR_AVD_EXTI_DISABLE_IT()   CLEAR_BIT(EXTI->IMR1, PWR_EXTI_LINE_AVD)
 Disable the AVD EXTI Line 16.
#define __HAL_PWR_AVD_EXTI_ENABLE_EVENT()   SET_BIT(EXTI->EMR1, PWR_EXTI_LINE_AVD)
 Enable event on AVD EXTI Line 16.
#define __HAL_PWR_AVD_EXTI_DISABLE_EVENT()   CLEAR_BIT(EXTI->EMR1, PWR_EXTI_LINE_AVD)
 Disable event on AVD EXTI Line 16.
#define __HAL_PWR_AVD_EXTI_ENABLE_RISING_EDGE()   SET_BIT(EXTI->RTSR1, PWR_EXTI_LINE_AVD)
 Enable the AVD Extended Interrupt Rising Trigger.
#define __HAL_PWR_AVD_EXTI_DISABLE_RISING_EDGE()   CLEAR_BIT(EXTI->RTSR1, PWR_EXTI_LINE_AVD)
 Disable the AVD Extended Interrupt Rising Trigger.
#define __HAL_PWR_AVD_EXTI_ENABLE_FALLING_EDGE()   SET_BIT(EXTI->FTSR1, PWR_EXTI_LINE_AVD)
 Enable the AVD Extended Interrupt Falling Trigger.
#define __HAL_PWR_AVD_EXTI_DISABLE_FALLING_EDGE()   CLEAR_BIT(EXTI->FTSR1, PWR_EXTI_LINE_AVD)
 Disable the AVD Extended Interrupt Falling Trigger.
#define __HAL_PWR_AVD_EXTI_ENABLE_RISING_FALLING_EDGE()
 Enable the AVD Extended Interrupt Rising and Falling Trigger.
#define __HAL_PWR_AVD_EXTI_DISABLE_RISING_FALLING_EDGE()
 Disable the AVD Extended Interrupt Rising & Falling Trigger.
#define __HAL_PWR_AVD_EXTI_GET_FLAG()   ((READ_BIT(EXTI->PR1, PWR_EXTI_LINE_AVD) == PWR_EXTI_LINE_AVD) ? 1UL : 0UL)
 Check whether the specified AVD EXTI interrupt flag is set or not.
#define __HAL_PWR_AVD_EXTI_CLEAR_FLAG()   SET_BIT(EXTI->PR1, PWR_EXTI_LINE_AVD)
 Clear the AVD EXTI flag.
#define __HAL_PWR_AVD_EXTI_GENERATE_SWIT()   SET_BIT(EXTI->SWIER1, PWR_EXTI_LINE_AVD)
 Generates a Software interrupt on AVD EXTI line.
◆ __HAL_PWR_AVD_EXTI_CLEAR_FLAG
#define __HAL_PWR_AVD_EXTI_CLEAR_FLAG ( )    SET_BIT(EXTI->PR1, PWR_EXTI_LINE_AVD)
Return values
None.
◆ __HAL_PWR_AVD_EXTI_DISABLE_EVENT
#define __HAL_PWR_AVD_EXTI_DISABLE_EVENT ( )    CLEAR_BIT(EXTI->EMR1, PWR_EXTI_LINE_AVD)
Return values
None.
◆ __HAL_PWR_AVD_EXTI_DISABLE_FALLING_EDGE
#define __HAL_PWR_AVD_EXTI_DISABLE_FALLING_EDGE ( )    CLEAR_BIT(EXTI->FTSR1, PWR_EXTI_LINE_AVD)
Return values
None.
◆ __HAL_PWR_AVD_EXTI_DISABLE_IT
#define __HAL_PWR_AVD_EXTI_DISABLE_IT ( )    CLEAR_BIT(EXTI->IMR1, PWR_EXTI_LINE_AVD)
Return values
None.
◆ __HAL_PWR_AVD_EXTI_DISABLE_RISING_EDGE
#define __HAL_PWR_AVD_EXTI_DISABLE_RISING_EDGE ( )    CLEAR_BIT(EXTI->RTSR1, PWR_EXTI_LINE_AVD)
Return values
None.
◆ __HAL_PWR_AVD_EXTI_DISABLE_RISING_FALLING_EDGE
#define __HAL_PWR_AVD_EXTI_DISABLE_RISING_FALLING_EDGE ( )
Value:
do { \
__HAL_PWR_AVD_EXTI_DISABLE_RISING_EDGE(); \
__HAL_PWR_AVD_EXTI_DISABLE_FALLING_EDGE(); \
} while(0);
Return values
None.
◆ __HAL_PWR_AVD_EXTI_ENABLE_EVENT
#define __HAL_PWR_AVD_EXTI_ENABLE_EVENT ( )    SET_BIT(EXTI->EMR1, PWR_EXTI_LINE_AVD)
Return values
None.
◆ __HAL_PWR_AVD_EXTI_ENABLE_FALLING_EDGE
#define __HAL_PWR_AVD_EXTI_ENABLE_FALLING_EDGE ( )    SET_BIT(EXTI->FTSR1, PWR_EXTI_LINE_AVD)
Return values
None.
◆ __HAL_PWR_AVD_EXTI_ENABLE_IT
#define __HAL_PWR_AVD_EXTI_ENABLE_IT ( )    SET_BIT(EXTI->IMR1, PWR_EXTI_LINE_AVD)
Return values
None.
◆ __HAL_PWR_AVD_EXTI_ENABLE_RISING_EDGE
#define __HAL_PWR_AVD_EXTI_ENABLE_RISING_EDGE ( )    SET_BIT(EXTI->RTSR1, PWR_EXTI_LINE_AVD)
Return values
None.
◆ __HAL_PWR_AVD_EXTI_ENABLE_RISING_FALLING_EDGE
#define __HAL_PWR_AVD_EXTI_ENABLE_RISING_FALLING_EDGE ( )
Value:
do { \
__HAL_PWR_AVD_EXTI_ENABLE_RISING_EDGE(); \
__HAL_PWR_AVD_EXTI_ENABLE_FALLING_EDGE(); \
} while(0);
Return values
None.
◆ __HAL_PWR_AVD_EXTI_GENERATE_SWIT
#define __HAL_PWR_AVD_EXTI_GENERATE_SWIT ( )    SET_BIT(EXTI->SWIER1, PWR_EXTI_LINE_AVD)
Return values
None.
◆ __HAL_PWR_AVD_EXTI_GET_FLAG
#define __HAL_PWR_AVD_EXTI_GET_FLAG ( )    ((READ_BIT(EXTI->PR1, PWR_EXTI_LINE_AVD) == PWR_EXTI_LINE_AVD) ? 1UL : 0UL)
Return values
EXTIAVD Line Status.
